Old 09-30-2016, 08:45 AM   #51
Bennett68C10
Bennett68C10's Avatar
Re: 71 C10 6.0 LS ground up build
Originally Posted by Jason7121 View Post
Went ahead and bought some 20×8 20×10 torque thrust wheels and mounted some 295 40 20 in rear and 245 45 20 up front. Gave the truck a different look.
Nice looking wheels and tires I have the same exact setup on mine Can never go wrong with TTII's.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-30-2016, 09:53 AM   #52
Jason7121
Jason7121's Avatar
I may need wheel spacers in rear they almost touch on the inside
Jason7121 is offline   Reply With Quote
Old 10-01-2016, 02:07 AM   #53
'68 Newtricks
'68 Newtricks's Avatar
What are the old rims and size? What are your plans with them?
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 10-01-2016, 02:53 AM   #54
lowrodderchev
lowrodderchev's Avatar
There for sale
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 10-01-2016, 09:47 PM   #55
Jason7121
Jason7121's Avatar
Yes would like to sell the set I took off.
Old 10-02-2016, 12:11 PM   #56
NewType72
NewType72's Avatar
Wheels look awesome brother! Great choice
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 10-02-2016, 06:38 PM   #57
Jason7121
Jason7121's Avatar
Thanks everyone for all the kind words. Got alittle more done this afternoon. I'll post some pics soon.
Old 10-02-2016, 10:17 PM   #58
jeh
jeh's Avatar
Looks great with new wheels!!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 10-04-2016, 08:38 AM   #59
crazycrew
Awesome progress!!
Brooks -- South Louisiana
2004 Tahoe, DD
Currently on the prowl for that right C10 project
https://www.facebook.com/brooks.landry.1
IG : brolandry
crazycrew is offline   Reply With Quote
Old 10-04-2016, 09:02 AM   #60
skyjgmc
Sub'd like where your headed with this.
skyjgmc is offline   Reply With Quote
Old 10-11-2016, 03:36 PM   #61
Jason7121
Jason7121's Avatar
Had some time yesterday so I disassembled front sheet metal. Taking it to have it dustless blasted to remove all the surface rust. Also drilled holes for fender emblems.
Old 10-11-2016, 11:30 PM   #62
hotrodsinner
hotrodsinner's Avatar
Good looking c10!! You don't waste no time.
hotrodsinner is offline   Reply With Quote
Old 10-12-2016, 02:09 AM   #63
Caraudiotekk
Caraudiotekk's Avatar
Sweet build!
Can you show some pictures of your steam vent tap in to your water pump? Doing the same build on my 68.
Where did you get the mount/holder for your Ecm?
Awesome job!
Caraudiotekk is offline   Reply With Quote
Old 10-12-2016, 09:42 AM   #64
Jason7121
Jason7121's Avatar
Got the ecm mount on ebay from a company called psi. Steam port was drilled and tapped into front of water pump on a flat spot. I'll try and take a picture this evening for you.
Old 10-12-2016, 10:10 AM   #65
Caraudiotekk
On another note, my heads had the back steam vents blocked when I bought it. Now, I had already bought a Trick Flow kit that pipes all 4. Do you know if it's necessary to plumb all 4, or does it matter? No one can answer that question in my circles...
Thanks again
Old 11-11-2016, 01:18 AM   #66
Jason7121
Jason7121's Avatar
Getting ready for paint next month. I bought a new cowl hood and fenders. Started taking off all the old under coating from bottom of cab.
Old 11-20-2016, 11:47 AM   #67
Jason7121
Jason7121's Avatar
Got bottom of cab and also bed sprayed with bedliner. Installed cruise lever and switch to the column.
Old 11-20-2016, 12:02 PM   #68
lowrodderchev
Who sprayed it?
Old 11-20-2016, 01:13 PM   #69
lolife99
67-72 parts collector,…
lolife99's Avatar
Great build thread!
Can't believe I didn't see it before now.
Keith
Convert to disc brakes.
Old 11-20-2016, 07:13 PM   #70
Jason7121
Jason7121's Avatar
Thanks guys. My buddy and I sprayed it in my driveway.
Old 11-21-2016, 10:09 PM   #71
jeh
jeh's Avatar
Some good work gone on here!!!!!
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 11-21-2016, 11:18 PM   #72
Jason7121
Jason7121's Avatar
Thanks Jeh it's headed off to paint in a few weeks so trying to get all the details figured out.
Old 12-02-2016, 08:53 PM   #73
Jason7121
Jason7121's Avatar
Got firewall holes welded up and started to block off fresh air vents. Got everything loaded up and to the painter today. Also drilled and tapped holed for courtesy light switches in door jambs.
Old 12-03-2016, 04:22 AM   #74
lowrodderchev
Looks good bro great job
Old 12-03-2016, 11:56 PM   #75
Jason7121
Jason7121's Avatar
Thanks for the compliments!
