Old 05-12-2015, 03:23 AM   #51
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Re: 1988 R30 Crew Soon to be Dropped
Originally Posted by slimneverdies View Post
Curious to see the wheels mounted on there at that ride height. I wonder if the front sticks out any...
I am very tempted, I almost brought them with to work tonight to change in the parking lot but ran out of time. They are heavy bastards as you know so it is painful lugging them around.
Tonight is the start of my work week so maybe I'll do it on my weekend coming up. I am going to pull the SRW 14b out and mock it up with wheels for some measurements before then.
Ghostwhite is offline   Reply With Quote
Old 05-12-2015, 12:19 PM   #52
slimneverdies
slimneverdies's Avatar
Great, you do that so I don't have to worry if it works or not. Some people say you have to shave two of the rear wheels and a bunch say they fit with just the rear end swap...
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 05-12-2015, 08:25 PM   #53
COS399
COS399's Avatar
Nice score on the donor truck.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 05-13-2015, 04:23 AM   #54
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Tried mounting the semis with the adapters on my SRW 14B tonight to get a good overall width measurement and came upon a major hurdle. The SRW hub centric lip is ever so slightly too large of diameter for the bore of the adapters. I also tried to throw one of my dually wheels on the SRW axle and the bore is also too tight for them rims to mount which proves its not the adapters.
I don't have a caliper large enough to measure the diameter of the hub with the studs in the way so I can't tell you an exact number of how much bigger they are but I will say that it is a very very small difference. I thought about using the lugs to suck the adapter on but thought better of it. I have to remove the lug studs for longer ones anyways so I will take the hub and an adapter to a machine shop and have them machine the hub diameter down to the right size for the adapter.
This led me to immediately try and mount the adapters to the dually 14b hub to make sure it wasn't an improperly machined adapter bore. The adapters went on the dually front and back without a problem.
I did set some wheels up with an adapter and laid them stacked up flat on the ground how they would mount on the truck and they measured 13 and 5/16 inches wide from the wheel mount surface of the adapter to the outside of the tire sidewall. The adapter is 13/16" thick.
I took a measurement of how it sits right now and the rear measures out at right around 99.5 inches from outside tire sidewall to outside tire sidewall.
When I get home I can measure the SRW axle from WMS to WMS and add 13 5/16" to each side to figure out how wide that will be and then measure the fenders on the truck.
Old 05-13-2015, 04:27 AM   #55
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Thanks! It will tie up a lot of loose end on this engine install.
Old 05-20-2015, 11:21 PM   #56
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Measured the SRW 14 bolt and it comes out at 67" WMS to WMS which would bring my total width to somewhere around 93.5" total width outside sidewall to outside sidewall once the semi wheels are mounted up.
I may end up having a machine shop take 3/8" off the face of each rear wheel to get some extra clearance at the fender. Right now the wheels are sticking out 2" past the outside lip of the fender with a total width of 99.5" sidewall to sidewall with the DRW axle.
My SRW 14 bolt came from a 1974 C20 regular cab long bed truck.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Old 05-21-2015, 02:28 AM   #57
slimneverdies
I got a measurement of 2-3/4 inches on each side that my wheels stick out measured from just inside of the fenders lips. That's cutting it pretty close if i went with the numbers you have
Long live SLIM
Old 05-29-2015, 03:39 AM   #58
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Got some time in on the dodge.
Lots of parts, some to re-use, some to sell/scrap/trash.
All the wiring is disconnected from the engine to truck. Should be able to button up the throttle linkage, trans linkage, and few other things and be ready to pull the driveshaft and blow mounts apart for final removal.
One step closer to getting the dually in and tore up.
Old 05-31-2015, 08:30 AM   #59
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Tonight's solo adventure went a little like this.
Very tight fit
On another note, I found this thing is pretty local to me. The guy wants $300 for the trailer and shell, I don't need the trailer but the shell has an odd enough look to it that might actually work for one of these slammed trucks.
Thoughts?
Old 05-31-2015, 08:53 AM   #60
tommys72
tommys72's Avatar
Cool buiild, it'll look great laid out over those alcoas . I'm watching
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 06-09-2015, 02:08 AM   #61
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
More uninteresting cummins related stuff showing up.
Bunch of gaskets, a few to fix some leaks and some to go in and do the KDP fix.
4k GSK, valve spring tool and bar over tool
60lb valve springs
I'm trying to get this dodge out of my garage, I have a few local cummins enthusiasts that are interested in taking it so hopefully that pans out. I don't have the room to keep it around and part it out.
Old 06-10-2015, 12:13 PM   #62
Justin@EntropyRad
Justin@EntropyRad's Avatar
Looks tough on the Alcoas...definitely watching this thread
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 07-05-2015, 10:43 AM   #63
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Made some room finally.
