Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-08-2018, 04:07 PM   #51
Graham57a
Graham57a's Avatar
Re: How To: Ruin a Perfectly Good 4wd
Suhhweeetttt! I'm in, can't wait to see it unfold
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 02-09-2018, 12:41 PM   #52
gringoloco
A guy with a truck
gringoloco's Avatar
Me too! Parts collecting mode right now, progress soon
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-09-2018, 01:43 PM   #53
knomadd
knomadd's Avatar
I think the arbitrary line you reference in the diagrams is intended to represent the firewall. I'm not 100% certain of it though. Looks like you've got it figured out anyway. Good luck.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 02-09-2018, 09:06 PM   #54
gringoloco
A guy with a truck
gringoloco's Avatar
I was kinda thinking that, too. It may or may not matter, but it’s a start
-Chris
Old 02-14-2018, 11:10 PM   #55
gringoloco
A guy with a truck
gringoloco's Avatar
Received a couple of boxes from MS today:
-Chris
Old 02-14-2018, 11:14 PM   #56
gringoloco
A guy with a truck
gringoloco's Avatar
Overall view of the Polite’s Deadend Garage parts received:
Pretty impressed with the quality for the money. Seems like well thought-out parts with good assembly and nice welds.
-Chris
Old 02-14-2018, 11:22 PM   #57
gringoloco
A guy with a truck
gringoloco's Avatar
First up, the panhard bar. It’s a nice, heavy piece that is full length from the frame rail to the trailing arm. Includes wrap-around trailing arm mount and shim for opposite side. The heims are opposite threaded so adjustments can be made on the truck. Bonus.
This bar will also work on stock 2wds, which means that any stock or aftermarket stock-style panhard should work with the conversion kit. I chose to purchase this with the notches since I recently (and foolishly) sold my ECE super panhard. Did I mention I wasn’t looking for another project?...
-Chris
Old 02-14-2018, 11:30 PM   #58
gringoloco
A guy with a truck
gringoloco's Avatar
Next, the rear shock relocation brackets. These are important since the 4wd does not have the crossmember with provisions for upper shock mounting with the trailing arms. The upper brackets will tie into the notches and the lowers mount on the trailing arms. Notice, too, that all holes are slotted for adjustability. This may come in handy for alignment or clearing exhaust, etc.
You can see that one of the lowers was bent, presumably in shipping, but a big crescent wrench quickly rectified that (though it didn’t bend easily).
-Chris
Old 02-14-2018, 11:40 PM   #59
gringoloco
A guy with a truck
gringoloco's Avatar
Now, the heart of this conversion setup, the notches. They serve as not only the c-notch for axle clearance, but also provide the upper mount for the coil springs (or bags), which is missing on the straight 4wd Blazer framerails. They also have the frame side panhard bracket, locate the upper shock mounts and panhard crossmember, and have holes for stud mount bumpstops.
Also included is a template used to locate and shape the cut for the notches in the framerails. Nice.
-Chris
Old 02-14-2018, 11:44 PM   #60
gringoloco
A guy with a truck
gringoloco's Avatar
I also purchased a set of their front shock relocators, which correct shock angle and allow use of a stud style shock, similar to what Porterbuilt and RideTech offer. The uppers bolt to the ‘rails, while the lowers locate in the a-arm channel and are welded in place.
-Chris
Old 02-14-2018, 11:53 PM   #61
gringoloco
A guy with a truck
gringoloco's Avatar
And finally, mock-up. Truck parts in tha house! The parts fit together very nicely. I anticipate a smooth install (we'll see). There are a few places I will have to grind some welds smooth for good fitment, but overall, pretty impressed.
Notice I also elected to have them send a second crossmember that I will locate as close as possible to the spring perches to keep the framerails from bowing under the weight of the truck.
-Chris
Old 02-15-2018, 12:31 AM   #62
smbrouss70
smbrouss70's Avatar
Looks like some nice pieces. I'm surprised it took that long for somebody to make an econimcal, simple way to convert a 4x4 to 2wd.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-15-2018, 06:00 AM   #63
lolife99
67-72 parts collector,…
lolife99's Avatar
Thanks for the detailed pics of the Deadend Garage parts.
Keith
Convert to disc brakes.
Old 02-15-2018, 12:29 PM   #64
gringoloco
A guy with a truck
gringoloco's Avatar
I know, right?! Wish I’d thought of it...
