Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-02-2016, 12:28 AM   #51
ClassicStyle
ClassicStyle's Avatar
Re: 72/68 blazer 4x4 dream/nightmare
What are you asking for it? You can pm me if you want my dad might be interested in a blazer.
I'll think about your problem too, it's kind of a wierd one
1972 Dark blue, Cst, Highlander
ClassicStyle is offline   Reply With Quote
Old 08-02-2016, 01:06 AM   #52
mcmlxix
Collector of Projects
mcmlxix's Avatar
Originally Posted by Madtrucker View Post
... I'm so frustrated I listed it for sale last night.
I plan to check the compression after a little more carb tuning fails. Any insight would be greatly appreciated, I have little time to work on it and would love to start enjoying it.
Before selling it, see if you can find a local shop to look at it for you. It may be something that you just don't see. Set a dollar amount to diagnose. Maybe Someone here can help or help to recommend a shop near you. Throw out a Zip-code to narrow it down.
Rich
1972 K5 Blazer CST Click HERE
Old 08-02-2016, 05:00 AM   #53
Madtrucker
That has crossed my mind, my buddies and I always work on our own stuff and have never had the need for a shop. There's so many possibilities the shop hours would rack up fast. But if anyone knows of a reputable shop near 48185 I'm open minded at this point.
1968 k10 lwb-swb stepside
1936 chevy truck
1977 corvette
My 68 lwb-swb 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=527176
1972/68 blazer 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=641824
Madtrucker is offline   Reply With Quote
Old 08-04-2016, 05:05 PM   #54
Madtrucker
I pulled the carb spacer off, that must have sealed a minor vacuum leak. It idles much better and a little more responsive, baby steps. It's also nice having a taller garage and being able to walk under the hard top now.
1936 chevy truck
1977 corvette
Old 08-05-2016, 07:25 AM   #55
lks dcvn
lks dcvn's Avatar
Agree with a shop visit - sometimes the money spent is worth it to to have the problem diagnosed and then you can fix it.
Also - having the issue fixed would potentially net you more money in a sale.
lks dcvn is offline   Reply With Quote
Old 08-08-2016, 12:16 AM   #56
Madtrucker
So I was offered full asking price the other day and decided to keep it. I told the guy he'd get the first call if I changed my mind again. Anyway after solving the vacuum issue I played with the initial timing a bit last night. I found that 12* made a little more improvement. Better response, more power while cruising and the run on wasn't constant. I still need to set the total timing as soon as a get a good dial back timing light and a helping foot. After 2 harbor freight lights I guess I'll stop being cheap. I've never messed with curving a distributor, I'm sure it'll be a few long aggravating trial and error days. I'm really eager to get it looking right after making it act right.
1936 chevy truck
1977 corvette
Old 08-08-2016, 04:39 AM   #57
Chulisohombre
Chulisohombre's Avatar
It's hard to get rid of something you've worked so much on. With a clocked rv cam and high lift rockers mine likes to sit around 12-15 btdc as well to get full power. I don't use the timing tab anymore though. I timed mine with a vacuum guage and timed it for best overall vacuum at 3000 rpm. Made a world of difference in power.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 09-18-2016, 10:57 PM   #58
Madtrucker
I kind of suspected the tv setting for the Trans as a big portion of the problem, even though I set it as directed. I had a Trans shop reset it with the pressure gauge hooked up, they even had a hard time he said. It made a huge difference, firmer shifts, better response. It still falls off a bit after 3rd but no rediculous. Testing passing gear I found a new problem, I got in it in 3rd downshift was fine up shift seemed pretty hard then the truck started bouncing. It was like driving over a washboard at 40mph, almost like there were no shocks in the front. I'm really hoping it's not a torque converter issue, I'd think that would be more of a jitter. I stopped to inspect it and didn't see anything, it hasn't done it again but I haven't gotten into it either since.
1936 chevy truck
1977 corvette
Old 10-18-2016, 09:00 PM   #59
jondancer
I power washed the front end and started scuffing the firewall. I removed about 60ft of wires going to nowhere. I gave a few parts the old electrolysis bath, and the new trans is waiting to bolt in. I got a new seal kit for the t-case but there maybe a major twist in this build. I came across a complete 2wd frame, I love the tuff look of my truck but I've always loved them lowered with the 68 clip as well. I really need the weigh the cost of both options. I also like the idea of restoring the other frame while driving my truck.
Do you still have access to that 2wd frame? In Michigan ?
jondancer is offline   Reply With Quote
Old 10-19-2016, 08:07 AM   #60
Mr Banshee
I have a 71 rolling 4x4 frame that I'm looking to get rid of. Its up around Grayling MI.
Mike
Mr Banshee is offline   Reply With Quote
Old 10-19-2016, 08:14 AM   #61
jondancer
Looking for 2wd thanks
Old 10-20-2016, 03:27 PM   #62
Madtrucker
Mike
How clean is that frame? I'm still thinking of building a rolling chassis while driving the truck. I just haven't found anything as clean as mine yet.
1936 chevy truck
1977 corvette
Old 10-20-2016, 03:33 PM   #63
Mr Banshee
its a Michigan frame, would need to be blasted and evaluated. Here is an attached picture i have. Not the best but to give you an idea.
Mike
Old 12-07-2016, 01:27 PM   #64
jondancer
madtrucker pm sent
