Old 04-27-2015, 12:39 PM   #801
SCOTI
SCOTI's Avatar
Re: Project: Recycle
Originally Posted by rwade View Post
Great! I hope so. But I'm sure I can't be as ready as you are
Wade
It was nice just seeing the chassis (it's been a while). But, getting reaquainted allowed me to notice some items that were not quite up to par so they'll need to be addressed once I get back on it. Mainly just some hardware items that were oxidized/rusted already so just detail stuff.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-27-2015, 01:45 PM   #802
likaroc13
Rollin' Old Skool
I agree, it would be great to see this up & going again! I know that feeling of getting reacquainted, & I'm really hoping to get back to mine soon as well.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 04-27-2015, 07:37 PM   #803
northern 85
northern 85's Avatar
If the seats are in the cab i would love to see how they look! I have a set, and was wondering if the 67 68 bracket bolts up in the 66 cab??
northern 85 is offline   Reply With Quote
Old 07-21-2015, 10:17 PM   #804
northern 85
Bump for a cool truck!
Old 07-22-2015, 10:11 AM   #805
SCOTI
SCOTI's Avatar
I apologize.... I never saw your request for pics. The seats are in the cab but they're covered up in plastic & the truck is basically a rolling shelf/storage table for misc parts while my dually & the el camino are dis-assembled.
The dually is nearing the end of it's revitalization & the el camino should be headed home by end of the month so the 64 is about to get some attention. I can get you those pics then.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-26-2015, 07:17 AM   #806
northern 85
Thanks dude!
Old 02-07-2017, 02:45 PM   #807
SCOTI
SCOTI's Avatar
Dusting this off. My goal was to have the exhaust finished up by the first of this year so I can get to swapping the body over.
I made good progress getting everything plumbed through the T/A x-member but then plumbing the tubing within the packaging restraints slowed progress significantly. My buddy Danny (Painter D) has been busting butt on his latest project which stoked my fires. I pushed hard last week to finalize everything & really liked what I had laid out. I had everything from the T/A x-member back tacked together & the only remaining thing was to finish the placement for the back half exhaust hangers but I was @ a roadblock. I came back to the shop Monday AM & w/a different day came a new idea.
I was excited that I had my plan & could now order the remaining parts. I placed my order through Summit & then went back over @ lunch to take some pictures & it hit me like a head-on collision @ speed..... My layout immediately after the T/A x-member failed to account for the positioning of the rear cab wall. Since my frame is Z'd, this is fairly important. Talk about getting the wind knocked out of your sails.
After work, I took multiple measurements & the routing path I took was just not going to work w/o cutting up the back of the cab. I used 45° elbows which allowed a nice/smooth transition but required too much area/length to go from the T/A x-member exhaust ports up to the mufflers (about 6-7" difference). I pulled everything on the back half back apart to try & re-clock the mufflers to reduce the gap. No go.... The mufflers are as high as comfortably possible while allowing airflow for cooling & space for clearance. Rotating them caused them to be too high, killed the hanger plans, & would require re-working the tail-pipe sections as well.
I walked away for some dinner & had a couple of beers. I went back & did some additional measuring. I ran a string line to lock down my limitation (back cab wall/support + ~1"). I removed my 45° pieces & did some more math. By 1am this morning I felt I had worked around the issue but now it will take some tedious grinding as the pieces I need to use were all cut from demo'd pipe so they aren't 'true/square' cuts.
Regardless.... the mufflers stay in the same spot which means the hanger portion (& parts ordered) won't change nor will I have to re-pipe from the mufflers back. I hope to have things tacked-up by the end of the week when the hanger parts arrive. Once they are in place, we can yank everything & do the final welding & clean-up on the outside surface of the exhaust.
Progress!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-07-2017, 03:09 PM   #808
darkhorse970
darkhorse970's Avatar
I'm glad to see your progress here! It motivates me to get mine moving.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 02-07-2017, 03:19 PM   #809
SCOTI
SCOTI's Avatar
Thanks. I've had my chassis back @ my shop since about April '16. I had hoped to get back on it sooner but my DD 90 got whacked which forced my dually into DD service before it was quite done. Been chipping away @ the dually list & did a SS exhaust on a 56 Chevy wagon for a buddy in a labor swap (he fixed & painted my banged-up 90/I paid for the parts; I did his exhaust/he paid for the parts). Once all that was done, I've been trying to move forward on this dusty project.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-07-2017, 03:57 PM   #810
aggie91
I'm just glad to be here!
aggie91's Avatar
Glad to see you back on this one. You think you can have it together for C10's in the Park this year? If you need help with the body swap, give me a shout. I am still interested in getting that LWB frame...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-07-2017, 04:43 PM   #811
SCOTI
SCOTI's Avatar
Not sure on C10ITP but you never know.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-08-2017, 09:19 AM   #812
likaroc13
Rollin' Old Skool
Glad to see you back on it & making progress! Hoping to post some much overdue updates on mine soon as well.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 02-10-2017, 03:59 PM   #813
SCOTI
SCOTI's Avatar
Boom, driver side is 95% good to go. I still need to tack the very last straight piece as I had to shorten that section since the use of the 90° elbows still required shifting the muffler back. It is followed up w/a another 90° section & just stops there for now. I need the bumper & brackets on before I can route the final tail pipe section.
