Old 05-21-2015, 02:09 PM   #51
Joe Pass
Joe Pass's Avatar
Re: 62 Front SwayBar Installation
A follow up on the torsion bar keys and how I raised them almost 1"
I had a chance to takes some pictures of how I gained some ground clearance.... so here's some pictures.
The bushing was sourced from center axle on some throw away castor. A friend sourced his at the local bearing supply in bronze under $10. The picture shows the dimensions with my example. You will also see the skid plate I attached to the X pipe out of 1/4" plate to help protect every thing a little further.
As you can see there is a speed bump that hates me in my driveway, but the keys haven't scraped
Joe Pass is offline   Reply With Quote
Old 05-21-2015, 02:29 PM   #52
slepysal
slepysal's Avatar
Just outstanding thanks
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-21-2015, 02:43 PM   #53
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
So you removed the piece in the 2nd picture to get it higher off the ground.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-21-2015, 04:13 PM   #54
doobiebro
doobiebro's Avatar
Originally Posted by Joe Pass View Post
Well there is one thing I did to gain ground clearance is I eliminated the spacer under the head of the torsion key bolt. That allowed T-bolt to settle almost an inch higher in the torsion key saddles. The only pictures I have are from my build that show it before the removal, but you might get the idea. If you look at the bolt in the pictures there are 2 square blocks under each bolt. I then removed the one directly under the bolt head. The second block has a larger inner hole so I used some thin wall bushing material to reduce the slop and reinstalled it. I turned both bolts gradually until the lower arms were level and since readjusted them up a little bit after it settled. I wish I took some photos but I was at a friends alignment shop and did this a the fly. That area is my lowest point and sits 4.5" above the level ground. So far I scraped twice on the X pipe but the bolts /keys cleared any harm.
Attachment 1399924
Attachment 1399925
Attachment 1399926
Attachment 1399927
Very nice under belly.. My 60 torsion bar bolt heads measure 4" to level ground. Your truck stance looks similar to mine. I have 2 1/2" dropped spindles and I cranked the torsion bar bolts up front and at the rear 4" drop coil springs. I also ran both exhaust pipes in between the torsion bars just like your pic on the x pipe. My 1st truck was a 62 and now I have a 60. Thanx for the write up... Man I love your truck
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 05-21-2015, 04:15 PM   #55
Joe Pass
Joe Pass's Avatar
Correct....Joe
Old 05-21-2015, 04:18 PM   #56
Joe Pass
Joe Pass's Avatar
Thanks, Love to see how you did your exhaust also
Old 05-22-2015, 11:05 PM   #57
par4tom
Your truck looks awesome!!!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 05-22-2015, 11:27 PM   #58
Joe Pass
Joe Pass's Avatar
Thank You....I'm honored.
Old 06-05-2015, 12:57 PM   #59
verdell
verdell's Avatar
Hey Joe and Doobie,
what shocks are you guys running front and rear?
verdell is offline   Reply With Quote
Old 06-05-2015, 02:13 PM   #60
OldChevy61
OldChevy61's Avatar
Joe Pass, was there any spark plug issues with those headers. Looking at the pics,looks like they drop in front of the bell housing. I'm running a factory bell with hydraulic clutch on passenger side. Do you have a pic of the pass side by chance? Awesome looking work there by the way.
OldChevy61 is offline   Reply With Quote
Old 06-05-2015, 04:33 PM   #61
The Rocknrod
Moderator
The Rocknrod's Avatar
Very, very nice job Joe!
Old 06-05-2015, 05:08 PM   #62
Joe Pass
Joe Pass's Avatar
Originally Posted by verdell View Post
Hey Joe and Doobie,
My shocks are Bilstien's right from CPP The front are standard length application and the rear accommodate a 5" drop spring
Old 06-05-2015, 05:08 PM   #63
Joe Pass
Joe Pass's Avatar
Thank you
Old 06-05-2015, 05:18 PM   #64
Joe Pass
Joe Pass's Avatar
No spark plug issues..
Here's the pictures I have, hope you can see enough....just so you know I'm an automatic and relocated the trans mount to the back. I trimmed flush the bell housing crossmember/mount which opened up a straight shot back.
Joe
Old 06-05-2015, 05:20 PM   #65
doobiebro
doobiebro's Avatar
Hey Joe and Doobie,
same exact thing said by Joe Pass except my rear is 4'' drop spring
Old 06-05-2015, 07:42 PM   #66
61_FL_Apache
Who Me?
Heck with the sway-bar! Look at that exhaust system!! Sweet
Steve
2001 Blazer 4D 2WD
Old 06-05-2015, 10:56 PM   #67
Joe Pass
Joe Pass's Avatar
Thanks....
Old 06-06-2015, 12:51 AM   #68
Captainfab
60-66 Nut
With a manual trans and the original bellhousing crossmember in place, you will not be able to run any of the car headers. IMO your best bet is the Hedman #69260 headers. They are listed to fit '55-'65 trucks. No spark plug issues. In fact these will work with angle plug heads.
Old 06-06-2015, 07:14 AM   #69
The Rocknrod
Moderator
A bit pricey for some, however these would give your X-pipe some clearance:
http://www.spintechmufflers.com/x-pi...s/cat_126.html
Old 06-06-2015, 11:16 PM   #70
bosephus
bosephus's Avatar
Hate to beat the exhaust questions to death but there isn't much information on header application for trucks retaining the torsion bars. Are your headers the Patriot clipsters in the link or are they Hedman 68608 that I seen in an earlier post? That system is awesome! Thanks,bo
bosephus is offline   Reply With Quote
Old 06-06-2015, 11:22 PM   #71
Joe Pass
Joe Pass's Avatar
I'm using the Hedman...Answering the question I just wanted to show the link to a style I was using...sorry for any confusion
Joe
Old 06-06-2015, 11:41 PM   #72
bosephus
bosephus's Avatar
Thanks for the info Joe! Beautiful job on the truck.
Old 06-07-2015, 12:13 AM   #73
Joe Pass
Joe Pass's Avatar
Thanks...
Old 06-12-2015, 01:07 PM   #74
par4tom
Hey Joe,
I got my sway bar installed and finally getting a chance to run around with it a little bit. I had to replace a brand-new motor with another after the guy at the exhaust place wiped out the cam revving it up!!! (He wouldn't take ownership of it though)
The ride difference on this with the sway bar is remarkable. Much more stable and much less vehicle sway!
Anyway, I am getting a bit of rubbing of the right front tire on the side of the sway bar. I have the old tires on there that have quite a bit of bulge until I can get the axels swapped out and converted over to 5 lug.
Did you have any rubbing issues?
Also, what kind/size of wheel are you running and do you remember the offset?
Tom
My Build Thread
Old 06-12-2015, 01:49 PM   #75
Joe Pass
Joe Pass's Avatar
Hey Joe,
Tom
That's sad about the motor....I tend to disable the ignition when I have to entrust someone's help on my trucks in case I'm not there to watch. Never had much issues myself but I worked at a differential repair shop and the shop owner's test drives consisted of personal errands and to pickup his lunch with a customer's car...
Anyway I haven't had a rubbing issue on the swaybar...I run 15x7" front wheel with a 3.5" backspace. The tire is a 225/65/15 and its a BF Goodrich "G" force tire with a stiff sidewall to also help with its handling.
