Old 04-18-2012, 10:30 PM   #826
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by woodwright View Post
What I was getting at, is if you are not gonna need AC, you can adapt a 70s or 80s chevy non-AC truck heater. the outer air box is pretty small.
No, this turd is getting a/c and I'm going to use the stock stuff. I can make the turbos fit around it one way or another.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-18-2012, 10:50 PM   #827
ryanroo
ryanroo's Avatar
Originally Posted by 6lcummins View Post
For the hard to find part of it, but when you make over 500HP the gear to gear wont hold the 1000lb ft of torque very well. NP241DHDs hold well over 1800lb ft and are easier to find.
Originally Posted by Dieselwrencher View Post
What he said.
I've broken inputs and outputs with a divorced 205 truck I had. Then I put a 29sp in it and did it again. Then I purchased the pro fab billet parts and broke those. No warranty and no money back from that deal so yeah I'm nervous of 205's with diesel power.
this is interesting. in the world ive been living in (off-road and rock buggies/engine conversions) that was not ever the case. 205s are god there. or of course the atlas if you have that budget. i love my 205 in the hunk-o-jeep. i rage the weewee out of that 6000# BBC rattle factory and never have an issue.
i may have to reconsider my ideas on t-cases considering the chances of smacking the case on a rock is near non-existent for my build. opens up some options anyhow. do you see a difference in the rate of explosion auto vs. manual?
as far as hard to find cases, i can turn GM small bearing cases into big bearing cases pretty easily. i have 3 in my garage that would make wonderful figure 8 big bearing cases with little effort.
ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-18-2012, 11:24 PM   #828
ryanroo
ryanroo's Avatar
sorry to hijack. i assume you need to run the early late 80s-early 90s 241? is this the same strength as the dodge 241dhds? i cant find reference to a p-drop dodge 241 case anywhere. also, the GM versions will have a 32 spl. input and the dodge tranny has a 29 or 23 spl input. swapski?
how do you plan to attach it to the dodge tail housing? as far as i know the 6 hole pattern is incompatible as far as clocking goes.
thanks
ryan
72 K20 12v build
Old 04-18-2012, 11:24 PM   #829
jbclassix
Junk Yartist
jbclassix's Avatar
Since all of you guys are all talking about blowing up NP205's behind a diesel, do you guys think I will be ok running a 205 behind a 6.5L/NV4500 turned up to 300hp?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 04-19-2012, 12:24 AM   #830
6lcummins
thanks
ryan
The ones we use are for dodges, would be 94-present if you are looking for tcases. Will have to flip them though and do a few mods. NP241DLD, NP241DHD, NP271, and NP273 are all factory Dodge T-cases.
You should be fine, it's when you get over 500HP the issues start.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 04-19-2012, 12:29 AM   #831
jbclassix
Junk Yartist
jbclassix's Avatar
If I get that out of a 6.5L I will have bigger problems than a weak t-case!
-Jeremy
Rebuilding an NP205
Old 04-19-2012, 10:33 AM   #832
mknittle
mknittle's Avatar
Given the size of the wheel wells on these trucks vs wheel travel a well mod wouldn't hurt if it comes to that. For turbo clerance.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-19-2012, 02:13 PM   #833
Dieselwrencher
thanks
ryan
I plan on using a 241dhd from an auto trans pending it has the speedo set up on the tail shaft. If it doesn't I'll have to use a 241DLD from my brother's truck. I will reclock it where I need it and modify the pick up tube for the oil pump in the tcase. Another advantage to a 241 over the 205, is the 241 has a lower low side.
Ryan
Old 04-19-2012, 02:13 PM   #834
Dieselwrencher
I think you better cross your fingers and start praying now for the 6.5.
Ryan
Old 04-19-2012, 02:15 PM   #835
Dieselwrencher
That's what I'm thinking. I will cut out the wheel well on the RH side and cut modify what I need to to get them in there and route the exhaust according.
Ryan
Old 04-19-2012, 03:19 PM   #836
MrBeast
high-Tech Red Neck
MrBeast's Avatar
I have had 3 6.5's that was 4 too many!
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 04-19-2012, 06:46 PM   #837
6lcummins
300HP is asking a lot out of one of those...
