Closed Thread
Old 09-11-2017, 02:52 PM   #51
jchav62
1962 C-10
jchav62's Avatar
Re: 1965 1/2 C10 Pickup
Originally Posted by salty531 View Post
vin# 6Z126582
c144
JUST CONFIRMED IT IS A L79 66 CORVETTE ENGINE WITH ROLLER CAM.
That's a 1966 that was purchased at the end of 1965. The first number of the VIN, "6" indicates it's a 1966.
Are you sure you don't mean solid lifter cam?? L79's were solid lifters, I'm pretty sure. Also, the L79 was the 350HP version of the 327. No "310HP" version of the 327 ever existed. Roller cam or not.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline
Old 09-11-2017, 02:52 PM   #52
dtkarst
Is there a sticker on the glove box door? That'll tell you its options but I've only had one 66 with a SPID on it but that's just me.
dtkarst is offline
Old 09-11-2017, 02:53 PM   #53
The Rocknrod
Moderator
The Rocknrod's Avatar
Dont feed em.
L72 = Solid lifter.
The Rocknrod is offline
Old 09-11-2017, 03:00 PM   #54
60-66
60-66's Avatar
"Back then if you had connections, anything was possible" and "I was talking to my old shop teacher, and he said back then you could order almost anything if you knew the right people. And stuff like that happened too" are the most over blown or biggest myths floating around the internet or shop talk. It would help if people would substantiate these quotes with fact , especially when it comes to drive-train and engine horsepower .
About the only things you could change up were colors, options , seats , maybe extra sound deadening , tires , wheels but not horsepower. These engines were delivered to the assembly plant from Flint Mi, Built and Done ! ready to install with a suffix code to match an application and transmission. If a cam was changed it would require other parts or if anything was changed it would have its own specific Suffix code stamped in that engine BEFORE it left Flint. So , again , we need the VIN to determine year, SPID would be nice or Protecto Plate since you bought it new, would tell us everything about the truck, but the Suffix will not lie as to what horsepower that engine is , which should be 220 gross hp. In the DATA book it lists all the COPO numbers for Special Orders and they are "9000" numbers , these specific numbers will be on the build sheet and spid. There are no COPO 1966 engines listed for truck.
On the 390 1965 Mustang , speaking with a ford guy , says that would take an awful lot of inner fender or shock tower modification to even get a 390 in the engine compartment. Great story tho .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline
Old 09-11-2017, 03:04 PM   #55
60-66
60-66's Avatar
VIN# 6z126582
Your truck is a 1966 as already stated. Confirm the stamping on the front of the block. An L79 will have a VIN number stamped in the block and also an aluminum intake and holley carb , ???
60-66 is offline
Old 09-11-2017, 03:06 PM   #56
salty531
Originally Posted by Brad54 View Post
Can you get a pic of the cam and the lifters? That'll clear up the whole "roller cam" question.
I'm not one to say "never," but as a tech editor for a Chevy magazine, and tech editor and freelance writer for several other magazines over the years, I have never heard of a factory roller cam in any Chevy vehicle from the '60s.
-Brad
I ordered new parts for 66 Corvette with Roller Cam and got he parts.
salty531 is offline
Old 09-11-2017, 03:08 PM   #57
jchav62
1962 C-10
jchav62's Avatar
If it has a roller cam and lifters, it must've been added later with aftermarket parts.
Joseph Chavez
jchav62 is offline
Old 09-11-2017, 03:09 PM   #58
salty531
Hp could be wrong. New Roller Cam parts for 66 Corvette came. See pic.
salty531 is offline
Old 09-11-2017, 03:10 PM   #59
The Rocknrod
Moderator
Show some actual truck documentation as stated above. New parts do not make a difference on what was there when it left the factory.
Old 09-11-2017, 03:12 PM   #60
jchav62
1962 C-10
jchav62's Avatar
I can order a roller cam for pretty much anything nowadays. Doesn't make it original replacement parts.
Joseph Chavez
jchav62 is offline
Old 09-11-2017, 03:13 PM   #61
salty531
SPID sticker did not come out until the 80's. 220 Hp is correct but this came with L79 Corvette or L79 used in Malibu high performance cars with 325 or 350 HP. See pic- new Roller Cam parts.
salty531 is offline
Old 09-11-2017, 03:14 PM   #62
salty531
I know what was there when it left the factory as i have owned it since it came from the factory.
salty531 is offline
Old 09-11-2017, 03:15 PM   #63
jchav62
1962 C-10
jchav62's Avatar
My 73 had a SPID sticker on the fender well. In the glovebox on an '83 I owned. Not sure about the '66 you have though... if it has one.
Joseph Chavez
jchav62 is offline
Old 09-11-2017, 03:16 PM   #64
salty531
No way. I have owned it since new and it has never bin touched by a mechanic.
Engine is as it came from the factory.
salty531 is offline
Old 09-11-2017, 03:16 PM   #65
salty531
SPID started in the 80's.
salty531 is offline
Old 09-11-2017, 03:18 PM   #66
salty531
They are identical to the ones in the Truck.
salty531 is offline
Old 09-11-2017, 03:37 PM   #67
salty531
Not likely.
And yes no roller cam 327 ever was made, and a roller cam small block started in like 87? or latter.
Sorry to differ with you but it has a Roller Cam and was verified by the machine shop. He said that he has only seen one other like it. It is very rare but they were made.
salty531 is offline
Old 09-11-2017, 04:14 PM   #68
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Hey guys,
It doesn't really matter, does it?
Let salty531 enjoy his all original 1965-1/2 vin# 6Z126582 c144 - With a L79 66 Corvette Engine with a Roller Cam.
66 C20 Service Truck:
LostMy65 is offline
Old 09-11-2017, 04:19 PM   #69
dtkarst
Not trying to split hairs but from 67 and up I believe had the spid on the glovebox for sure. Only had one or two 66 pickups with them. That being said you still have a very desirable pickup that many on here would love to have.
dtkarst is offline
Old 09-11-2017, 04:24 PM   #70
60-66
60-66's Avatar
All 1966 up trucks have spid sheets and protecto plates . Looks like this subject is dead anyway, salty only wants to show his new cam for his 1966 with a corvette engine or whatever?
60-66 is offline
Old 09-11-2017, 04:25 PM   #71
dtkarst
Also here is my spid from my 66. Factory ac, big window, automatic and steering, also factory 327. Sat for a long time with the glove box open but here it is.
dtkarst is offline
Old 09-11-2017, 04:39 PM   #72
oem4me
All 66's came with a SPID on the glove box door. Though it seems impossible, I'd actually love it if Salty can prove us all wrong and show a SPID sheet confirming a unique engine. These stories surface every now and then, and true or not, really stir things up! Here's hoping!
oem4me is offline
Old 09-11-2017, 05:16 PM   #73
The Rocknrod
Moderator
He wont show his glove box door and we all know why. He wont have any documentation and we know why. He has a new cam for an engine that we dont even know it's a 65 or 66 or not it's just "confirmed" by the unicorn wrangler.
Old 09-11-2017, 05:16 PM   #74
La Zona Imagery
No reason to attack me like that. My shop teacher said back then lots of things were possible that aren't as possible nowadays
1965 Chevy C-10 350 V8
2003 GMC Sierra Crew Cab 6.0L 4x4
La Zona Imagery is offline
Old 09-11-2017, 05:25 PM   #75
La Zona Imagery
Maybe you got an early prototype engine build. That would be cool.
Closed Thread
