Old 10-26-2014, 07:09 PM   #51
Jake Wade
Jake Wade's Avatar
Re: Used Parts Build
Man, that's a lot of work
Jake Wade is offline   Reply With Quote
Old 10-26-2014, 08:17 PM   #52
tinydb84
tinydb84's Avatar
Yeah its a bit of work done so far....been working too much and working on other peoples cars. Going to bodywork class once a week though. Pretty cool set up. Even have a frame straightener
One of the students has a pretty nice truck
I have been a bit sick of modifying ever part to fit my 75 and don't want to even deal with running air lines or buy valves etc. I also am limited with the 8 lug set up so I went online and found a set of control arms and a 12 bolt for really cheap.
I'm going to toss a set of springs in there so I can work on getting the engine and trans mocked up. I just really want to drive the thing. Once its running I'll start bagging it.
David
Instagram: myfabguy
Old 10-26-2014, 08:56 PM   #53
tinydb84
tinydb84's Avatar
Sold the sectioned crossmember I did awhile back:
Worked on a patch panel in class. Everyone had to weld a side (mine is the one without all the burn through lol)
One of the guys from class was working on his project.
Working on shrinking metal. Prius fenders as super thin!
Really need to buy a blaster....Cleaning rust and paint is such a pain:
Lot more cleaning ahead. Then going to do some painting.
David
Instagram: myfabguy
Old 11-09-2014, 04:50 AM   #54
tinydb84
tinydb84's Avatar
I was planning on just tossing the front suspension back together but couldnt leave well enough alone. I stole the idea from Rob at No Limit.
Ordered ball joint cups from Speedway Motors. I moved the ball joints forward 5/8'' of an inch and about 1/16'' inch in.
My hole saw was getting dull. This sped everything up faster than I thought it would.
I'll weld the new cups in tomorrow.
David
Instagram: myfabguy
Old 11-15-2014, 11:16 PM   #55
tinydb84
tinydb84's Avatar
Welded the cups in:
David
Instagram: myfabguy
Old 11-15-2014, 11:17 PM   #56
tinydb84
tinydb84's Avatar
Didnt want to rattle can my suspension parts and wanted to try something other than the por15 I am using on my frame.
Didnt come out too bad. Got a few runs and bit of a dry spot. I should have waited a bit longer between coats. The amount you spray at one time is semi limited because the can starts to get cold. We'll see how well it holds up.
David
Instagram: myfabguy
Old 11-20-2014, 08:47 PM   #57
rusty76
rusty76's Avatar
Cool build. I dig it. Where did you get the little aerosol sprayer? Some really nice work.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 11-20-2014, 10:21 PM   #58
tinydb84
tinydb84's Avatar
Thanks man. You can get them at most hardware stores. Its 9 bucks for the set up but then you can reuse the bottom and buy the tops for around 4 bucks.
David
Instagram: myfabguy
Old 11-20-2014, 11:11 PM   #59
73Super8
73Super8's Avatar
Wow, very nice work. So meticulous.
73Super8 is offline   Reply With Quote
Old 11-21-2014, 11:18 AM   #60
tintbox
Looking good!
tintbox is offline   Reply With Quote
Old 11-21-2014, 06:52 PM   #61
rusty76
rusty76's Avatar
Thanks.
My build thread
Crossmembers CC
Old 11-23-2014, 01:17 PM   #62
Hankster
Hankster's Avatar
Just read this whole thread, and I must say bada$$ truck! Keep up the work man!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 12-12-2014, 11:01 PM   #63
slotard
What engine are you putting in it?
Why did a C10 start out 8 lug, or did someone convert it? Depending on what's in the rear end I might be interested in some parts.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-13-2014, 01:29 AM   #64
tinydb84
tinydb84's Avatar
It is a C20. I was planning on keeping it 3/4 ton but rims where really expensive, the rearend weighs way too much, and I found all the stuff I needed to convert to a 1/2 ton for $200 bucks.
What parts are you looking for?
Edit: I am putting the 5.3 I have in my garage in it. The plan is to turbo it.
David
Instagram: myfabguy
Old 12-13-2014, 10:53 PM   #65
cfan10
cfan10's Avatar
Impressive work. Love the 3.5 man, I miss my g35.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 12-14-2014, 08:40 PM   #66
tinydb84
tinydb84's Avatar
Thanks. I almost got a G35 but the seller backed out and I got the 350Z instead. Still need to tint the windows and tail lights.
