Old 09-13-2014, 12:08 PM   #51
FnLow69
FnLow69's Avatar
Re: [PROJECT] "Hot Rod" 1931 model a Bonneville/ Rolling bones style
Well I finally got around to getting the clutch linkage hooked up, had to notch out the x-member in order to get the pedal to travel far enough. also got the steering box mount modified to work for side steering and made a riveted cover for the frame where the shaft comes out. Yesterday I fixed the bad patch job where the old filler used to be in the cowl that the previous owner did. also welded the cowl side seems.
Initial mock up
modified mount and final placement (still need to trim down)
this is what I came up with to strengthen the area I remove for the clutch arm clearance
(will weld in once the body is removed)
Cowl top before
cowl top after lots of hammer and dolly work and little bit of English wheeling
And cowl welded in
Justin
FnLow69 is offline   Reply With Quote
Old 09-14-2014, 12:51 AM   #52
FnLow69
FnLow69's Avatar
Finished the welding on the spreader bar and made a push bar for it. Also started getting the front floor kick ups made no pictures of that though.
Here's the spreader bar and push bar
Justin
Old 09-14-2014, 11:29 AM   #53
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Very nice as always...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-14-2014, 04:38 PM   #54
FnLow69
FnLow69's Avatar
thanks
Old 09-27-2014, 03:50 PM   #55
79azc10
Looks great can't wait to see more of it
79azc10 is offline   Reply With Quote
Old 09-28-2014, 12:52 AM   #56
FnLow69
FnLow69's Avatar
thanks
Old 10-05-2014, 07:23 PM   #57
hopped up
hopped up's Avatar
Awesome metalwork ! And that chop is great! Car looks real good and mean! What's the wheelbase you're using? Stance looks right on ,just wondering if it's the rear wheels are a little too far back? Maybe the angle of the pic cuz you obviously know what you're doing
hopped up is offline   Reply With Quote
Old 10-05-2014, 10:31 PM   #58
FnLow69
FnLow69's Avatar
Thanks hopped up, I believe the wheel base ended up at 106". As for the rear tire its pretty much centered in the wheel well, so It must be the picture.
Old 10-07-2014, 06:36 PM   #59
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice metal work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-08-2014, 12:53 AM   #60
FnLow69
FnLow69's Avatar
Found some shocks that would work on the rear just had to get creative to mount them, also had to remove the sub floor and raised it to clear the mounts. While the sub floor was out I decide to cut out and replace the wheel tubs.
Found a ton of bondo by the rear passenger side wheel area.
Heres the wheel tubs done, don't have a picture of the other side.
Next I started on the floor kick-up in the front and the trans tunnel. the double step is so the wood floor will sit flush with the upper flat area.
Next I notched for the drive line and started the driveline tunnel and the floor.
And that bring us guys up to date with the progress.
thanks Justin
Old 12-08-2014, 03:46 PM   #61
Dieselwrencher
Justin, great fab work. The floor turned out awesome!
Ryan
Old 12-09-2014, 09:14 AM   #62
FnLow69
FnLow69's Avatar
thank you sir!
Old 12-13-2014, 01:48 PM   #63
Flames97
Flames97's Avatar
That looks amazing, very clean!!Excellent work!
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 12-13-2014, 05:24 PM   #64
Desperado454
Desperado454's Avatar
Floors are looking great, nice work! Not sure if you posted before, but are you using anything between the body and frame or is it mounted solid?
Twin Turbo '76 C10 Build
'28 Model A Build
-Brooks
Desperado454 is offline   Reply With Quote
Old 12-15-2014, 07:34 PM   #65
JakeDW
JakeDW's Avatar
Looking really nice like all of your projects.
Jake
JakeDW is offline   Reply With Quote
Old 12-15-2014, 11:41 PM   #66
FnLow69
FnLow69's Avatar
Thank you
Thanks, I have frame webbing to go on top of the frame and the middle mounts I have some rubber that ill cut and punch a hole in.
Jake
Thanks man! one day ill get back to the others lol...
Old 12-17-2014, 08:09 PM   #67
reaper71
reaper71's Avatar
Nice to see you over here on the site!!
I was following the dodge build on the Hamb. for awhile...
very Nice,Neat and clean work..Chop is badass Man...
Mark...
reaper71 is offline   Reply With Quote
Old 12-17-2014, 08:40 PM   #68
Advanced Design
Advanced Design's Avatar
Really nice work! Love the clean lines and neat execution....very cool!
Advanced Design is offline   Reply With Quote
Old 12-26-2014, 01:54 AM   #69
FnLow69
FnLow69's Avatar
Thanks reaper71 and advanced design
Old 02-04-2015, 11:35 PM   #70
FnLow69
FnLow69's Avatar
So Here's an update finally!
Got the floor and driveshaft tunnel done, Front kickup and transmission tunnel still need fastened down some how. Made new trunk braces and Found a goo pair of houdaille shocks to run up front, of course I had to drill a series of holes in them. the link will be replaced with a dog bone style. Next I started on the hood extension, cut just after the first louver and added needed amount. Hood is stretched 5" over stock. Had a nice weekend a couple back so I got it out in the sun to get a good look at it.
Here's the pictures.
Floor
Shocks
Hood extension Started with I nice donor one.
Outside Finally!!
Justin
Old 02-05-2015, 12:04 AM   #71
Advanced Design
You have been busy. Really impressive work!
Old 02-05-2015, 10:44 AM   #72
JakeDW
JakeDW's Avatar
Looks great great fab work as always.
Jake
Old 02-05-2015, 05:52 PM   #73
Dieselwrencher
Very nice work! It looks awesome! A model A coupe or roadster is one of the rods I'd like to build some day.
Ryan
Old 02-05-2015, 09:46 PM   #74
reaper71
reaper71's Avatar
looks killer!!!
Old 02-06-2015, 12:14 AM   #75
youngrodder
youngrodder's Avatar
Very impressive...I like seeing your metal finishing skills. After seeing your work its becoming obvious that the only thing worse than my welding skills are my grinding skills.
Keep at it.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
