Old 02-17-2016, 08:41 PM   #51
72MARIO
72MARIO's Avatar
Re: 1987 R20 Suburban LQ4 4L80E swap
Would it be possible to lift the engine and heat up the crossmember and massage some more clearance ? Is that area single or double thick ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-17-2016, 10:52 PM   #52
Nodnarb76
Nodnarb76's Avatar
Don't really want to pull it back out at this point. Pretty sure I can get in the and trim a little off with a cut off wheel, or sawzall. It's not the body of the crossmember that's close, only the lip comming off the crossmember.
I'll get back to work on everything on Monday, and can post another update.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 02-18-2016, 11:58 AM   #53
aggie91
I'm just glad to be here!
aggie91's Avatar
I would just trim the lip of that cross member with a cut off wheel or sawzall. Looks to close on that one corner. That lip is doubled up and spot welded together in that area, just don't get into the spot weld that you can see near that corner and you should be good.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-18-2016, 07:00 PM   #54
Cwarta
Cwarta's Avatar
Very nice, you will love it. My 80 was a stock 6.0/sm465 them a 6.0/4l80e/yank3600SS stall and now a 6.0/228r cam, 5.3 heads, and nv4500 with 1 tons. Love love love it. One of several swaps I have.
Cwarta is offline   Reply With Quote
Old 02-19-2016, 10:41 PM   #55
Nodnarb76
Nodnarb76's Avatar
Sounds like an absolute beast of a truck!
Old 02-20-2016, 12:10 AM   #56
Cwarta
Cwarta's Avatar
Not sure yet haha, just drove it for the first time today and the clutch is slipping horribly. Ugh lol
Old 02-22-2016, 10:10 PM   #57
Nodnarb76
Nodnarb76's Avatar
Update:
Today was one of those days that I got a lot done, but the pics don't look like I did much.
Today I got the shift linkage, gas pedal, ECU, TAC module, and a/c condenser Installed. Also re-connected the battery and I got power to the areas I want it, and was happy that everything else still works!
Old 02-22-2016, 10:12 PM   #58
Nodnarb76
Nodnarb76's Avatar
ECU mounted using the Dirty Dingo PCM mount.
Old 02-22-2016, 10:14 PM   #59
Nodnarb76
Nodnarb76's Avatar
Gas pedal mounted, wasn't as hard as I was expecting, but I had to move some stuff out of the way to make it fit.
Also had to cut a 2" hole in my firewall to get the plug through.
Old 02-22-2016, 10:18 PM   #60
Nodnarb76
Nodnarb76's Avatar
Also got the grille back in,
Looks like my truck again!
Old 02-22-2016, 11:49 PM   #61
MTCK
MTCK's Avatar
Good progress. You are busting out your list.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-01-2016, 10:23 AM   #62
Nodnarb76
Nodnarb76's Avatar
Got a lot more done yesterday.
Got my subframe trimmed, and the tabs cut off the transmission.
Also got all the wiring finished up, and the Dakota
Digital dash installed, my dashboard re-installed' Lokar shift linkage installed (still needs to be adjusted). Also got the hood back on.
Was able to turn the motor over (no fuel lines installed yet so not ready to start) and everything was good.
Going to send the truck down the street this week and get the driveshaft cut/installed and the exhaust installed. Going with Magnaflow mufflers and tips.
I'll post more pics of the dash once I get back to work today.
Here is a pic of my notched subframe.
Old 03-01-2016, 11:57 AM   #63
MTCK
MTCK's Avatar
Wow nice work. You are cranking this project out.
-Marcus
Project Plow Truck
Old 03-01-2016, 03:20 PM   #64
Nodnarb76
Nodnarb76's Avatar
Here is a pic of the Dakota Digital dash. Never mind the ck engine light, no O2 sensors or MAF sensor installed yet.
Old 03-01-2016, 11:36 PM   #65
COS399
COS399's Avatar
Looks good. Think you can peg the Speedometer at 160?
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 03-01-2016, 11:57 PM   #66
MTCK
MTCK's Avatar
That looks cool. Worth a shot on pegging the speedo!
