#726 |
Truck and auto performance nut
Re: LS1 into a 73 cheyenne
those are some sweet looking mounts!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#727 |
id love to have an ls style motor in my swb someday. very nice build very nice i like it
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842 |
#728 |
mounts look killer bro nice job so far...
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... ![]() |
#729 |
.....that lifting device bolted to the valley cover is a cool idea too...I'ma gonna steal that idea...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#730 |
I ordered the u joint and shaft from summit i should get them sometime this week. I went with Borgesons, stainless polished components. 2 u joint 1 double the shaft and 1 support. I under estimated these lil fellas they quickly added up $
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios |
#731 |
yeah, but look how nice they are......
#732 |
UPS dropped off this today Sata 100 p b rp with a 2.5 tip and a 0.6L plastic cup. This is the latest addition to my Sata collection. Il post pics of my entire line up. Especially designed for polyester. This will be replacing my sharpe razor 2.3
#733 |
nice very nice....
#734 |
i got the u joints from fed ex today the shaft was delivered by UPS, unfortunately when i got the box from UPS it seemed really light and it was damaged with a bunch of tape so i opened it as soon as the delivery guy handed it over to me only to realize it was empty, the UPS dude apologized claiming that since the box appeared damaged it could have fallen out somewhere in the transport. I will call summit tomorrow and explain the situation.
#735 |
back to the Sata 100 2.5 tip i ordered some Roth Flake to test how it handles flake, i might just save this gun for flake only.
#736 | |
#737 |
Sweet i just got off the phone with summit, there sending out a new one. Hopefully this one doesnt fall out the box.
#738 |
I installed the column & swivel ball. Luckily the ujoint fit.
#739 |
So the shaft came in today good job summit. After installing the header the limited space got eaven tighter but i managed to snake thru, after a few attempts. i just need to install the ball joint, but according to the calculations this is good to go.
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios Last edited by smokedat; 02-25-2012 at 01:12 AM. |
#740 |
Still Learning
Alex,
Question, If you only had enough cash to buy one Sata gun for Base coat Clear. Which model and size tip would you get? Or would I need a finer tip for one or the other? I was thinking I could get a cup for the base and one for the clear. I want to get a new gun before I paint my truck but don't have the funds to buy several different guns. My gun is so old it's a siphon fed Devilbiss. It was a great for single stage urethane but it waste so much paint it's not worth using on this job. Any help? thanks |
#741 | |
I would recommend the Sata 3000 hvlp with a 1.3 This would be an all around tip size if spraying solvent, for bases and clears. You dont need separate guns for base n clear if you dont plan on spraying for a living. just clean gun thoroughly after switching from base to clear. Since the launch of the 4000 series you could find good deals on Ebay on the 3000's. I just happen to like satas they work for me. Keep in mind that sata has a no price on line policy, and if you ever need sata acccesories like cups n regulators you most likely need to buy on line, or order from a distributor and if its not in stock it will be like 1-2 week wait. Alot of the guns i bought on ebay straight from distributors in Europe because they always have a better price than ordering from local shops.
I spray weld thru primer on structural steel with siphon fed guns and the switch to modern day gravity fed hvlp's is dramatic to say the least. Quote:
#742 | |
Still Learning
#743 |
Dupont makes a good product. Since you like Dupont i suggest Nason/Dupont, with chroma clear. good product at a fair price and availability carried by any local auto body refinish shops. Take a close look at the Kustom Shop line, they have really sweet colors available and the price is right. Just dont skimp on clear always try and get the best clear you can afford.
#744 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios Last edited by Sillyoldman; 02-28-2012 at 09:11 PM. |
#745 |
sarcasm will get you nowhere here
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by old Rusty C10; 02-28-2012 at 10:14 PM. |
#746 |
So i managed to get the steering going. The origianl idea of goin over the frame using the double u joint was creating some slop or feedback, so i had to change the lay out and decidedto go directly from the column to rack eliminating any chance of feedback or slop. In order to accomplish this i had to cut back the top of the frame, i will reinforce this area not to worried about it, i had no other option, but the result will equal in crisp steering.
#747 |
I also startded blocking the polyester surfacer with 220 catching any last minute inperfactions and reshooting with polyester again will water sand that with 600-800 and spray the sealer I will use House of Kolor K3005 wich is tinted blue designed to help save material and $ when spraying a shade of blue candy or pearl. I called a PPG rep to ask if i could tint my deltron sealer, and he said it was not possible, so i will save that for another project. As for the clear i changed my mind on the dupont and i will use Glasurit HS.
as for the blocking method i could water sand the polyester the first time around and shoot the sealer as the panels are true and guide coat is coming off even, but i dont want any compromises not messing around with this finish. I tested out my 100 BP and it handles polyester like nobodys business, lays it on smooth, so far i like this gun i still need to learn its ways to validate its worth
#748 |
The KD3000 series of primers are designed to be intermixed with each other to tint the primer closest to the base coat color being applied. This is important in reducing the number of coats of base coat saving $ on expensive paints like candys and pearls also in the event the finish is chipped or scratched the damage area won’t be as obvious.
#749 |
Beautiful work. I sure wish you lived like next door!
#750 |
Still Learning
You have some amazing skills with the bodywork. I appreciate all the help. More questions to come
Tags |
73c10, c10, cheyenne, ls1, swap |
