Old 10-09-2017, 10:41 PM   #51
joedoh
joedoh's Avatar
Re: 57 GMC, frame swap, 4wd, 454 big block, 4 speed
purty!
I think the color you seek was recently released by PPG, kindigit did a 55 bel air in a color they called "putty" and everyone lost their mind for it so PPG was said to have added it.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-09-2017, 11:00 PM   #52
Old57
Originally Posted by joedoh View Post
purty!
Thanks! Yes, that color is growing on me.
My 57 GMC build
Old57 is offline   Reply With Quote
Old 10-12-2017, 04:04 PM   #53
Old57
I went to my friend's garage the other day and we tilted the cab on it's back and removed the dolly, sitting it on a stand. Last night, he got the bottom side prepped and sprayed in the bed liner. I'll go get the cab and bring it home this weekend, then I can get it mounted to the frame.
I shouldn't have to worry about rust in the lower half of the cab anymore.
My 57 GMC build
Old 10-12-2017, 05:20 PM   #54
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Clean!
ChuckDriver is offline   Reply With Quote
Old 10-12-2017, 06:16 PM   #55
Old57
Originally Posted by ChuckDriver View Post
Clean!
Thanks! It feels good to finally be ready for the cab to go on the chassis.
My 57 GMC build
Old 10-15-2017, 10:36 PM   #56
Old57
There was a "marriage" in the shop today... the 57 GMC cab is mounted to the K20 4x4 chassis. It feels good to start seeing it take shape. Wheels and tires will raise it a couple inches... It's going to be a big boy, but will fit under my 8' doors. I'll be using an HEI distributor too, now that I know it'll clear ok.
My 57 GMC build
Old 10-16-2017, 01:12 PM   #57
OutlawDrifter
Very cool!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 10-16-2017, 02:08 PM   #58
Old57
Very cool!
Thanks! Its not everyones preference, but its what I wanted
My 57 GMC build
Old 10-16-2017, 05:37 PM   #59
joedoh
joedoh's Avatar
super great, it was a great weekend in kansas to be working on trucks!
Old 10-16-2017, 09:24 PM   #60
Old57
Man, it was a perfect fall weather for "shop stuff"! Your truck is coming along good... much faster than mine! I wish I had more time to work on my own stuff.
My 57 GMC build
Old 10-18-2017, 05:05 PM   #61
rusty76
rusty76's Avatar
Awesome truck I’m following.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-29-2017, 08:32 PM   #62
Old57
I had time to work on my front fenders today. I'm using the driver side 57 GMC fender that was on the truck, but the passenger side GMC fender was in bad shape and not worth fixing, so I found a 55-56 Chevy passenger side fender a long time ago to use, which I'm changing to a 55-56 Chevy front clip anyway. I knew this 55-56 fender would need to be re-repaired from poor previous work.
My GMC driver side fender had rust in the headlight eyebrow and rear lower bottom. It also had the holes for the GMC mustache trim, which had been cut out a lot bigger for some reason. The other issue to fix is the grill mount notch that 57 fenders have. I got all of the areas in the driver side fender marked, cut out, and prepped for repairs. I used a new repair piece for the eyebrow, and made a patch for the rear bottom. I used a wrecked donor fender for the other pieces, and also welded in the GMC emblem holes. So the end result is a 57 GMC fender converted to a 55-56 Chevy fender, and now rust free.
After that, I used a wire cup on a grinder to remove all the body filler and inspect what needs done on the 55-56 passenger side fender. It will need a little work in the eyebrow area, and needs the poor quality bottom patch redone, and a new lower inner brace to replace the hacked up one in there now. I'll be able to re-use the previous lower rear patch, just cutting it out where some one lap-welded it so I can properly butt-weld it together and fit it right... and not need 1/4" think body filler then!
So after I get this passenger fender fixed, I'll have a rust free truck... finally! Then I can take all 4 fenders, inner fenders, hood, core support, and doors to get media blasted and sprayed in primer. I'll get the bed blasted and sprayed in primer sometime after that. I still need to come up with a good 73-87 long bed floor to weld into my 57 long bed, which will also have the bed cross rails to mount directly on this K20 frame.
