Old 02-19-2019, 12:30 PM   #51
Dads79GMC
Dads79GMC's Avatar
Re: 85 GMC dirt cheap refresh
Another addition to the resume!!
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 02-20-2019, 10:14 AM   #52
aggie91
I'm just glad to be here!
aggie91's Avatar
Originally Posted by Jaysonb View Post
...But as long as I don't charge myself for labor, it's still a pretty cheap project. ...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-24-2019, 07:05 AM   #53
Jaysonb
Jaysonb's Avatar
Did some block sanding on the cab, then cleaned up the floor. I removed all of the old seam sealer and put some new stuff in there, removed the surface rust that was on the right floor, and went over my welds with some waterproof fiberglass filler incase there were any pin holes that I missed. After that was dry I sanded the floor down with some 80 grit, and shot a couple of heavy coats of dupont corlar high solids epoxy mastic.
Jaysonb is offline   Reply With Quote
Old 02-24-2019, 10:04 AM   #54
Dads79GMC
Dads79GMC's Avatar
Very nice work
Old 02-25-2019, 08:13 AM   #55
Jaysonb
Jaysonb's Avatar
Made a little more progress on the cab tonight.
Old 02-25-2019, 10:49 AM   #56
Dads79GMC
Dads79GMC's Avatar
A little progress??
Old 02-26-2019, 09:35 AM   #57
aggie91
aggie91's Avatar
Originally Posted by Dads79GMC View Post
A little progress??
like I said before, his definitions are different from most of us...
Karl
The LST Challenge:
Old 02-26-2019, 01:38 PM   #58
Dads79GMC
Dads79GMC's Avatar
Karl, I'm gonna throw him off his game and get him to paint my front clip! .
Old 02-28-2019, 06:41 AM   #59
Jaysonb
Jaysonb's Avatar
I had a little time in the shop tonight and got the cab back on the frame, and started getting some stuff bolted back on it. I cleaned the bottom of the cab up a little, and sprayed some undercoating on it before I bolted it down.
Old 02-28-2019, 10:09 AM   #60
Dads79GMC
Dads79GMC's Avatar
Oh boy, looking awesome! When do you think you’ll power it up?
Old 02-28-2019, 04:55 PM   #61
Jaysonb
Jaysonb's Avatar
Thanks Mike! I'm not sure about powering it up, for now I just want to get whatever I can bolted on and out of the way so I can make room in the shop to get your front clip painted up.
Old 02-28-2019, 04:57 PM   #62
Dads79GMC
Dads79GMC's Avatar
Lol!!
Old 02-28-2019, 07:47 PM   #63
MTCK
MTCK's Avatar
Jayson is at it again!!!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-04-2019, 09:49 AM   #64
MrFinland
MrFinland's Avatar
Wau!! So nice! Truck is almost ready to road!
MrFinland is offline   Reply With Quote
Old 03-27-2019, 01:57 AM   #65
Jaysonb
Jaysonb's Avatar
Well, the doors on this truck ended up being to rusty along the edge that had the door edge guards on them. So I pulled out a set of aftermarket doors I had sitting in the basement. The bummer about that, is that I had to bolt everything back on to the truck to find out what kind of work it will take to make the doors fit. The right door fits almost as good as the oem door, and after hogging out the bolt holes in the hinges to allow for more adjustment, the left door fits good as well. It took awhile took hang and adjust the doors and fenders, but I will make up some time by not having to fix the rust, and dents the factory doors have. It was also nice to see what the ride hight ended up at. It is a touch higher than I was hoping for, but it will work.
Old 03-27-2019, 10:19 AM   #66
Dads79GMC
Dads79GMC's Avatar
Awesome work!!
Old 03-28-2019, 12:48 PM   #67
erichevy
erichevy's Avatar
Great thread. I'm hoping to do something similar to my 87 Shorty. Looks great so far!
1979 GMC C35 - Farm Work Truck
1986 GMC C25 Crew Cab
1987 SWB R10
erichevy is offline   Reply With Quote
Old 04-04-2019, 06:48 AM   #68
Jaysonb
Jaysonb's Avatar
Thanks guys! The ride hight was just a little higher than what I was shooting for, so I swapped out the 2/4 stuff for some 4/6 stuff to see how that looks. Much closer to what I'm after, but the front is a touch low for the more level look I want, so I'm going to swap out the 2" springs for some 1", and I think that will work perfectly.
Old 04-05-2019, 10:44 AM   #69
Dads79GMC
Dads79GMC's Avatar
It looks great right now. That one inch may be just perfect.
Old 04-06-2019, 11:59 PM   #70
Jaysonb
Jaysonb's Avatar
The 1" drop springs showed up today, and me and my oldest boy got them installed. I think I'm happy with the stance now. The truck is not perfectly level from side to side, so we had 3 diffrent sets of springs in there, and swapped springs side to side making sure that they were fully seated each time, and we are now positive that we do not have a spring issue, so somthing is a little tweaked somewhere, but it is within a 1/4" from side to side, so I'll have a little shimming to do to get the body level.
Old 04-08-2019, 08:47 PM   #71
rusty76
rusty76's Avatar
Looks good
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-13-2019, 01:17 PM   #72
Jaysonb
Jaysonb's Avatar
I decided to see if I can repair my oem doors, if it doesn't turn out I can use the aftermarket doors, so I have nothing to loose. I am going to try and replace the rusted through door edge, and there is a small rusty spot at the bottom to fix. So far I bent a piece up, and have been working it in the shrinker to match the shape of the door. I think it's pretty close now, so I'm going to cut the edge of the door out, weld in the patch, and then fold the edge around. Hopefully without turning the door skin into a warped oil can!
Old 04-13-2019, 02:09 PM   #73
Jaysonb
Jaysonb's Avatar
With the edge cut out, the door frame underneath is in perfect condition. New piece was cut to fit nice, and I'm using a damp cool rag next to the weld to help prevent warping.
Old 04-13-2019, 02:23 PM   #74
MTCK
MTCK's Avatar
Nice work. Looks like it came that way.
-Marcus
Project Plow Truck
Old 04-13-2019, 03:26 PM   #75
Jaysonb
Jaysonb's Avatar
Thanks Marcus, so far it's working pretty good, the weld area sucked down just a touch, but the cool rag prevented any warping out in the middle of the panel, and that's what I was worried about. I hammered over the edge, and I'm more than happy with the progress so far.
