Old 08-08-2017, 10:12 PM   #51
1lo94
Re: 1986 swb bagged and bodied build thread
Also testing pinion angle change, and lift. Truck has 31" of lift with very little pinion angle change. Obviously won't have that much lift with the bags installed but very happy with how well we got the pinion angle dialed in.
1986 1 owner C10 Silverado. In process of bagging and bodying. Build thread coming soon
1986 BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=731446
1lo94 is offline   Reply With Quote
Old 08-08-2017, 11:51 PM   #52
tinydb84
tinydb84's Avatar
Wouldn't you want the front upper mount on the passenger side?
David
Instagram: myfabguy
Old 08-09-2017, 08:42 AM   #53
1lo94
Why would you want it that way?
Old 08-09-2017, 11:07 AM   #54
tinydb84
tinydb84's Avatar
I thought it had to do with the torque running through the upper bars and wanting the torque to push the chassis through the passenger side. I could be wrong though.
David
Instagram: myfabguy
Old 08-09-2017, 11:47 AM   #55
1lo94
Oh yeah that makes sense, I don't think it makes a lot of difference the way I have it all set up. But it could if the truck was gonna make a lot of power. Gonna be a mildish 350 build make maybe 400 hp. But I am glade you brought it up cuz I may look into it a little more
Old 06-07-2018, 11:33 AM   #56
bubblemouse
Updates!!!???
bubblemouse is offline   Reply With Quote
Old 06-07-2018, 12:01 PM   #57
1lo94
Originally Posted by bubblemouse View Post
Updates!!!???
Let me try to upload some pics, I haven't been on in a while. Kinda had two projects going and finished up my shop and got a lift so lift has been crazy. But the truck is real close to being done. Bought everything to do a 5.3L and 4L80e swap but motor needs rebuilt and trying to buy a house now so gong back with the built SBC I have and built trans and should be setting that in this weekend.
Can follow my build on Instagram @c10aronius as well
Old 06-07-2018, 02:32 PM   #58
1lo94
Here is a few pics of the build I got some more downloading. Couple of shots of it laid out, and a few shots showing the tilt bed frame on and functioning
Old 06-07-2018, 02:52 PM   #59
1lo94
Frame painted with por15 and the bed frame pictured up. Also showing the turning radius all the way down
Old 06-07-2018, 02:55 PM   #60
1lo94
Bed work! Moved the wheel tubs in 3" by building flat sheet metal walls. Also made the tubs fit like factory by cutting the bed floor and moving it all. Flat wall in back for when the tailgate is down from raising bed floor. Cut and welded front wall to appear factory
Old 06-07-2018, 03:11 PM   #61
1lo94
Some of the most recent pics
Old 06-07-2018, 03:15 PM   #62
1lo94
The motor I am gonna put in it now, it is the original motor out of the truck. All rebuilt and a cam and new springs. Also going back with a Fitech FI setup I came up with. And a pic of my girls with the truck at a local show we took the truck out to show the progress so far.
Old 06-07-2018, 08:30 PM   #63
3drburb
That's how you update a build, just plan sick.
I like that tilt bed also.
Nice work.
3drburb is offline   Reply With Quote
Old 06-08-2018, 08:42 AM   #64
MotoX
MotoX's Avatar
Looks sweet. Have you decided on painting it or leaving it patina? And did you paint the bed or use a bedliner?
I am Captain Chaos and this is my faithful companion Cato! Say hello Cato!
MotoX is offline   Reply With Quote
Old 06-08-2018, 09:16 AM   #65
1lo94
Nice work.
I appreciate it man. The tilt bed has turned out really well. I figured i'd get mixed emotions on it.
I am leaving it patina for a while, just wanna enjoy the truck and not have to worry about it getting scratched or something. I have all the original trim going back on, drip rails, fender trim, cab and tail gate trim, and then new molding. gonna finish buffing truck before I install it all.
