Old 02-25-2018, 08:27 PM   #51
LowCST
Originally Posted by hewittca View Post
I am running these on my '68 with a 4/7 drop. First of all you have to have the centers of the wheels bored to fit over the hubs on the 4 wheel drums. For the fronts, I am running 265/35s and have not had to do any clearancing (stock fenders and inners). I have not bottomed out or rubbed at all, but if I were to go any lower (which I plan to) I will have to do some modifications for clearance. In the rear, you can't run the stock transit because it has too much backspacing. You can either run a 1.25" to 1.5" adapter spacer like everyone above had to do, or flip the center of the wheel and change the backspacing. I changed the backspacing on mine to 4" but it did require a bit of clearancing to make it work. A more conservative backspacing would be 4.25", and with a 5" drop you should be fine and require no modifications.
Awesome man thanks for the reply that solves a lot of questions. Do you happen to remember what you had to bore the centers out to? Also do you recall what spacers (inner diameter) you had to run? I’ve seen some people mention having to run Toyota spacers due to the hub size issue? Just trying to buy all this stuff once and be right! Thanks again man very helpful. Truck looks awesome can’t wait for mine!
LowCST is offline   Reply With Quote
Old 02-26-2018, 09:07 AM   #52
LowCST
Originally Posted by Ghernandez66 View Post
I got 1" spacers on the truck in the picture I bought em of summit racing
part #TGI-14001-1-KIT they say they're for Toyota but the ones for Chevrolet the center bore is still to small for the drum to fit..
In my truck it won't clear the tubs and that's because of the height I wouldn't be able to go that low with them on also remember my truck is bagged ..
Part number no longer brings up a wheel spacer. Do you happen to remember what the size of the opening was for the spacer to fit the hubs?
Old 02-26-2018, 10:20 AM   #53
hewittca
hewittca's Avatar
Re: 22" Gm Transport wheels
I don't exactly remember. I want to say the stock hub is 4" and the guy I had do my wheels bored them slightly larger than that, maybe 4.1". I don't know for certain, but could measure it this evening if you want to know exactly. All I know is the wheel isn't hub centric anymore, as in, the wheel bore is slightly larger than the hub on the axle and the wheel is centered with the lugnuts. I had to get different lugnuts (these) since the transits are technically made for slightly larger studs. As for my spacers, I also had to bore those out to fit so I don't know what spacers would work without modification.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 02-26-2018, 11:21 AM   #54
LowCST
Yea that would’ be awesome if you have time to measure them. No rush man. So my plan would be this (tell me if I’m missing anything here)
1.) get all 4 wheel centers bored to clear the hubs
2.) run 1.25-1.5” spacers on the rears (either find ones that fit our hubs or get them bored as well) if I’m reading your instructions right I shouldn’t have to use spacers on the fronts.
3.) make sure the studs now are long enough to clear the new setup. I’m gonna look at what the other guys mentioned above and check out the Toyota style spacers that may fit.
I’m going to run a hubcentric spacer if at all possible for safety and stability reasons so if I find a solution that fits I’ll def let you know. Thanks again for the help man much appreciated
Old 02-26-2018, 12:04 PM   #55
hewittca
hewittca's Avatar
That looks mostly good to me. Some notes
1) Correct. Only exception here is if you plan to do a disk swap in the process of getting these wheels mounted. The rotors have a smaller hub and fit inside the transit center without boring them. If you are running all drums, then they all need to be bored.
2)Correct. No spacers on front needed. The rears are technically called adapters. There are no spacers that wide. Adapters bolt to your existing studs and then have their own studs that the wheel bolts to.
3)See 2). You won't need to replace the studs if you run adapters.
The only thing you didn't mention is getting the lugnuts I referenced above. I HIGHLY recommend getting those for the fronts. for the rears, you won't need them if you get adapters because those usually have the larger studs in them (and I think they come with lugnuts).
