04-01-2021, 10:58 PM | #51 |
Re: My 58 Brookwood
The problem was that even with 7.4 pushrods and the rockers adjusted all the way up. The valve train was just way to tight.
my Solution is to make 1/8" spacers to place under the pedestals.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
04-02-2021, 09:50 PM | #52 |
Re: My 58 Brookwood
We put on the new water pump and the throttle body today
04-03-2021, 10:08 PM | #53 |
Re: My 58 Brookwood
we spent all day making these spacers to try to salvage the rockers, but it looks as if they won’t work!
04-17-2021, 12:11 AM | #54 |
Re: My 58 Brookwood
This is the LS3 all buttoned up
Can anyone tell me if the steam tubes have to be in front? I’ve converted them to 4AN. This is a real 6.2, just over 500hp!
04-17-2021, 06:46 AM | #55 |
Re: My 58 Brookwood
Very cool looking valve covers.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
04-17-2021, 09:18 AM | #56 |
Re: My 58 Brookwood
thank you
04-21-2021, 09:43 PM | #57 |
Re: My 58 Brookwood
Finally received the correct belt today and installed it
Bolted the fuel rails down Took out the radiator and prepped the 250 to pull Did a 1/8 NPT tap for an elbow to route the steam tubes to
04-22-2021, 08:03 AM | #58 |
6>8 Plugless........
Re: My 58 Brookwood
This is a sweet build and that is an awesome engine! What did you finally figure out on your valve train issue?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-22-2021, 09:05 AM | #59 |
Re: My 58 Brookwood
Went back to stock rockers I will do rollers later
04-22-2021, 09:26 PM | #60 |
Re: My 58 Brookwood
Pulled the old 250/3 speed out. Making way for the LS3!
Empty engine bay. I will be converting from manual steering to a CCP Power gearbox. I will also be converting to dual reservoir power disk up front
04-23-2021, 03:14 PM | #61 |
Re: My 58 Brookwood
Agreed! Where did you get those? Most of the "pretty" valve covers seem to omit the oil fill cap, and that's not good for routine maintenance.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
04-23-2021, 03:48 PM | #62 |
Re: My 58 Brookwood
Watching carefully! I have a 59 brookwood that burns as much oil as it leaks. Planning a 5.3 so I’m excited to see how your project goes. Love those old wagons! Keep the updates coming and thanks for sharing.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
04-23-2021, 10:54 PM | #63 |
Re: My 58 Brookwood
72gmguy-love these old wagons!
04-23-2021, 11:01 PM | #64 |
Re: My 58 Brookwood
the pitman arm
After removing the old manual steering box The manual box The new power steering box, some trimming will have to be done on the sheetmetal
04-26-2021, 11:37 PM | #65 |
Re: My 58 Brookwood
Here’s engine bay before we started
Here it is minus the battery tray, motor Mount pedestals, and clutch linkage Tomorrow we’ll work on getting the pedal assy and steering column out
04-27-2021, 09:40 AM | #66 |
Re: My 58 Brookwood
Radiator surround is back where it should be
sheetmetal trimmed for the power steering box
04-27-2021, 09:58 PM | #67 |
Re: My 58 Brookwood
so today JP took out the front seat
He also got the pedal assembly about 95% removed. Tomorrow he’ll finish that, remove the steering column, and the gas pedal.
04-28-2021, 10:34 PM | #68 |
Re: My 58 Brookwood
Today we got the steering column out
The master cylinder came off And the Brake/clutch pedal assembly came out
04-29-2021, 11:00 PM | #69 |
Re: My 58 Brookwood
We cut the bump for the master and steering column. Removed all the Wiring in the engine bay, and removed any clutch/throttle linkage.
This is the steering column I bought for it.
04-30-2021, 07:58 PM | #70 |
Re: My 58 Brookwood
We welded in that firewall patch to smooth it out.
Then we modified an S10 brake pedal assembly to work We wound up using part of the 58's pedal assembly to get it to be bolt-on.
04-30-2021, 08:11 PM | #71 |
Proprietor of Dale's Corner
Re: My 58 Brookwood
It's making progress!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-30-2021, 08:31 PM | #72 |
Re: My 58 Brookwood
04-30-2021, 09:19 PM | #73 |
Re: My 58 Brookwood
The Brake pedal and booster are in. We may need to go With a smaller diameter booster because it contacts the hood hinge.
05-03-2021, 08:52 PM | #74 |
Re: My 58 Brookwood
The patch is all cleaned up. The brakes and steering column have been mocked up and modified. Pics tomorrow
05-04-2021, 10:08 PM | #75 |
Re: My 58 Brookwood
We got the steering column in today
Cutting out the lower column bracket Tacking the bracket