"STOCK"
ASSEMBLY THREAD
Old 04-19-2012, 07:52 PM   #838
Dieselwrencher
Today I ordered my billet freeze plugs for the engine and a seat heater for it. More parts for the pile.
Ryan
Old 04-19-2012, 09:05 PM   #839
mknittle
mknittle's Avatar
I need a steering wheel and shift knob heater.
Mark
My GMC build.
Old 04-20-2012, 10:07 PM   #840
ryanroo
ryanroo's Avatar
a little something from colorado for your longhorn. i'll need a shipping address. i also promise not to be so slow in shipping it that you have to wait to drive it because of me. more tomorrow on the reason i had to pull it tonight.
ryan
72 K20 12v build
Old 04-20-2012, 11:40 PM   #841
Dieselwrencher
No need to ship it in a hurry man! Believe me you wouldn't be holding me or it up. Thanks, PM coming.
Ryan
Old 04-27-2012, 07:41 PM   #842
Dieselwrencher
Making a little progress on the pumpkin. Starting to get turbos on this thing.
I took apart one of our 241DHD auto tcases, and converted it to 5 speed. I then placed it on the transmission to see what it looks like. I think it'll work fine with some work.
Ryan
Old 04-27-2012, 10:49 PM   #843
pickup67man
pickup67man's Avatar
I'm still new to the diesel game. How much heat comes off the turbo when your egt gets high. The turbo seems a little close to the fiberglass hvac box. Love the build, wish I knew more about custom diesel building for my suburban.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
Project Family Hauler
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 04-27-2012, 10:59 PM   #844
Dieselwrencher
Usually while regular driving exhaust temp gases are around 500-750*. While towing they are usually from 750-1150*. (The reading is taken before the turbo in the exhaust manifold, and usually is 250* less after the turbo.) On this truck I'm going to guess it will see 1200*+ bursts when I get bigger injectors. On my F-350, which I DD and tow with constantly, the turbo exhaust housing is literally 1/4" away frm the HVAC box, and it hasn't discolored or melted yet. (I've put about 30k on it in a year too.) This pic isn't very good, I'll get a better one tomorrow. If it gets too hot for the HVAC housing, I'll put a turbo blanket on it.
Ryan
Old 04-27-2012, 11:06 PM   #845
ryanroo
ryanroo's Avatar
i sure am glad you are making progress because i am at a dead stop. DD blew a head gasket thursday and my jeep is having EST issues. jeez...
that t-case looks all confused, but it looks like you should be able to fit 5" tube through there pretty well.
i bet the HVAC housing doesn't even blink. a 1/4 of air is enough to really insulate the heat. if the exhaust housing on the turbo starts to glow then it might melt that sucker but if that is the case i think you have bigger problems.
looking good sir
Ryan
72 K20 12v build
Old 04-27-2012, 11:15 PM   #846
jbclassix
Junk Yartist
jbclassix's Avatar
TurboS? I like what you did with the T-case. Are you just going to plumb the oil pump externally for it?
-Jeremy
Rebuilding an NP205
Old 04-28-2012, 12:15 AM   #847
mcbassin
Still Learning
mcbassin's Avatar
Hey hey, nice progress Ryan! glad to see you wrenching on this thing again.
mcbassin is offline   Reply With Quote
Old 04-28-2012, 09:15 AM   #848
Dieselwrencher
looking good sir
Ryan
Thanks. Sorry to hear about your vehicle issues. I feel your pain. my F-350 has wanted a part a week some times. I guess it's mad I spend more money on the Longhorn now. Hopefully today I can get the primary turbo mounted and I'll show the pics of the problem area.
Ryan
Old 04-28-2012, 09:17 AM   #849
Dieselwrencher
I was actually thinking of trying that and putting the pick up in the drain plug port. Too bad I already sealed this case up. It was supposed to go on my brother's dodge, but he's letting me use it for now until I get our other one rebuilt for his truck.
Ryan
Old 04-28-2012, 09:18 AM   #850
Dieselwrencher
Thanks, I'd like to get this thing in as little pieces as possible soon. Is that possible?
Ryan