My 57 GMC build
Old 10-29-2017, 08:37 PM   #63
Old57
A few more pics
My 57 GMC build
Old 10-31-2017, 08:56 PM   #64
Old57
I started fitting my core support, inner fenders and driver side fender. I was having trouble getting the inner fenders to mount to the core support and be lined up with the cab, then noticed that the EZ Chassis Swap mounts had my cab leaning down in the front. I asked a guy to get me some measurements on a stock frame for the body mount height difference in the front and rear mounts. With his measurements, I figured out that I needed to add 1/2" shims at the front mounts, then everything started lining up and looking right. I trimmed the driver inner fender to clear the steering box, and I'll shape it nice when I take the front clip back apart for blasting and priming. Also, the EZ Chassis mounts for the core support was a good fit for the passenger side, but I had to rework the driver side mount quite a bit, and rework the driver side of the core support to get everything bolted on. I messaged Ed at EZ Chassis Swaps to ask about the core support mounts not clearing the steering box, and he knew about it and said I'd have to modify everything to work on the 55-57 trucks. He never mentioned anything like that when I ordered the cab and core support mounts from him. I'd think that if the mounts weren't correct, they'd be revised before they are sold as being right. If I was to do this again, I'd make my own mounts. The EZ mounts are really pricey, especially when they don't fit right anyway. It's nice to start seeing what the truck is going to look like now. It'll come up 3 or 4 inches with wheels and tires... Going to be a big boy.
My 57 GMC build
Old 11-01-2017, 09:34 PM   #65
Old57
This evening's mock-up progress on the 57... I got the front clip fit up to the cab and frame. I need to install the hood, fix the passenger side fender, and make both fender bottoms match the door and cab, then I can get it all media blasted and sprayed in epoxy primer like the cab. Nothing just goes right together, haha!
My 57 GMC build
Old 11-03-2017, 01:20 AM   #66
izzy_Britton
izzy_Britton's Avatar
nice build. looking good. wish i had the time to work on all my projects. lol
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 11-03-2017, 10:24 AM   #67
joedoh
joedoh's Avatar
holy geeze that is a big truck! haha looking good!
Old 11-03-2017, 04:37 PM   #68
mongocanfly
Post Whore
mongocanfly's Avatar
yep....coming together nicely. ..
Old 11-03-2017, 05:25 PM   #69
Black_Sheep
Black_Sheep's Avatar
Lovin' it...
Black_Sheep is offline   Reply With Quote
Old 11-03-2017, 11:50 PM   #70
Old57
Thanks guys
I had a little bit of time this evening, so I set in the 88-98 Chevy truck bench seat and marked for the mounting holes. It fits in great, and I'll get it recovered sometime. I think I might shorten the bottom mounting brackets 1 1/2" or 2". Its much more room and comfortable than the stock bench, but I'm 6'-4", so I sit up pretty close to the roof now. I also mounted the wiring panel on the inner firewall.
My 57 GMC build
Old 11-08-2017, 12:56 AM   #71
Old57
I had a chance to get a little more done this afternoon. I got rid of the drum brakes on the 14 bolt rear end, and installed rear disc brakes.
My 57 GMC build
Old 11-08-2017, 07:00 PM   #72
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on your truck, I love it!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-08-2017, 09:07 PM   #73
Old57
Thanks! I feel the same about your truck too!
My 57 GMC build
Old 11-08-2017, 09:12 PM   #74
Old57
This afternoon, I cut 2" out of the mounts on the 88-98 Chevy truck seat. The seat fits great in the cab, but I'm tall and my head was close to the roof of the cab, so I cut the mounts down. I sprayed some black paint on them after I welded them together. I'll probably have them powder coated later on when I re-cover the seat in pleated black vinyl.
My 57 GMC build
Old 11-08-2017, 10:09 PM   #75
Advanced Design
Advanced Design's Avatar
Wow, cool build and nice work! Catching up and tagging along for the rest.
Advanced Design is offline   Reply With Quote
