04-09-2018, 04:28 AM | #51 |
Re: Mike D's 50 pickup build
Silverfox
That Norton is slick!!! The frame is wow!!! Did you do the interior frame bracing yourself? Are the Shockwaves up front upside down? I'm defiantly following this build. Keep on keepin on Thanks NC
Been there, wrecked that |
04-09-2018, 08:47 AM | #52 |
Thanks, I restored the Norton 4 years ago from parts boxes, everything is original Norton parts excepts for signal lights. Frame bracing was done by Lloyd Dyck. I did the sheet metal and everything else. As far as I know, the only way to mount the front shockwaves on the TCI Custom IFS is upside down. Unless I am mistaken.
Got a lokar floor throttle pedal coming and 16" bench seat shifter.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003 Last edited by Thesilverfox; 04-09-2018 at 10:36 AM. |
04-16-2018, 10:30 AM | #53 |
This weekends accomplishments,
Got brake pedal/MS installed and trying out some ideas for the air lift position sensors.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003 |
04-16-2018, 11:28 AM | #54 |
maybe wanna put the air leveling valve link in the middle hole so you have more future considerations.
looks good. |
04-16-2018, 11:47 AM | #55 | |
Let me know. https://www.americanmuscle.com/airli...u-install.html
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003 Last edited by Thesilverfox; 04-16-2018 at 01:47 PM. |
04-22-2018, 10:53 AM | #56 |
Lots of progress this week. Got air compressor brackets mounted, installed park brake lever, Holley oil pan, headers, push rods, torqued all engine components, replaced trans filter ,pan gasket and output shaft seal. Got my tires 305 20 rear, 235 18 fronts, wheels should be here in a couple of weeks.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003 Last edited by Thesilverfox; 04-23-2018 at 09:04 AM. |
04-22-2018, 11:57 PM | #57 |
Looking good. Which parking brake kit is that? I like the look of it.
04-23-2018, 08:58 AM | #58 | |
http://lokar.com/catalog/#page=33
04-24-2018, 12:50 AM | #59 |
Thanks for the link. Didnt realize it was Lokar, havent looked at there catalog in years. Will add it to the saved websites to periodically check.
04-26-2018, 10:51 AM | #60 |
Will be shielding the compressors from tires when I install the tubs. Wire harness routing also figured out. Could not install compressors inside frame since fuel tank is too wide. Challenging to fit all this stuff while mainting stock box depth.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003 Last edited by Thesilverfox; 04-26-2018 at 10:59 AM. |
05-07-2018, 11:59 AM | #61 |
Lots going on this week.
Got the wheels installed and made the transmission tunnel. Found a sweet barn/garage find matching numbers1969 Firebird 400 with Trans Am rally instrument cluster. In storage since 1982.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003 Last edited by Thesilverfox; 05-07-2018 at 05:29 PM. |
05-07-2018, 01:37 PM | #62 |
truly staggering work! I cant hardly believe this is the same truck. I especially like the trans/driveshaft bumps, how did you get such smooth radii?
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-07-2018, 01:51 PM | #63 |
Very nice progress....nice looking trans tunnel.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
05-07-2018, 02:28 PM | #64 |
Post Whore
looking good...naw...looking great!!!
05-07-2018, 05:02 PM | #65 |
Thanks guys. I used a dead blow hammer, 3 inch pipe in a vise, a block of wood and about 1000 tweaks with the grinder to get the fit perfect.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003 Last edited by Thesilverfox; 05-07-2018 at 05:18 PM. |
05-08-2018, 12:00 PM | #66 |
WOW!! Yup that covers it.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
05-08-2018, 01:10 PM | #67 |
I have seen a few steel wheel barrow tubs used as well. sometimes a bit big though.
nice work. no planishing hammer then? looks really good. |
05-08-2018, 01:14 PM | #68 |
great work ----lookin good
05-08-2018, 01:14 PM | #69 |
too bad about the old firebird interrupting your build. better just let me have it so you don't get some syndrome or another. just thinking about your mental health........
05-08-2018, 07:55 PM | #70 |
very nice choice for wheels, great stance!
05-09-2018, 09:28 AM | #71 |
Thanks guys.
Firebird would be an interesting project for sure. Have not bought it yet though. Want to finish truck first so I don't get sidetracked. It is a true matching numbers 400 with all the original parts. The spoiler from a Camaro was added later but is not original to the car. Would be an great restoration project. I guess an unmolested Firebird is kinda rare.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003 Last edited by Thesilverfox; 05-09-2018 at 09:33 AM. |
05-09-2018, 09:46 AM | #72 |
Looking good! gonna be a very cool truck.
1950 3100 5 window |
10-21-2018, 09:53 PM | #73 |
Update, it's been lots of work but happy with the results so far. What you see below is final assembly of the frame components. I had everything aligned and fitted but still running into minor issues.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003 Last edited by Thesilverfox; 10-23-2018 at 09:10 AM. |
10-21-2018, 11:09 PM | #74 |
Very nice...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
10-22-2018, 02:51 AM | #75 |
beauty!
