Old 04-23-2017, 06:44 PM   #51
cooperhw
cooperhw's Avatar
Re: 78 downlow-littledough
Finally was able to get back in the garage and get some work done on downlow-littledough.
Trimmed the belly after installing a piece of 2" X 4" tube steel. Moved out back today and was able to get the c-notch installed. Ran out of gas, so clean up on the welds will have to wait for next weekend. Also got the front a-arms cupped for the bags to sit in a little lower. Will have to get some pics of that later on.
Anyhow, a little bit at a time.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 04-23-2017, 06:48 PM   #52
cooperhw
cooperhw's Avatar
few more
Later,
Wayne
Old 04-30-2017, 08:04 PM   #53
cooperhw
cooperhw's Avatar
Well slowly but surely I am gaining ground (I think). I finally got finished slicing and dicing on the frame and am in the process of going back together. I trimmed off the leaf spring hangers and spring perches off the axle tubes.
I got to finally roll the rear end under the frame and sit her down.
It is resting firmly on the bottom of the trimmed frame rail (2" X 3" box tube). I still have about 3 inches under the crossmember, but the lower a-arms and not on yet. Anyhow, the front of the frame the core support sits on has about 1/2" clearance.
So, I know you all like pictures.
Later,
Wayne
Old 04-30-2017, 08:06 PM   #54
cooperhw
cooperhw's Avatar
more,
Later,
Wayne
Old 04-30-2017, 08:09 PM   #55
cooperhw
cooperhw's Avatar
last but not least,
Later,
Wayne
Old 04-30-2017, 08:28 PM   #56
cooperhw
cooperhw's Avatar
How could I forget.
Bought a new heart and lungs for the old girl. So much for "littledough".
Having trouble loading pictures of them right now.
It's 2002 LS-1 with a T-56 6 speed manual transmission. Came out of a 2002 Camaro with 78,000 miles.
Later,
Wayne
Old 04-30-2017, 08:32 PM   #57
cochino12
It followed me home?
cochino12's Avatar
Sub'd
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-30-2017, 09:02 PM   #58
cooperhw
cooperhw's Avatar
Transplant to come soon.
Later,
Wayne
Old 05-01-2017, 09:28 AM   #59
hewittca
hewittca's Avatar
Lookin' good so far. What are your plans for the bed floor?
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-01-2017, 09:51 AM   #60
cooperhw
cooperhw's Avatar
Thanks hewittca. As to the bed floor; IDK. I know so far I will be installing another set of wheel tubs to accommodate more tire. Going over the C-notch will just be a matter of cutting out the area that the notches comes into contact with, and after the bed is mounted back in place I will probably raise the bed floor.
My method of dealing with sheet metal is to just cut it away and then patch it back in where it fits over whatever I stuck in the way. I have no qualms with cutting into sheet metal and welding it back.
Later,
Wayne
Old 05-02-2017, 10:02 AM   #61
SCOTI
SCOTI's Avatar
Most likely will need to raise the floor just based on driveline angles w/the drivetrain 6" higher vs the cab floor (depending on what does/doesn't get changed further forward).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-02-2017, 11:31 AM   #62
cooperhw
cooperhw's Avatar
Agreed. Little slice and dice here and there. No biggie.
My old friend used to say "No step for a Stepper".
Later,
Wayne
Old 05-05-2017, 10:41 PM   #63
cooperhw
cooperhw's Avatar
Well, I got a little bit of work done. I went downtown and had some U-bolts bent so I could start mocking up my trailing arms and bags. Finally got the front control arms back in place. Was able to set my bags in place and check out ride height. Looks like about 4 to 5 inches will be the norm. Tons of clearance at the front control arms and crossmember.
Later,
Wayne
Old 05-05-2017, 10:43 PM   #64
tinydb84
tinydb84's Avatar
How is the driveshaft going to fit??
David
Instagram: myfabguy
Old 05-05-2017, 10:43 PM   #65
cooperhw
cooperhw's Avatar
few more pics
Later,
Wayne
Old 05-05-2017, 10:48 PM   #66
cooperhw
cooperhw's Avatar
Doesn't look like there is going to be any problem. We'll see.
Later,
Wayne
Old 05-05-2017, 10:52 PM   #67
cooperhw
cooperhw's Avatar
I am going to have to adjust the pinon angle just a tad though.
Later,
Wayne
Old 05-05-2017, 11:34 PM   #68
tinydb84
tinydb84's Avatar
Looked a bit tight from the pic. Might be the angle.
David
Instagram: myfabguy
Old 05-07-2017, 05:48 PM   #69
rusty76
rusty76's Avatar
So are using a stock truck arm cross member and truck arms?
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-07-2017, 07:09 PM   #70
cooperhw
cooperhw's Avatar
Yes. I "cupped" the bottom control arm & have a plate across the stock crossmember.
Later,
Wayne
Old 05-08-2017, 12:16 PM   #71
SCOTI
SCOTI's Avatar
That's what you did up front. I read the question as what's going on out back.
It looks like an aftermarket POL or CPP T/A x-member & factory GM truck arms for the rear. But, it seems like your placement of the arms on the rear end will require changes @ the x-member.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-08-2017, 12:24 PM   #72
cooperhw
cooperhw's Avatar
Oh, ok.
Yeah, out back,
After much (really a lot) deliberation, yesterday I came to the conclusion that the trailing arms off of that 66 were not going to work without major modification (as mentioned) and was just going to looked hacked into place. So, I pulled all of it out and will be installing a triangulated 4 bar set up. I should have done it in the first place, but until I got it into position in my minds eye it would work. Oh well, live and learn.
Later,
Wayne
Old 05-08-2017, 06:10 PM   #73
rusty76
rusty76's Avatar
It's all good I was just wondering if you were using stock parts or aftermarket.
My build thread
Crossmembers CC
Old 05-08-2017, 07:36 PM   #74
cooperhw
cooperhw's Avatar
I was hoping to use the stock trailing arms, but not gonna make it as low as this dude is gonna drop.
Went and picked up some aftermarket triangulating bars tonight. Gotta keep plugging along. Two steps forward and (hopefully) one step back. sometimes
Later,
Wayne
Old 05-08-2017, 09:38 PM   #75
cooperhw
cooperhw's Avatar
Ok, now I am feeling better about my decision to scrap the trailing arms. Frame is at ride height. Rear axle at ride height. Top bag bracket will raise up to top of c-notch.
"I'm feeling it".
Later,
Wayne
