04-26-2015, 07:44 AM | #51 |
Re: 56 step side on 07 trailblazer chassis
Very impressive!
http://67-72chevytrucks.com/vboard/s...d.php?t=414646 |
04-26-2015, 09:10 AM | #52 |
Nice progress.
Looking real nice. Kim |
04-26-2015, 12:22 PM | #53 |
Thats looks awesome, love the wheels.
05-03-2015, 08:35 PM | #54 |
thanks!! so now is for sale here in Vancouver BC im asking 25k cad or 20k usd or best offer here are the truck details:
A daily driver 1956 chevy on 2007 trailblazer power train streetrod with patina style 4.2 liters in-line 6 front engine with 93 mm bore, 102 mm stroke, 10.3 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder LL8, 300HP/300LBFT at 6000RPM Unleaded fuel 87 Fuel consumption: (mpg): 16, country/highway (mpg): 22 and combined (mpg): 18 Multi-point injection fuel system 22 gallon main unleaded fuel tank 4x4,4x4 automatic,hi/low Four-wheel ABS 3.42:1 axle ratio Four disc brakes including four ventilated discs Electronic traction control via ABS & engine management Immobilizer Spacesaver steel rim under body spare wheel Stability control Wishbone front suspension independent with stabilizer bar and coil springs , beam rear suspension rigid with stabilizer bar and coil springs Day time running lights HD towing package 5 speed wiper cruise control digital cluster original heater with controls working original switches control 225/45/17 on custom rims 3 power outlet 3-point seat belts ONSTAR Online information system,vehicle tracking,free hands power windows with cranck switch bose audio satellite radio original headlight and tailights ,automatic control (turn on when is in drive and night time) 5" touchscreen in the mirror ANDROID 4.4 ,gps 3D, wifi ,front and rear camera recorder,music speedometer |
05-03-2015, 08:36 PM | #55 |
more pics
05-03-2015, 11:08 PM | #56 |
Looks real nice.
Kim |
05-06-2015, 01:50 AM | #57 |
05-06-2015, 12:20 PM | #58 |
Damn that was fast. I started mine two years ago and it's maybe half done.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and 47RH AOD transmission http://67-72chevytrucks.com/vboard/s...d.php?t=640042 |
05-20-2015, 01:17 AM | #59 |
wow, lots of work in a short time. just curious if those tirese rub. did you reprogram the ecm for the different tire size? how do they affect cruising speed, does it bring the rpm up a bunch at 110 kph?
your truck looks good. lots of cool ideas that you thought of yourself, nice to see that instead of copycat someone else's ideas. |
05-20-2015, 04:55 PM | #60 | |
09-11-2015, 01:41 AM | #61 |
hey rusty, just curious if you sold your truck. also, if you don't mind me asking, what did you do for inner fenders under the hood and what did you end up with for rad clearance? i would like to put a/c in mine but so far just dreaming and no hands on yet. too may other projects still. hopefullu will get back to the truck in the next month or two. I have a gmc envoy donor waiting for the teardown.
09-11-2015, 06:51 PM | #62 | |
Hey man, yes i sold it like 3 months ago and after that i move back to my country with my wife,kids and my 81 pontiac firebird 467. i use the originals 56 inner fenders, i just cut around the TB suspension. with this chassis and engine i has no room, i had to cut the fan 1 inch and that leave me 1 inch between the fan clutch and the rad ,so is not room for nothing there |
09-11-2015, 09:42 PM | #63 |
Hey thanks for the reply. Good to see you made it back home again hopefully it was god while you were here. Good luck with the pontiac, they were/are great cars.
09-11-2015, 10:18 PM | #64 |
Great job! Those wheels with the center caps were an awesome idea.
Jeff
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
09-12-2015, 06:48 PM | #65 |
love it! this may be my next project after my next project, only with a colorado as the donor. what great attention to detail!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
09-14-2015, 09:41 AM | #66 |
Really cool truck
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
02-02-2016, 08:09 AM | #67 |
Man, that was fast. Sorry to see you sold it! Turned out great.
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
