Old 05-19-2015, 02:25 PM   #51
Coldshot
Coldshot's Avatar
Re: One mixed up 51'
Thanks, yea should throw people for a bit of a loop. I'm gonna try making my own cover when the time comes. Keep the secret best I can except at shows.
Once I get more steel I'll start on the front and this thing should be upside down for final weld up in no time
Coldshot is offline   Reply With Quote
Old 05-19-2015, 03:04 PM   #52
Coach529
Coach529's Avatar
Interesting build.......
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 06-16-2015, 11:38 PM   #53
Coldshot
Coldshot's Avatar
Haven't had much time but I got the other strut tower cut out for the strut top.
Now that those are tacked up I'm starting on the fronts.
So far so good I think. Will of course add support to the inside.
Old 06-17-2015, 06:55 PM   #54
lower50's
lower50's's Avatar
Nice!! Make sure you leave motor access.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 06-17-2015, 07:52 PM   #55
Coldshot
Coldshot's Avatar
I'm trying to mimic the supra struts in a way the best I can. I know my motor will fit in one of those. I'm also pushing the motor as far back as I can so that should help with clearence I hope.
Old 06-21-2015, 10:02 PM   #56
Coldshot
Coldshot's Avatar
Went to the fathers days car show this weekend and surprisingly I only saw 1 s10 and only gmc versions of mine!
Didn't get a pic of the dime but did of the 3 gmc's
Also my dads rarity
Old 06-26-2015, 11:29 AM   #57
Coldshot
Coldshot's Avatar
Thanks, might put the project on hold for a little bit. Thinking of finally doing the upgrade my shop space so desperatly needs.
My counter space currently consists of a foosball table with patio bar peace's on top and a plastic collapsible table.
So I think it's time to finally do it so I can bolt down some tools like a vice and a brake I'm looking at
So looking at maybe a week to get it done and re organized.
Old 07-05-2015, 05:52 PM   #58
Coldshot
Coldshot's Avatar
Pretty much done the new benches. Done on the cheap but heaps better then what I was using before.
BEFORE:
CLEANED:
Constructing:
DONE:
Still gotta put everything back, buy a vice to bolt down and got my eyes on a 30" brake as well.
Back onto the truck
Old 07-30-2015, 09:35 AM   #59
Coldshot
Coldshot's Avatar
It's been a bit since I've updated this but things have been busy and the garage Is still not cleaned out. But as I have been walking past the truck and looking over what I've done I have come up with maybe a different, maybe better way to attack this suspension.
What I've done so far is only tacked together and looks pretty industrial (strong at least) but it's a pain to get it just right with the lack of "shop" I have.
So the thought I have is to get a donor supra and graft the front clip, witch does have frame rails I can connect to, so the suspension can line up and bolt up a lot easier. Also cutting out the rear floor with strut towers and moulding that on to the back.
This is just a thought that's gone threw my mind and thought I'd throw it out here and see what everyone thinks?
Should get the garage done this weekend so things will move forward soon.
Old 08-23-2015, 09:39 PM   #60
Coldshot
Coldshot's Avatar
Been a wile since I have had time for the truck but I finally did something today!
I've redisigned the towers a bit.
Using 6" pipe and 3/16 plate I've put them together.
I still need to get the cab back off, but going to make a dolly for it first.
Once it's off I'll be able to measure better to get everything perfect.
Here's the new strut tower tops I made today.
Considering these will be seen in the bed, these should look much better.
Old 08-24-2015, 07:36 AM   #61
lower50's
lower50's's Avatar
Great job. I agree they will look better. I see you have random Canadian tire money floating around your shop as well LOL. It must be a normal thing.
1951 MG TD
Old 08-24-2015, 12:17 PM   #62
Coldshot
Coldshot's Avatar
Thanks, finally got some better tools to make better stuff.
As for the canadian tire money, you should see my jar lol.
Old 09-05-2015, 06:00 PM   #63
Coldshot
Coldshot's Avatar
Install on the new tops went ok. Had to take them apart and back together to get them to fit right.
Bit more time on these to close them up then I might try setting the back on wheels.
