Closed Thread
Old 05-23-2013, 06:37 AM   #7726
jbgroby
jbgroby's Avatar
Re: What did you do to your truck today?
yep, just like the New Orleans region.
jbgroby is offline
Old 05-23-2013, 08:31 AM   #7727
zippeay
zippeay's Avatar
I was in Air Force and fixed a plane from Homestead in 2006, my Dad took me there when I was a kid and I was shocked at how much damage was still there when I went back. I still had an awesome time down there, caught a 48 Dolphin !
zippeay is offline
Old 05-23-2013, 04:21 PM   #7728
anubisani
anubisani's Avatar
u wont recognize it now
anubisani is offline
Old 05-23-2013, 06:00 PM   #7729
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Took another picture of it!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 05-24-2013, 08:21 AM   #7730
robber grin
Dang Steve - your truck looks G O O D... cool pic.
rg
robber grin is offline
Old 05-24-2013, 02:34 PM   #7731
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Wink Re: What did you do to your truck today?
Ordered my Bear Claw Latch Set from Summit Thursday and just received them today.
Will post pics soon of the install.
AutoLoc Bear Claw Latch Sets BCLGP
Power Door Latch/Popper Kit, Bear Claw Door Latch, Large, Set of 2
Brand: AutoLoc
Manufacturer's Part Number: BCLGP
Part Type: Power Door Latch Kits
Product Line: AutoLoc Bear Claw Latch Sets
Summit Racing Part Number: HFM-BCLGP
Door Latches Included: Yes
Door Latch Type: Bear claw
Attached Power Acuators Included: Yes
Manual Release Cable Included: Yes
Striker Mounting Hardware Included: No
Quantity: Sold as a kit.
These AutoLoc Bear Claw latch sets feature dual claws and striker bolts that provide awesome gripping strength and rugged good looks. They feature an all-steel mechanism and are the strongest latches on the market. They're perfect for doors with shaved handles because of their lever-action triggers, 3-stage locking system, and 5-coil steel springs, which allow the Bear Claw latches to generate over an inch more throw than many types of doors. Available in small or large sizes, these Autoloc Bear Claw latch sets are sure to make your vehicle's doors operate more efficiently.
http://www.summitracing.com/parts/hfm-bclgp
AutoLoc Bear Claw Latch Installation Kits BCINST-L
Installation Kit, Bear Claw Door Latch, Large, Set of 2
Brand: AutoLoc
Manufacturer's Part Number: BCINST-L
Part Type: Door Latch Assemblies
Product Line: AutoLoc Bear Claw Latch Installation Kits
Summit Racing Part Number: HFM-BCINST-L
Door Latch Material: Steel
Quantity: Sold as a pair.
AutoLoc's bear claw latch install kit makes installation a snap! Autoloc uses state of the art cad construction technique to insure ultra accurate constructions resulting in easy installation and alignment even for the "weekend mechanic". Heavy duty all steel construction insure a long life of smooth operation. Kit includes door section mounting plates with die stamped screw holes to avoid scraping your door sill paint when closing. Kit also includes floating sticker bolt plates to insure easy alignment and installation.
http://www.summitracing.com/parts/hfm-bcinst-l
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Old 05-24-2013, 02:36 PM   #7732
vin63
It's Better With Nitro
vin63's Avatar
Cool...are you doing a suicide door set up?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 05-24-2013, 03:36 PM   #7733
1Bad62Pro/Street
Yep!
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
Old 05-24-2013, 08:43 PM   #7734
ACK
ACK's Avatar
Put in a fresh transmission filter, rear seal, plus new cooler lines; drilled the frame and installed the tranny cross member so it's no longer on an angle and hanging on by 2 bolts; tinkered with the e-brake assembly I made; changed the oil & filter; put everything back together, but ran out of sunlight, so knock on wood tomorrow I'll be driving her after a month of having her up on jacks.
My truck ain't dead, it just smells funny.
ACK is offline
Old 05-24-2013, 10:59 PM   #7735
pdxhall
pdxhall's Avatar
I flipped the cab on it's back and started its clean up. It was much nicer than I thought. NO undercoating. The cleaning so far took less than an hour with a scotch brite and my shop vac. Just dirty.
pdxhall is offline
Old 05-24-2013, 11:24 PM   #7736
porter90
porter90's Avatar
gathered the final parts to put a t-5 in my 64!! i just need it to stop raining long enough for me to crawl around and do it!
porter90 is offline
Old 05-25-2013, 12:18 AM   #7737
FetchMeAPepsi
FetchMeAPepsi's Avatar
I replaced my old beat up door with a donor door from CoyoteRun, who is a great mechanic and all around good guy. Need to do the rocker too though. It shows more with a straight door that isn't um..."blended" well with it's own big dent.
Before:
After:
Read about it if you're bored:
http://6066gmcclub.com/forum/showthread.php?p=48809
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline
Old 05-25-2013, 12:20 AM   #7738
FetchMeAPepsi
Congrats on the progress. Now that's a full day! I'd be lucky to get half that done in a day
Step by steps:
Old 05-25-2013, 03:56 PM   #7739
bhc41051
bhc41051's Avatar
This is my method for mounting my cab back on my frame.. I'm such a hillbilly.. Kids don't try this at home...
bhc41051 is offline
Old 05-25-2013, 06:03 PM   #7740
CRGRS 66
CRGRS 66's Avatar
So... you set the wood on fire, and cross your fingers?
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 05-25-2013, 06:20 PM   #7741
WCHLVR
WCHLVR's Avatar
Tired of not having a place to set a drink in Brutus so I whipped this up for $7! Pleased with how it came out. Simple, stable and almost invisible unless you are looking for it!
WCHLVR is offline
Old 05-25-2013, 06:24 PM   #7742
61_FL_Apache
Who Me?
I like that cup holder..
Steve
2001 Blazer 4D 2WD
Old 05-25-2013, 07:58 PM   #7743
robber grin
Did my first pipe or C-notch today and it wasn't half bad...
Even though I measured and worked off the trailing arm I messed it up since I didn't consider the 2" drop blocks...
Soooo the bad half is it's an inch or so too far back on the frame...
Oh well - cheap education - just hate to mess up when it's avoidable.
Live and learn -
rg
Old 05-25-2013, 08:02 PM   #7744
61_FL_Apache
Who Me?
Live and learn -
rg
Post some pics of you have some.. I thought of doing the pipe notch on mine too.
Steve
2001 Blazer 4D 2WD
Old 05-25-2013, 08:21 PM   #7745
jbgroby
jbgroby's Avatar
Got bored and put my rear bumper on.
jbgroby is offline
Old 05-25-2013, 08:26 PM   #7746
markeb01
Senior Enthusiast
markeb01's Avatar
Solved a pesky leak from the recent engine swap. It was a loose bolt on the back of the power steering pump. Probably loosened it up to remove the pump, and never went back to check or tighten it since nothing attached to it. Apparently it went into the reservoir as tightening it up eliminated the problem.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 05-25-2013, 08:38 PM   #7747
TxRat
TxRat's Avatar
Nothing fancy...
TxRat is offline
Old 05-25-2013, 08:58 PM   #7748
1964Chevy
1964Chevy's Avatar
What's a "pipe Notch"?
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb
1964Chevy is offline
Old 05-25-2013, 10:00 PM   #7749
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Thats a wicked color.......great choice
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline
Old 05-25-2013, 10:14 PM   #7750
wutnxt
Okay I am a little behind.....But I washed the 58 and headed out to find my buddies.....so we could drive the wheels off of some stuff
wutnxt is offline
Closed Thread