Now back to correct the pass side. Hopefully it goes faster since it should be a repeat of the driver side drill....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-13-2017, 01:54 PM   #814
SCOTI
SCOTI's Avatar
What should have went faster & easier took longer and was definitely more tedious. I wound up have to go backwards on the pass side to keep things consistent. Not sure how/where things got so different side to side when visually it appeared very equal (and each side was set-up w/the same strategy).
Regardless, I pushed through. It's ready to come back out for final welding....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-14-2017, 01:06 PM   #815
likaroc13
Rollin' Old Skool
Nice work!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 03-06-2017, 04:48 PM   #816
SCOTI
SCOTI's Avatar
I was waiting on a few parts ordered but for now, the exhaust is done (3/4's of it). What's in place is now fully welded. Everything lined up pretty well & went in w/o much fuss but 1pc will need to be re-worked because of heat/warping. I could make it all work but it would be in a bind so I prefer re-working the piece (increase the length of the H-pipe).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-06-2017, 04:55 PM   #817
SCOTI
SCOTI's Avatar
With the front portions of the exhaust wrapped up, I needed to finish one last item on the rear suspension. I built my own Panhard bar frame mount & knew early on that I needed to make it a little more robust. I left things alone until other items were in place & I could determine my options. I opted to triangulate the mounting bracket to the opposite side frame structure vs adding to the frame mount. I took measurements & was looking up parts on the net when I decided to "recycle' yet another piece from previous builds & make it useful again....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-07-2017, 12:58 PM   #818
aggie91
aggie91's Avatar
I like that triangulation!
I need to do the same thing to mine...
Karl
The LST Challenge:
Old 04-27-2017, 11:25 AM   #819
SCOTI
SCOTI's Avatar
Had to take some time to clean up the shop so things could be shuffled around. After the dust settled, I got the 64 moved over to the 'fab' side of the shop & got it lined up to prep for the sheet metal swap.
Sunday yielded progress....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-27-2017, 11:27 AM   #820
SCOTI
SCOTI's Avatar
Then on Tuesday, my buddy Matt came over after work to lend a much needed extra set of hands....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-27-2017, 11:29 AM   #821
SCOTI
SCOTI's Avatar
Then, last night I got after it again so I could see what I was up against & prep accordingly.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-27-2017, 12:05 PM   #822
watahyahknow
watahyahknow's Avatar
a while back i seen a chassis swap for a ford truck on hot rod garage
they changed the frame with one from a Ford Crown Victoria cop car
wonder if theres a chevy version of that swap too
a had seen someone who gotten a older style corvette frame to fit under a truck like that
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 04-27-2017, 12:39 PM   #823
SCOTI
SCOTI's Avatar
The Crown Vic front x-member swap is common for Ford trucks. Add a 4-bar set-up from FatMan Fab & your done. These already had a decent starting platform & are easily updated w/later year (thru 87) parts plus the T/A set-up offers great all around performance. Not sure why one would go through all the fab work of swapping a frame from something unless it was a fairly easy swap.
I believe a board member did swap a C5 vette chassis & modified accordingly. There's a build thread on it....
http://67-72chevytrucks.com/vboard/s...d.php?t=655105
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-27-2017, 01:25 PM   #824
hewittca
hewittca's Avatar
Cool build. For some reason I never saw your build threads before despite reading many of your posts on the boards. You should link your builds in your sig! I wish I would have seen this before I did my rear frame Z. I might have done a few things slightly differently.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 04-27-2017, 01:31 PM   #825
watahyahknow
the reason hot rod garage did it was because the front and rear suspension from a crown vic was a lot better than the original 60s suspension . it had rack and pinion steering , it had the gearbox (forgot if it was a gearbox or automatic on the show) with the overdrive gear in it and the engine was stronger / better / more fuelefficient too
i seen modern engineswaps fairly often and most of the time they start with a donor car as they need a lot of the smaller parts to get it to work , i just figured it be a good idea to replace frame with the suspension too
the guy that did the corvette frame swap was looking intoo better handling and had a wrecked corvette and a chevy cab bed and nose laying around
seen pictures of it years back , he told me he brought it in once to have it serviced
the guy asked him wat happened to the frame as it was shaped so weird for a truck he just said he repaired a fenderbender