-Marcus
Project Plow Truck
Old 03-02-2016, 01:27 PM   #67
Nodnarb76
Nodnarb76's Avatar
Well, today sent truck off to get the driveshaft cut/balanced and installed and the exhaust welded up.
When it's back just need to get fuel lines, and cooling system installed and should be ready for the first startup!
Old 03-02-2016, 11:13 PM   #68
Nodnarb76
Nodnarb76's Avatar
Oh yeah about the 160 mph thing from the previous posts.
May be able to hit 160 if I could find a completely vertical and long cliff face I could drive down full speed. Only problem I can think of trying that, would be the terrible aerodynamics of a square body suburban may not let me go that fast.
Old 03-09-2016, 04:54 PM   #69
jmack91z28
jmack91z28's Avatar
This is such an awesome thread, you've knocked a lot of this out in a very timely manner. Proud of you man, can't wait for this to get finished. I was worried at first about the Dakota Digital Gauges but those look very nice.
Keep it up.
1961 C60 Viking 8' Dump 261 SM420 2-Speed Rear
1966 C10 Fleetside 350 W/ Saginaw 4 speed
1985 K10 Chevy 6.2 diesel 700r4 longbed
2001 Dodge 3500 Dually 24v NV5600 4x4
USMC Reserves
Jason
jmack91z28 is offline   Reply With Quote
Old 03-09-2016, 06:27 PM   #70
Nodnarb76
Nodnarb76's Avatar
Thank you for the kind words! I am very happy with the gauges also turned out better than I had hoped. Plus found out I can have the illumination turned on during daytime driving and then dim them for night driving. I wasn't sure I would like the white needles on white numbers at first, but now that the needles will be red whenever the truck is running I like a lot better!
Truck is still getting driveshaft and exhaust work done, hopefully be back early next week, then it will be a few more things to hook up and I get to start it!
Old 03-10-2016, 09:32 AM   #71
jmack91z28
jmack91z28's Avatar
You should look into the PAC-1300 add on controller. Fades the interior lights off when the door closes, keeps the lights and radio on after the truck turns off for a user determined time. That would be really cool. Adds a nice modern touch.
USMC Reserves
Jason
Old 03-15-2016, 01:30 PM   #72
Nodnarb76
Nodnarb76's Avatar
Update:
Just got off the phone with the shop doing my driveshaft and exhaust. They have been backed up and busy and the truck has been sitting for a week waiting to go into the shop (I work for a car dealership and this happens to us sometimes). When fixing cars there are 3 ways to fix a car: 1. cheap 2. right
3.fast. You can always have two out of the three, never 3 out of 3. I chose the shop that was 1 and 2, cheap and right but not fast. They got it in last Friday and looked at it. I told them to go ahead and replace all the u-joints and the center bearing on the driveshaft while they had it. They now have everything ready to go back in and hopefully get the exhaust done later this week too. Instead of having it towed back up to my work, think I'm going to tow it to my house so I can work on it on my time and get more done. Now that I don't have any more heavy lifting that needs to be done this makes sense. Will keep everyone posted, didn't want people to think something went south with the build and I stopped posting.
Old 03-15-2016, 01:55 PM   #73
Blessed66
Blessed66's Avatar
When fixing cars there are 3 ways to fix a car: 1. cheap 2. right 3. fast.
My Hyundai tech (I saw you mention working at a Hyundai dealer, earlier in the thread) used to tell me something similar.
"They can have their car right, or have it right now."
Current Projects:
1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion
1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently.
Blessed66 is offline   Reply With Quote
Old 03-15-2016, 08:03 PM   #74
SBTork
Garage wrench
SBTork's Avatar
Maybe swap the oil pan with a shorter one?
I used the dirty dingo sliders on my '85 Suburban and used the "Hot rod" oil pan kit that GM/Chevy Performance makes. It worked really well!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 03-22-2016, 11:57 PM   #75
Nodnarb76
Nodnarb76's Avatar
Got a call that my exhaust is getting wrapped up and may have the truck back later in the week! Enytopy sent my 28" core radiator and I got it in today also.
My cat is guarding it for me until the Suburban is back.
