Old 04-16-2022, 07:52 PM   #751
Johnl48
Re: 67-72 cab corner 6x9 speaker brackets
Pm sent
Old 04-26-2022, 02:50 PM   #752
AllGoNoShow
Went to install my brackets and realized the small floor brackets are different-one has elongated slotted holes which match up with the 2 holes in the bottom of the main speaker bracket- and the other has straight up/down elongated holes which are spaced 1/4-1/2 too short to have both holes line up with the 2 holes in the bottom of the main speaker bracket. What am I missing? (picture below)
AllGoNoShow is offline   Reply With Quote
Old 04-27-2022, 07:55 AM   #753
AllGoNoShow
Bigblock73,
Your inbox is full, but on a similar note to the above, the floor brackets are bent at 90 degrees, which considering the cab slopes done significantly at the point, would make it impossible for the floor bracket to be in contact with both the floor and bracket.
I already started fabbing up new floor brackets, longer, holes in right spots, bent at about 120 degrees, but just wondering if you may be sending out floor brackets for different years with the 67-72 main speaker brackets.
Old 04-27-2022, 11:15 AM   #754
bigblock73
yeller
bigblock73's Avatar
Originally Posted by AllGoNoShow View Post
Bigblock73,
Sent you a message just now.
bigblock73 is offline   Reply With Quote
Old 06-17-2022, 01:18 PM   #755
rpajr52
I would like a set with holes for 67-72.
Richard
rpajr52 is offline   Reply With Quote
Old 06-17-2022, 07:44 PM   #756
pgc
Junior Member
I would like a set with holes also
pgc is offline   Reply With Quote
Old 01-06-2023, 06:27 AM   #757
AllGoNoShow
Those of you with those brackets and carpet- are you guys running the carpet underneath the speaker brackets or just cutting the carpet short and buttoning against the bottom? Can't really tell from all the pictures.
Old 01-17-2023, 09:31 PM   #758
TxGary
TxGary's Avatar
Pm sent, I would like a set with holes. Thanks Gary
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2015 Chevy Tahoe LTZ 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 01-21-2023, 06:27 PM   #759
Flashy2003
I would like a set for 67-72 with holes. PM sent, Thanks
Flashy2003 is offline   Reply With Quote
Old 01-30-2023, 03:53 PM   #760
Joyridin
I will take a set with holes if you still have any. Thanks!
Joyridin is offline   Reply With Quote
Old 03-09-2023, 01:40 AM   #761
Cheyenne1970
I would like a set with holes if you have any available. Thank you
Cheyenne1970 is offline   Reply With Quote
Old 03-09-2023, 02:44 AM   #762
Trash
Junior Member
Trash's Avatar
I would like a set for my 67 with no holes. Thanks..
Trash is offline   Reply With Quote
Old 03-25-2023, 08:38 PM   #763
erick-1
erick-1's Avatar
Is the set with no holes still available?
erick-1 is offline   Reply With Quote
Old 05-16-2023, 09:18 PM   #764
MT65
Would like a set with holes for a 67 please, the ones in my 65 fit perfectly, so we’re going to do it again.
MT65 is offline   Reply With Quote
Old 07-22-2023, 10:32 AM   #765
OneBad71
Junior Member
Hi, could someone possibly show what mods they did to the passenger side lower bracket to install the speaker panel, pictures would be great .
Thank you in advance
OneBad71 is offline   Reply With Quote