David
Instagram: myfabguy
Old 12-14-2014, 08:41 PM   #67
tinydb84
tinydb84's Avatar
Ever feel like all you do is clean and paint...?
Got the frame rails under the cab in POR15. More suspension parts and brackets in epoxy.
David
Instagram: myfabguy
Old 12-18-2014, 04:39 PM   #68
tinydb84
tinydb84's Avatar
Here the final result of my autobody class. Ignore the whole at the top because we cut it out to patch another part of the fender and time have the time to patch that one. It is in primer and has been wet sanded. I was pretty happy how it turned out.
Now I don't know what class to take next. There are two options:
Paint/Refinishing: The second half of this class. The two problems are that the instructor isn't the greatest teacher and I don't think I will be doing any real paint on my projects in the next year. He shows you how to do stuff but is much more show you once then go do it. Since I don't plan on painting right away I don't know if I want to take the class now and forget a bunch of stuff come paint time.
Welding: There is a class that is two nights a week that does the main welding processes (stick/mig/tig/OA). I can mig but want to get better with mig and learn tig.
The classes overlap so I cant do both. What would you all do?
David
Instagram: myfabguy
Old 12-20-2014, 04:27 PM   #69
tinydb84
tinydb84's Avatar
I guess paint only happens during the spring semester so I guess paint it is.
Anyway I went out and bought a new tool...
Its been raining quite a bit over here so I should have some free time to work on setting it up and cleaning my garage.
David
Instagram: myfabguy
Old 01-02-2015, 02:05 AM   #70
tinydb84
tinydb84's Avatar
Little side project.
I'm building a little set up to cool and dry the air.
Obviously I'm not a plumber...
I know the two bottom openings (when I am putting my valves) arent pointed directly down but if I open them under pressure it should clear all the water. I ordered barbed fittings to run rubber lines off each valve and tank drain to outside.
I'm hoping it wont leak too bad. I used plumbers tape and Locktite thread sealant on each fitting.
This is the first time I worked with plumbing/black pipe and I see why people buy expensive air dryers/filters. Trying to keep everything in place and not rotating as you tighten everything is a *****! I think if I need to redo it I am going to clamp it down to 2x4's as I connect each piece.
David
Instagram: myfabguy
Old 01-02-2015, 09:54 PM   #71
jratz1966
jratz1966's Avatar
Hey,just found your thread.subscribed enjoyed what I've seen so fare keep up the good work,can I ask what's the purpose of moving the lower ball joint?
thanks Jratz
jratz1966 is offline   Reply With Quote
Old 01-02-2015, 10:20 PM   #72
tinydb84
tinydb84's Avatar
Thanks.
It's to increase caster. It will make the truck handle better (more like a modern car). I stole the idea from Rob (No Limit) JT build thread.
David
Instagram: myfabguy
Old 01-04-2015, 10:35 PM   #73
tinydb84
tinydb84's Avatar
So I got it all installed. Ran the compressor and opened the valve to the set up I plumbed. No audible leaks! I was expecting it to hiss like hell. It does have a leak because it looses 5lbs an hour but honestly I am happy as a clam.
Filter and secured line at the end.
Drain plumbed in:
I ordered a few barbed fittings to run off the ball valves to run rubber hose outside so I dont have to worry about clean up.
Spent a hour or two trying to line up the cab/front end and gaps. I dont know why but my core support mounts look to be 1/2-3/4'' high...I dont know why. I looked back at all my pictures and cant figure it out. It looks like I will be able to just drill out the rivets and remount the supports lower or I can cut the mounts down.
David
Instagram: myfabguy
Old 01-13-2015, 02:37 AM   #74
tinydb84
tinydb84's Avatar
So my sister from another mother asked me to replace her timing belt on her Honda. This lead me to 4 hours of sweating, straining, and broken tools. After all of that I still couldnt get the crank bolt out.
So I did something that I knew I could pull off...assembling motor mounts haha
New mounts:
Assembled:
But I did manage to trim the fenders, battery box, etc. So I had to take a pic of it.
David
Instagram: myfabguy
Old 01-13-2015, 02:41 AM   #75
tinydb84
tinydb84's Avatar
I have been trying to work on the truck more frequently so I welded up the trusses on my lower bars.
They were a bit long so I cut the edges off. The lines are references for my welds. I didnt want to weld them all the way across:
I used two vises to make sure the bars were square:
Of course I always have one really ****ty weld:
but the rest looked nice:
and done!
David
Instagram: myfabguy