And painfully moved it in, my driveway isn't any wider than the garage door so this was a challenge to do single-handed. I only got it in just far enough to close the doors, my roommate was at work.
I'll be starting to slowly tear it down after I get it all the way in.
Old 07-08-2015, 01:52 AM   #64
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Did a little work today, started by removing the running boards and dropping the gas tank. Removed the fuel lines and started on the brake lines to get the inside of the frame cleared out for the 4x3 bracing. The trans crossmember is also in the way mounting inside the frame and being as the drivetrain isn't being reused I moved to the front to get everything out of the way for the engine/trans to come out.
Sorry for the blurry pics, hard to take pics without smearing grease all over my phone.
Was only 98 degrees in the garage due to rain so not as bad as it could be.
Old 07-08-2015, 11:41 PM   #65
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
More pictures of the frame and trans crossmember.
Outside frame, going to grind the rivets out of the body mounts and puts some bolts in temporarily so the mounts can be welded to the frame.
Another mellow day.
A little progress today before stopping early to take the family out to eat.
Wish gm would have made the engine harness a separate section of the main harness, so much crap on this TBI motor.
literally crap
Hauling the 454 to storage tomorrow and then carrying on.
Old 07-10-2015, 12:19 AM   #66
Matt Man
Matt Man's Avatar
Putting a lot of work in, this will be done in no time at this rate. Looking forward to the cummins.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 08-09-2015, 08:38 AM   #67
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Still doing lots of tedious little stuff on the truck when I can. Lots of other summer stuff getting in the way.
Got the body mount rivets ground and drilled out and the mounts welded back on.
First frame tube mocked up.
Tail tube mocked.
I got frame tubes for both sides mocked up, gonna get the cab raised up off the frame before I can go much further.
Whipped up some jack stand extensions for the body, its 'light' so these will do the trick.
Old 09-08-2015, 06:54 PM   #68
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Got it up in the air.
Picked up some stands.
They fit better.
Got started on welding, took three days of sporadic welding, letting everything cool between sets of stitches.
Overtemp'd the welder on the first day.
Few more random.
The tubes are fully welded for the most part. I want to add a few gussets to tie them into the frame at the front where it kicks up.
I also got the front crossmember all out of the way so I can start on cleaning the frame up and getting the DM fitted up. Waiting on a few misc front suspension/chassis parts like bushings and hubs/brakes.
Then I gotta get the bed off and out of the garage to start on the back. I have been distracted with desert racing all summer, chasing/pit crew for the Vegas2Reno desert race and codriving for an upcoming Bluewater Desert Challenge race along with prepping the race truck has been diverting my time.
Old 09-08-2015, 06:59 PM   #69
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
And to help with the desert stuff going forward I picked up a few fab goodies.
And also some general fab stuff.
Old 09-08-2015, 11:34 PM   #70
TrailerTrash
TrailerTrash's Avatar
nice progress!
you are going to love that Hypertherm. i have a Powermax 30xp and its amazing
TrailerTrash is offline   Reply With Quote
Old 09-09-2015, 12:51 AM   #71
COS399
COS399's Avatar
Looking good. After seeing what you are doing I ain't ever going to complain about having to move a couple of things in my garage in order to work on something. I can't wait to see it moving again and then done.
Old 09-09-2015, 12:27 PM   #72
tinydb84
tinydb84's Avatar
I have yet to kick the overload on any welder. I must not be welding enough!!
Nice work. Everything looks great. I am super jealous of you new tools.
I was just in Vegas visiting some friends. You must have AC in your garage....
David
Instagram: myfabguy
Old 09-11-2015, 02:18 AM   #73
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Originally Posted by TrailerTrash View Post
nice progress!
Thanks! It has done well so far. I cut one side of my frame with the oxy/acetylene and one side with a sawzall, THEN bought the plasma and felt like an idiot.
I know I am partly(entirely?) to blame for the clutter but working with what ya got is part of the deal.
Housing is supposed to be cheap out here but finding something affordable with a large or detached garage IN a decent neighborhood is impossible. I think I'm lucky to have a 3 stall.
The tools help! I have been a contractor/self employed for a couple years and didn't have enough write-offs this year so I'm making sure I do for 2015.
I really wish my garage was air conditioned, having a brew while working isn't an option if you want to stay conscious, which sucks! Its toasty for sure but 'winter' is coming temps are about to come down.
Old 09-11-2015, 12:37 PM   #74
slimneverdies
I can't lie, this Vegas heat is the real reason I haven't been in my shop to put in work. Every time I'm in there and it's 105* I find myself just laying down underneath my project.
Long live SLIM
Old 09-11-2015, 06:25 PM   #75
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
The struggle is real! I can't wait for it to cool down.
