Old 09-14-2016, 06:09 PM   #801
chad64chevy
chad64chevy's Avatar
Re: Greg65 build thread
another step closer greg
chad64chevy is offline   Reply With Quote
Old 09-15-2016, 08:37 AM   #802
greg65
greg65's Avatar
Thanks Chad
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 09-15-2016, 08:46 AM   #803
greg65
greg65's Avatar
Got the filter mounted to the frame last night. I'm still waiting on my hose and fittings that I was expecting to arrive Friday but will now be here next Wednesday. Amazon has better prices but the delivery needs some work.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 09-15-2016, 10:06 AM   #804
66ChevyMax
66ChevyMax's Avatar
Looking good
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 09-16-2016, 08:33 AM   #805
greg65
greg65's Avatar
Originally Posted by 66ChevyMax View Post
Looking good
Thanks Craig.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 02-25-2017, 01:36 PM   #806
greg65
greg65's Avatar
It has been a while since I have posted any progress on the truck. I. Did manage to get the rest of the fuel lines made and installed. I used Russell fittings and line and really like how they turned out.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 02-25-2017, 01:52 PM   #807
greg65
greg65's Avatar
I also relocated the trans cooler from the crossmember to the frame right under the radiator. Now I can take advantage of the radiator's internal cooler as well as the external cooler. Decided to go with Summit's fittings. Really felt good working on the old truck again.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 02-25-2017, 03:55 PM   #808
siggyfreud
siggyfreud's Avatar
Looking good! I too have used both the Russell fitting as well as Summit's brand. Both have come together equally well, though I haven't actually used fluid through either setups yet.
siggyfreud is offline   Reply With Quote
Old 02-26-2017, 09:29 AM   #809
likaroc13
Rollin' Old Skool
Nice to see you making some more progress Greg! It does feel good to get out there & tinker with stuff.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 02-27-2017, 03:05 PM   #810
greg65
greg65's Avatar
Looks like we are in the same boat. The truck has been put on the back burner for a while and really looking forward to getting it back on the road.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 02-27-2017, 03:07 PM   #811
greg65
greg65's Avatar
Yes it does Phillip. I know you will be stoked to get your truck back running again.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 02-27-2017, 04:41 PM   #812
The1960APE
The1960APE's Avatar
This is a really great build thread! I like how clean everything looks! NICE WORK!
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline   Reply With Quote
Old 02-28-2017, 10:11 AM   #813
likaroc13
Rollin' Old Skool
Yes sir! Can't wait to get it on the road again.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 02-28-2017, 10:38 AM   #814
66ChevyMax
66ChevyMax's Avatar
Good to see the update, one more step for the Chevy Truck!
Craig
Old 02-28-2017, 11:54 AM   #815
greg65
greg65's Avatar
Thank you Sir.
Can"t wait to see some pictures of you and Webb on his first ride.
Thank you Craig.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 03-01-2017, 09:26 AM   #816
likaroc13
Rollin' Old Skool
Can't wait to see some pictures of you and Webb on his first ride.
That'll be a neat day for sure! Gotta work on getting some seat belts installed.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 03-01-2017, 11:06 AM   #817
aggie91
I'm just glad to be here!
aggie91's Avatar
Glad to see you back on it. I like where you mounted the trans cooler to make it cleaner to use the one in the radiator too.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-02-2017, 10:01 AM   #818
greg65
greg65's Avatar
Thank You Karl.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 05-02-2017, 10:19 AM   #819
greg65
greg65's Avatar
Look what big brown dropped off today. Big thanks to Matt at MCB's for the great price on my wiring kit. Since the front wiring will be run under the inner fenders I need to mount the fuse panel and drill the hole on the firewall. Hopefully I can get that done this weekend.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 07-10-2017, 12:10 PM   #820
greg65
greg65's Avatar
I started working on my cowl side panels this weekend. The passenger side had a couple pin holes right behind the antenna opening. After bead blasting and welding the area, I cleaned both pieces and applied POR 15 to both. Here are a couple before and after pictures. Now for a little filler and sanding.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 08-10-2017, 08:33 PM   #821
flips72
flips72's Avatar
Looking good Greg, fuel lines are awesome.
flips72 is offline   Reply With Quote
Old 08-11-2017, 08:26 AM   #822
greg65
greg65's Avatar
Thank you sir. With a seventeen and a fifteen year old I don't have a lot of truck time. But it will get finished one day. Hopefully. My daughter Jordan getting her senior pictures made and my son Evan at his Spring game with his friend Tyler. I hope all is going good with you and thanks for checking in.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 08-12-2017, 10:47 AM   #823
likaroc13
Rollin' Old Skool
Great looking young lady & man you have there, Greg. I know you're proud of them. I'm learning all too well about lack of time these days!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 08-14-2017, 08:17 AM   #824
greg65
greg65's Avatar
Thank you Phillip. The older they get the more activities they get into. But I wouldn't trade it for anything.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 01-26-2018, 11:05 AM   #825
greg65
greg65's Avatar
I haven't posted in a while but here are a few updates. Took the truck to my brother in law's shop to get the fenders and front panel lined up. As usual with aftermarket replacement sheet metal I had to slot some of the holes for proper fitment. The grille mounting panel was a little high on one corner so we had to modify it a little.
1965 c-10 swb
2004 tahoe
1993 mustang gt