Certainly. I know of only one other person with these parts right now, so I'm a bit of a guinea pig. But, that just makes it a little bit more fun
Just received the following from DEG, along with a bunch more pics and answers to my questions. Great customer service so far from these guys. Looks like the c-notch will locate pretty much inline with where the 4wd bumpstops are currently.
EDIT: Direct comparison with my previous conversion confirms the notch location is almost exactly the same. (reference the existing frame holes in relation to the vertical line drawn at axle CL)
-Chris
Old 02-16-2018, 10:10 PM   #65
gringoloco
A guy with a truck
gringoloco's Avatar
Spent some time today pulling the original gas tank, which still wears its “snake” filler neck, but unfortunately keeps blocking the fuel filter with mud rust, has been poorly patched in the past, and the gauge sender is malfunctioning. Thankfully, I have the poly tank I removed from the C10 to replace it.
When I removed the tank, I also removed a bunch of evap lines, that looped through a second filler cover on the passenger side, then ran up the framerail next to the battery to where the charcoal canister used to be. I’m guessing this was a California model, as I didn’t think trucks had this extra stuff until ‘72? Either way, when I install the new tank, I’ll make sure to, um, properly restore the function all of these lines and hoses and stuff, um, yeah
Also yanked the pretty nice and well-fitting trailer hitch from an unknown manufacturer. Almost a shame to pull it, but it hangs below the license plate which won’t exactly jive with the planned new stance
-Chris
Old 02-17-2018, 07:36 AM   #66
jaros44sr
jaros44sr's Avatar
Hey Chris, just a heads up on the poly tank. Its hard to attach the metal fill pipe to the poly tank, they were soldered on from the factory, and the location is very specific to get around the body mount
I use a chisel to start the cut, and tin snips to finish up. Don't blow yourself up
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 02-17-2018, 02:15 PM   #67
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks for the tip. Definitely won’t be throwing any sparks around it, haha
For the filler, I have a couple of options. The one attached is what I used on the truck, which cleared the floor well. If that doesn’t work here, I’ll use the smaller one on top to adapt the “snake”. That’s the plan, anyway
-Chris
Old 02-17-2018, 07:14 PM   #68
lks dcvn
lks dcvn's Avatar
Any idea if DeadEnd Garage has a kit that doesn't require you to use a C-notch? I hate the thought of cutting a good frame - even if the goal is to go 2wd.
lks dcvn is offline   Reply With Quote
Old 02-17-2018, 07:22 PM   #69
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'd be interested in the OEM gas tank fuel neck and the trailer hitch if you don't intend to use these. Thanks, Pete
Old 02-18-2018, 01:28 AM   #70
gringoloco
A guy with a truck
gringoloco's Avatar
I’m sure they could build one without the notch. Call them up and see what they have to say. Super customer service from them
I’ll let you know on the filler neck in the next couple of days. Hitch is up for grabs now
-Chris
Old 02-18-2018, 01:35 AM   #71
gringoloco
A guy with a truck
gringoloco's Avatar
Finished removing the evap system for “restoration” purposes. Looks like this one used to be olive (no SPID). Also appears the evap system was an add-on, after paint. Behind the fuel filler cover is primer only, so it was assembled pre-paint. <— gee-wiz interesting. Love the olive color, but I like ochre more
-Chris
Old 02-18-2018, 01:43 AM   #72
gringoloco
A guy with a truck
gringoloco's Avatar
While the tank and wiring are out, I coated everything I could reach and that isn’t getting removed soon with my favorite shade of POR-15. Not perfect, but much better looking than surface rust.
-Chris
Old 02-18-2018, 02:43 AM   #73
SeventyOne
That evap thing you pulled definitely wasnt stock.
They were always on the driver side. The panel you pulled off would cover the filler neck and there would be a cylindrical stand pipe that had 3 hoses connect to it under the floor pan.
What you have is really strange.
SeventyOne is offline   Reply With Quote
Old 02-18-2018, 09:31 AM   #74
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks, please do. What do you need for the hitch shipped to 87107? Pete
Old 02-18-2018, 10:36 AM   #75
gringoloco
A guy with a truck
gringoloco's Avatar
Strange, yes. I’ve only seen the other type you speak of, too. I still think this was a GM add-on, based on the fasteners, brackets, hoses and cover used, as well as the overall cleanliness and well engineered approach of the install. Maybe an early version before they refined the design?
I’ll dig up a box and let you know.
-Chris
