Old 02-16-2016, 09:05 AM   #751
mcbassin
Still Learning
mcbassin's Avatar
Re: Started my first frame off - 72 SWB LS1, 6-spd manual
Originally Posted by trkfrk View Post
After many hours of research, I have ordered my new rear end gears with posi traction. Now I will be able to use 5th & 6th gear on the freeway.
Congrats on the new gears Mark. I want to add a posi to mine but after my first go around with a gear swap, not too sure I want to tackle it.
I bet your truck will come out of the hole good with the 4:56.
mcbassin is offline   Reply With Quote
Old 02-18-2016, 10:56 PM   #752
trkfrk
trkfrk's Avatar
Thanks Mike. It was A/C or gears right now. I decided to go with the gears for now, and hopefully A/C before summer. The chart on the left is my current set up with 3:73. The chart on the right is the 4:56 gears. Right now I have to use a ton of clutch to come out of the hole, and it doesn't pull like it should. so as you can as see by the chart with my current setup 3:73 @ 2000 RPM in 6th gear I had to do 106 MPH, and with the new gearing @ 2000 RPM in 6th gear I will be doing 79 MPH on top end. What I have read and feel while driving these LS motors, they like to run between 2100-2400 RPM.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 02-18-2016, 11:04 PM   #753
trkfrk
trkfrk's Avatar
Dropped the rear end today. I figured it will be easier to rebuild it on the bench rather than climbing under the truck a 100 times lol.
Mark
Old 02-20-2016, 09:33 PM   #754
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
The 4.56 gears look like a great choice. Heck looks like even 4.88's could work well.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-22-2016, 11:54 PM   #755
trkfrk
trkfrk's Avatar
Kurt,
I think so too. I know I'm going to shift more, but I am going to have more usable gears. 4:88's would be fun though..
Mark
Old 02-23-2016, 09:48 AM   #756
Bowtiguy
Bowtiguy's Avatar
That's interesting. I had a little different experience and I think its due to the differences in gear ratios in each trans. I'm running a TR6060 out of a 14' Camaro SS ( along with its stock hydraulic clutch) and the ONLY time I use 1st gear is if I'm starting on a hill. I can easily start in 2nd gear with my 4:10 rear gears that Mark Williams axles installed for me when widening my 12 bolt and doing the c-clip delete.
The motor is a VVT LC9 out of a 13' Silverado. The issue I have is bogging at 75mph+ on the highway pulling 6th gear moving this brick down the road. But I'm also comparing it to my old LS7 C6Z that pulled 1800 rpm at 80mph and had 100 extra cubes and 350 extra hp.
Time for heads/cam!
Bowtiguy is offline   Reply With Quote
Old 02-24-2016, 12:44 AM   #757
trkfrk
trkfrk's Avatar
Time for heads/cam!
I totally agree with you, on the transmission gear ratios. Not until researching, did I learn which rear end gears to change to. I learned there are 2 different T56's; a close ratio and a wide ratio. I also didn't realize that my wheels and tires outside diameter, made a major difference. My outside tire diameter is 5" taller than the Pontiac TA with the same drive train.
Mark
Old 02-24-2016, 01:26 AM   #758
trkfrk
trkfrk's Avatar
Pic
Mark
Old 02-24-2016, 01:28 AM   #759
trkfrk
trkfrk's Avatar
Pic 2
Mark
Old 02-24-2016, 01:29 AM   #760
trkfrk
trkfrk's Avatar
Mike you're right, I really wanted the satisfaction of being able to rebuild my rear end myself. After I tore it down and started the assembly process, I realized I wasn't skilled enough for such a large task. So, for less than $300, I had Dan's Driveline here in Las Vegas do the assembly for me, & I'm definitely glad I did.
I just finished My test drive a couple hours ago
Mark
Old 02-24-2016, 09:22 AM   #761
Bennett68C10
Bennett68C10's Avatar
Nice choice on the 4.56 gears! How does that bad boy launch now?
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-24-2016, 01:07 PM   #762
slowcpe
slowcpe's Avatar
Love this truck. Gives me inspiration on mine.
Sorry if I missed it but what size rear tire are you running? I assumed I would go 4.11s in my t56 and never dreamed I would need 4.56s. Guess I need to do some research.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 02-29-2016, 09:41 PM   #763
trkfrk
trkfrk's Avatar
Thanks Keith.. So much fun to drive now. It feels like I added 200HP, no joke.
Thanks Ryan.. I'm running 295/45/20 in the rear which equals 30.45" diameter. Yes, definitely research it, because I also thought going from 3:73 to 4:11s would do the trick. A frend of mine that's big into the Rock crawling turned me onto the site that helped me figure out what I wanted. It takes the guesswork out of the equation, grimmjeeper.com. Make sure you know which T56 you have, wide ratio or close ratio. You're really going to enjoy your T56.
Mark
Old 03-20-2016, 11:54 PM   #764
trkfrk
trkfrk's Avatar
Loving my new gears! I have put almost 2,500 miles on the truck already without my interior done yet lol..
We're planing on going to the Brothers show in California July 10th, we can't wait. Hopefully have my interior done by then.
I haven't worked on the truck to much lately, but I have been able to get the garage back into shape. No more Home Depot chipping blue finish lol.
Mark
Old 03-20-2016, 11:58 PM   #765
trkfrk
trkfrk's Avatar
A lot of grinding
Mark
Old 03-21-2016, 12:04 AM   #766
trkfrk
trkfrk's Avatar
No color, just clear coat, Acrylic Urethane Sealer.
Mark
Old 03-21-2016, 12:11 AM   #767
trkfrk
trkfrk's Avatar
Still need to do second coat.
Mark
Old 03-21-2016, 12:17 AM   #768
mcmlxix
Collector of Projects
mcmlxix's Avatar
I ssw the truck at Cars and Coffee on Saturday. You were driving out so I didn't get to say Hi.
Hi.
Nice truck.
Rich
1972 K5 Blazer CST Click HERE
Old 03-21-2016, 07:58 PM   #769
trkfrk
trkfrk's Avatar
Hi.
Nice truck.
Sorry I missed you.. There were a lot of nice rides there. I plan on going Saturday.
Mark
Old 03-21-2016, 08:01 PM   #770
trkfrk
trkfrk's Avatar
Finished up the second coat on the garage floor this morning. I can't wait to get my truck back into the garage.
Mark
Old 03-22-2016, 12:53 PM   #771
HARDCORECASH
Garage looks great!!! Where did you buy the clear coat from??? If the concrete is fairly new without any paint or stains could you get away with just pressure washing??? Or should you grind the surface no matter what??? My garage floor is only 2 1/2 years old. Thanks for the help.
HARDCORECASH is offline   Reply With Quote
Old 03-22-2016, 04:04 PM   #772
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the garage floor!
Old 03-22-2016, 11:29 PM   #773
trkfrk
trkfrk's Avatar
I purchased all of the material from Concrete and Accesories here in Vegas. They specialize in concerte materials for contractors (industrial strength). I sanded the concrete down to expose the rock and to remove the blue Home Depot finish that was on the floor. The nice thing about grinding the floor was guaranteed removal of any stains/grease marks in the concrete.
Mark
Old 03-22-2016, 11:49 PM   #774
trkfrk
trkfrk's Avatar
Thanks Mike.. One less stress lol. Now it's time to get back to work on the truck
Mark
Old 03-23-2016, 09:41 AM   #775
roushinator
roushinator's Avatar
Nice work!
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