Old 02-26-2018, 12:34 PM   #56
LowCST
Excellent man. Exactly what I needed. Thanks again great to have people help each other on here
Old 02-26-2018, 12:41 PM   #57
The Rocknrod
Moderator
The Rocknrod's Avatar
You can also wash them with this soap. Not sure if "Wagon Train" makes soap, but this stuff gets em clean:
Old 02-26-2018, 08:14 PM   #58
rvrfoot
I may order some mob wheels for my 61 impala.
rvrfoot is offline   Reply With Quote
Old 02-26-2018, 09:44 PM   #59
hewittca
hewittca's Avatar
The center hub on the stock steel wheels specs out right at 3.5" and my bore on the transits is 3.7". There's definitely some room to tighten that up but I think you're going to have to be really sure you can get the bore centered. I can see on my wheels that the bore is ever so slightly off center, so it's a good thing the bore isn't centering the wheel on the hub because it would probably vibrate.
Old 02-26-2018, 10:38 PM   #60
rvrfoot
The lug nuts will need to line it up.
Old 02-28-2018, 12:29 AM   #61
Ehud
I have a 1998 Chevy that is a light duty 3/4 ton. I plan on using the engine, transmission and rear Axle in my 64. Will the transport wheels need to be bored for a 1998 6 lug rear end? I am also wondering what how close the width is on the 1998 rear end is vs the 1964.
Of coarse I can measure it but I am not to that point yet.
Ehud is offline   Reply With Quote
Old 03-07-2018, 12:05 AM   #62
Jrs01
I also have a 2003 Escalade will that rear end be too wide for my truck has anybody tried it yet? 1965 C10 Fleetside
Jrs01 is offline   Reply With Quote
Old 03-07-2018, 01:01 AM   #63
Captainfab
60-66 Nut
I'm pretty sure it will be 3-4" wider than your original differential.
Old 04-06-2018, 03:06 PM   #64
Conrad63
Conrad63's Avatar
I have them on my truck. Work awesome. I will post pics soon
I’m the starter of this thread
Conrad63 is offline   Reply With Quote
Old 05-05-2018, 11:01 PM   #65
Conrad63
Conrad63's Avatar
Cool Re: 22" Gm Transport wheels
Hi Everyone.
I got my 22" transports from kijiji from a guy in red deer
I used the hubcap clips from the guy on instagram. they were easy to put on
I used just regular "dog dish" hubcaps, baby moons, got them from a place in Edmonton on Calgary trail, just south of 63 Ave, hubcap king or something like that.
the 22s have been great.
I have a CPP 5-6 drop. no rubbing except hard bumps in the rear. I think the tires touch the inner wheel well. other than that its all great.
Old 05-05-2018, 11:06 PM   #66
Conrad63
Conrad63's Avatar
Originally Posted by Conrad63 View Post
Hi Everyone.
and all I did to fit them on the rear was a 1/2" spacer. I didn't have to bore the center out.
Old 05-05-2018, 11:07 PM   #67
Conrad63
Conrad63's Avatar
my CPP kit was the 6 bolt kit. BTW
Old 05-06-2018, 05:09 PM   #68
w00dst0ck
w00dst0ck's Avatar
1/2" spacer won't work without extending the lugs. There wouldn't be enough material and it would be really dangerous driving like that. Stock studs only have 3/4" material on the outside of the drum.
I've been selling them for about 4 years now.
w00dst0ck is offline   Reply With Quote
Old 05-06-2018, 09:28 PM   #69
rvrfoot
I have 1/4 inch on mine.Name:  DSCN0835.jpg
Old 05-06-2018, 09:28 PM   #70
rvrfoot
Oh yeah i have longer studs.
Old 05-06-2018, 10:52 PM   #71
w00dst0ck
w00dst0ck's Avatar
Right on. Unfortunately 1/4" isn't enough to clear the bed on a fleetside. I'm not sure about a stepside.
Old 07-16-2018, 06:03 AM   #72
Dwyert4
Quick question, I just picked up a set of transports. They came with 10.5" hubcaps and what I believe are old style very clips.is there a pattern available or pdf download so I can make sure I get them exact? I don't want to wobble.
Dwyert4 is offline   Reply With Quote
Old 08-21-2018, 10:03 PM   #73
SC1969c10
Are you in NC?
SC1969c10 is offline   Reply With Quote
Old 08-21-2018, 10:51 PM   #74
Blue666(2)
Can you PM me the price for a set or four? We can figure the shipping later.
Thanks,
Blue666(2) is offline   Reply With Quote
Old 01-23-2023, 06:26 PM   #75
BigE 63
New Member
Hey are you still sell the studs?
BigE 63 is offline   Reply With Quote