Old 09-13-2015, 11:25 PM   #64
Coldshot
Coldshot's Avatar
Started on the front towers today. Only got a little done cuz I had a lot of cleaning to do in there.
Will be taking the cab off next.
Here's is where I've stopped on the rears for now.
Here is the little I've done on the fronts.
Just cut out the peace's to check fitment.
After taking off the k member and looking at what's left of the frame I've desided to add a little more structure.
That's as far as I got before I ran out of time. Taking the cab off next to get the fronts done.
Wish me luck
Old 09-14-2015, 08:14 AM   #65
lower50's
lower50's's Avatar
Good Luck!! Stronger frame is always better. Makes you feel better going down the rd.
1951 MG TD
Old 09-15-2015, 06:31 AM   #66
BC Toy chest
BC Toy chest's Avatar
Nice work, keep the photos coming.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 09-17-2015, 11:19 PM   #67
Coldshot
Coldshot's Avatar
Getting an hour here and there to work on the truck.
Had time to the front frame bits into shape and tack them in.
It should do the trick once the holes are filled. Couldn't go wider or I might have header clearence problems down the road.
Old 09-20-2015, 10:05 PM   #68
Coldshot
Coldshot's Avatar
Almost got the front frame bits done.
And started finishing off the rear towers.
Should have those done next big of time I get on it.
Old 09-21-2015, 08:37 PM   #69
Coldshot
Coldshot's Avatar
Well I pretty much finished the back towrrs today. But then I ran out of wire
Still lots of grinding to do tho, and a few gussets for final strength.
Now I really need to make that cab dolly damn it! I keep procrastinating on that.
Old 09-21-2015, 10:58 PM   #70
lower50's
lower50's's Avatar
They look good and strong. Good job.
1951 MG TD
Old 09-21-2015, 11:55 PM   #71
Coldshot
Coldshot's Avatar
Thanks, now just gotta get the fronts going. I'm getting really antsy to see this thing on 4 wheels
Old 11-09-2015, 12:15 AM   #72
Coldshot
Coldshot's Avatar
Well it's been a wile but life has slowed down enuf to let me get back onto the project.
Started the front strut towers today.
Gonna brace them with 1.5" square tubing and 1/8 plate.
I've also finally got a transmission yesterday!
But it's not a t56, after it seems like endless searching I found another trans that works behind the lsx. Found it in a review of a lsx swapped 300zx putting 450+hp at the tire with its stock 5 speed trans. There's a company that makes an adapter kit for it called LOJ. Kit goes for about 1k and I picked up the Z32 TT trans yesterday for $200 with low kms.
Only down sides to the trans are the shifter position is pretty far back so I'm gonna come up with some kind of relocating exposed linkage. The weak point in the trans in the syncro's but in 98 they fixed them so if I rebuild it with the 98's syncro's it's good to go.
So just incase this wasn't already an oddball mash of parts here's a few more lol.
I also grabbed a gage cluster in hopes of splicing it in as well from a 300zx.
Might try either re configuring or just making a sleeve to put it in as is?
Well I should have more material this week and maybe order my rims as well.
Old 11-17-2015, 02:09 PM   #73
Coldshot
Coldshot's Avatar
Things move slowly again.
Got some steel to finish the towers and to start on mounting the bed.
They shorted me 2 lengths but I should get them tomorrow or today.
Got a bit done on the towers but covered it with all the body to make space for a guys night in the garage so no pics yet.
Yesterday tho I did start on making the front of the bed as I plan to bolt the cab to the bed.
The peace's I got shorted are the ones for the X brace to be done. Pretty much done that just need the bracing and put a few more threads on the side to bolt te box together.
Old 11-17-2015, 04:18 PM   #74
ptc
ptc's Avatar
Thats alot of steel on the back end of the SUPRA suspension.... Is this still gonna be a 1/2 ton truck??? j/k - looking good!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 11-17-2015, 05:48 PM   #75
Coldshot
Coldshot's Avatar
I hear yea, but funny enuf that year supra weighs in at almost the same as the trucks.
