Old 10-14-2014, 07:31 AM   #51
68basket
Re: 1960 chevy parkwood wagon!
Originally Posted by Zoomin View Post
Dang, it packs those bags right up in the pockets!
No sharp edges in there I hope.
I was sure to check all around the bag and from as far as i can feel there is no sharp edges and the bag never touches the sides of the spring pocket at all! The brackets have some slots in the holes so that i can adjust the placement a little bit. I will be sure to re check them after i get air to the bags and it sitting down.
68basket is offline   Reply With Quote
Old 10-14-2014, 07:32 AM   #52
68basket
Originally Posted by nlped View Post
That's what I was thinking. I love this thing. You're doing it right
Ed
Thanks! I am loving this car.
Old 10-14-2014, 07:41 AM   #53
Lokin4AReason
Lokin4AReason's Avatar
nice progress so far =0)
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 10-14-2014, 09:38 PM   #54
68basket
All i did tonight was paint the firewall, Looks great. Turned out exactly how i wanted it to. Now to try and not screw it up during the rest of the build.
Old 10-14-2014, 09:40 PM   #55
lolife99
67-72 parts collector,…
lolife99's Avatar
Great to see a body colored firewall,... And not black.
Keith
Convert to disc brakes.
Old 10-14-2014, 09:46 PM   #56
68basket
I did my c10 firewall in black and i hated it. SHould have taken the time to have the factory red paint made up. Thats why i went and got this paint. It was only $40 to get a half pint of paint and harnder and reducer. I hate all black engine bays. The engine will be painted out nice bright orange also.
Hopefully it looks really great when i pop the hood, nice original patina all over the body and a really fresh engine bay.
Old 10-14-2014, 10:01 PM   #57
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I bet it looks great!
Zoomin is offline   Reply With Quote
Old 10-16-2014, 10:55 PM   #58
68basket
pulled the seats and vinal floor. Left rear pan was done by previous owner, and a really poor repair on the left front. I have 3 high quality floor pans for the front and right rear. The rust is not really very bad and the new floor pans will take care of it nicely.
Old 10-19-2014, 12:47 PM   #59
79azc10
Nice wagon and your work is coming along nice
79azc10 is offline   Reply With Quote
Old 10-19-2014, 01:47 PM   #60
68basket
here is some floor panel shots showing the rust
Old 10-19-2014, 01:50 PM   #61
68basket
I got the passenger side pans all welded in yesterday. still need to clean up the under side and seam seal and paint. Only the drivers pan left, that will get done this week.
Old 10-19-2014, 01:53 PM   #62
68basket
There is a big swap meet in town this weekend. Went looking for a few small things and ended up finding a deal on a brand new set of riddler wheels 18-20". I had a good set of continental tires sitting around so I took them to the shop and mounted up for a test fit. I am loving them and cant wait to see the car laid out!!
Old 10-19-2014, 02:44 PM   #63
nlped
nlped's Avatar
Those look like they belong on it. Love it.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-19-2014, 05:33 PM   #64
68basket
last one for the weekend. Just took the rear end out, and found a nasty looking drive shaft. I already have a slip yolk rear shaft and billet carrier bearing from cpp, but I will need to have the front shaft re made. I will call a place here local in the morning.
Old 10-19-2014, 05:37 PM   #65
CAL 58 GMC
CAL 58 GMC's Avatar
The wheels look great!
CAL 58 GMC is offline   Reply With Quote
Old 10-19-2014, 07:00 PM   #66
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Coming out very nice Taylor. I'm lovin it all.
Got a kick out of how PO found more uses for license plate.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 10-20-2014, 10:51 PM   #67
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I got a kick out of the plate too.
Wheels are a great find for your car, nice break you caught there.
Old 10-21-2014, 10:36 AM   #68
Luther Grimace
Luther Grimace's Avatar
Wow! You did a great job replacing that floor pan. Did you butt weld the edges or is the pan lapped onto the original floor pan. I have tried to butt weld all the floor pan replacement I have done but I don't know if it is worth it/as strong.
Also those wheels are awesome. I wish I could find a good deal like that.
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 10-21-2014, 12:46 PM   #69
68basket
Thanks!
The joints are overlapped. on some other panels i will butt joint it, but in this case i felt it ok to just overlap, i will put a few welds on the bottom side then brush on a good dose of seam sealer.
Old 10-21-2014, 02:05 PM   #70
HemiChallenger71
HemiChallenger71's Avatar
Great build thread. I have a '59 bel air 2 door that I am slowly working on. It needs complete floor pans and trunk and the toe board off the firewall. Strangely enough my inner and outer rockers and rear 1/4s are in great shape.
I'm looking forward to hearing your reviews on the rack and pinion. I'm on the fence with one in my car. They seem to have mixed reviews for x-frame chevys.
HemiChallenger71 is offline   Reply With Quote
Old 10-21-2014, 02:36 PM   #71
68basket
Thanks everyone for taking a look at my build and taking the time to comment. It really is encouraging!!
My rockers are perfect, only thing this car needs is floors. and the outer lower corners of the rear doors have spots.
The rack kit looks like very high quality. I could not go wrong with it because all of my steering system was trash, and i had no pump hoses etc. I also did not want to buy a new radiator to clear the bigger p/s box. I also got summit to price match and i think i only paid $1050 for the whole kit. The only thing it does not included is a belt and fluid!
I will update more on the rack kit after its installed.
Old 10-22-2014, 04:51 AM   #72
79azc10
Looking good
Old 10-23-2014, 10:52 PM   #73
68basket
Got the axle housing stripped down. The gears and bearings appear to be in god condition so i am going to run them for now. They are 3.08 and will probably get changed out after i drive it a while to better perform with the 700r4 overdrive. Rear end will get all resealed and the disc brakes installed.
Old 10-23-2014, 10:54 PM   #74
68basket
Got a little more done. All the rear ride tech strong arms are installed and have to say they are extremely nice parts. Installed the air bags and brackets with them.
Cut out the one remaining floor pan section and prepped for the new pan to go in.
Old 10-23-2014, 11:35 PM   #75
tommys72
tommys72's Avatar
nice progress! Looks great
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
accuair, bagged, elevel, parkwood, wagon
