#51 |
Re: Zippys 50'
More Pics
Mounted the fuse box to finalize where the wires will be routed for final assembly. Made a couple of aluminum panels to facilitate install as well. |
#52 | |
![]() Join Date: Jul 2012
Re: Zippys 50'
#53 |
Re: Zippys 50'
Thank you Doug!
It seems as if with todays technology it would be so simple - a video link, a color PDF with real photos - to help with instructions anyway. The fitment issues I really don't have any suggestions for that - I just know it certainly could be better. Mike |
#54 |
Re: Zippys 50'
Hi Guys
Wondering if I could get some guidance... We put a 700r4 trans in Jakes truck. I need to put an external lock up kit in it. I bought the american auto wire kit. Thought all was good - it needs to thread into the high pressure port on the passenger side of the trans. Guess what... no port. AAW says we need to use a different kit and they can't help. Any ideas? Thanks, Mike |
#55 |
Re: Zippys 50'
Mike,
While it might be possible to modify the kit you have so it will work, I am not familiar enough with them to help....other than a bit of research I did. Monster transmission lock up kit ordering selection drop down asks if there is an external pressure port or not. Guessing they send different components based on that. http://www.monstertransmission.com/7...l#.VxwztPpHarU Bowler Transmission has a lock up module that engages TCC 8 seconds after 4th gear applies and allows for brake disengagement of TCC. While I don't know if that might help in your situation, those would be nice features to have.http://bowlertransmissions.com/p/103...control-module Bowler is about 20 miles from me and last I checked in with them they really know transmission. |
#56 |
Re: Zippys 50'
Doug,
Thank you so much! I did a bit of research too - and some people have said to use my kit and tap the servo cover in the middle which would require removing it. I have the taps and drills to do so - just don't know if that is the way to go. I will read the links you sent today. Thanks Again Mike |
#57 |
Re: Zippys 50'
truck is looking good
do you have oil in it why not just use the lock up wiring that is on the valve body Jim |
#58 |
Re: Zippys 50'
Thanks Jim
There is enough oil in it but not full - the lock up wiring in the valve body need stop be controlled and I was looking for the simplest way for my son. I may have found a kit from bowtie overdrives. Still looking for ideas, Thanks Mike |
#59 |
Re: Zippys 50'
Hi
are you looking for some way to control l/u when you stop I was asking about the oil only because if you didn't have oil in it yet you could show me the lock up wire and pressure switch set up in your tranny 700 tranny's has many configurations for l/u Gm uses a 2 part brake switch 1-when pressed turns brake lights on 2nd half turns power off to lock up in tranny I think I have the book for the 700 with the different set ups for l/u if you want them I will look for it and scan and send them to you Jim |
#60 |
Re: Zippys 50'
Hello!
It's been a while, but Jacob and I have not stopped working on his truck. I will post pictures soon. We were stuck in paint shop hold for a long while, I built a little fun truck in the middle, and senior year of high school and now off to college sure limits his time to work on it. The good news is it close - real close. The bed is at the painter and the last thing we need, it is set to go for the interior the beginning of March. Mike |
#61 |
Re: Zippys 50'
Is that a glide engineering seat frame? Saw there booth at the GNRS last weekend, they look look nice in person. Just seeing if you have any input on them.
#62 |
Re: Zippys 50'
It is a Glide Seat. They are very nice. We got the foam kit at the same time.
Here are some pics I have no idea how to get them rotated? They are correct on my computer. |
#63 |
![]() Join Date: May 2007
Re: Zippys 50'
looking good!
for why you r pictures are rotated, most photo editing programs automatically rotate photos to display correctly on a computer screen, but the image info still recognizes the camera settings when the picture was taken. if you have ever uploaded pictures top craigslist or ebay you have seen what I am talking about, a sideways picture will automatically correct to be right side up. anyway, to fix it, either fix it in your camera when taking the picture (there is a camera icon on most phones that shows you the orientation of the picture, if the icon is sideways the picture will be sideways) or fix it on your computer by using the FILE-->EXPORT command to export the picture from the image program to a raw jpg on your desktop. when you open the picture from your desktop you will see it is sideways and most image editors have a rotate command the easiest way though is to just pay attention to the icon on your camera, if its sideways, your picture will be sideways. shake the phone a bit and it will eventually rotate, and your picture will be right
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#64 | |
![]() Join Date: Sep 2016
Re: Zippys 50'
Edit: Should have read the full thread first sorry. Great metal work throughout! I like the pictures showing how the clamps work. Dan Carpenters: http://dancarpenters.com/tubb.html $310 for two tubs. Not bad at all. Good instructions in there like you said.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride Last edited by gigamanx; 02-02-2018 at 10:40 PM. |
#65 |
Re: Zippys 50'
Thanks for the comments and help.
Here are some pictures from fitting up the front sheet metal and cab, prior to paint. We just about gave up trying to get the gaps right. Days of time but they came out pretty good for our first time ever. |
#66 |
Re: Zippys 50'
woop woop! looks right side up and awesome
#67 |
![]() Join Date: Mar 2011
Re: Zippys 50'
Looks like nice gaps to me...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#68 |
Re: Zippys 50'
Thank you.
Its been a real learning experience so far. Here some more pictures - we fit up the grill, bumper and splash shield. Thats Jake in the truck just for a smile and it getting sent back the body shop. |
#69 |
Re: Zippys 50'
More pictures - bodywork with the front sheet metal on before we took it apart... again.
#70 |
Re: Zippys 50'
Looking really good, awesome work on fitting the sheet metal right! Appreciate the updates.
#71 |
Re: Zippys 50'
Thanks Doug
Right after these pictures, we took the entire front clip apart again for final painting. I don't remember where I heard it or read it, but we drilled 1/8" locator pin holes on every item prior to unbolting. What a fantastic tip. Mike |
#72 |
Re: Zippys 50'
After we broke it down, final bodywork and primer on the cab and doors.
Ordered circle racing smoothies and got the tires mounted up as well. |
#73 |
Re: Zippys 50'
And finally - Color! In the side view the door needs a little adjustment yet
#74 |
Re: Zippys 50'
I'm loving the look of those wheels!
#75 |
Re: Zippys 50'
Thanks 84 Blaze - they will be painted body color on the brushed portion.
Here are the pics after we got the cab and front sheet metal back on. Go figure... it only took three hours to get everything back on - first time because we drill the locating pin holes. Not happy with the grill above the drivers turn signal - it seems to be going uphill a bit. |
