04-04-2017, 10:40 PM | #826 |
Re: 55 Wagon Progress
Back in the shop this evening, time to make some bolting brackets to hold the seat back frame to the floor..
Locating... Brackets TIG welded on.... This shows it in place, we have about 1/4" clearance at the tight spots.... https://www.youtube.com/watch?v=jB5qRfP7IxY The cleco's were removed and 1/4-20 AVK rivet nuts installed in the floor... Missed that picture... Next will be the top support....
Robert Last edited by MP&C; 04-05-2017 at 12:16 PM. |
04-09-2017, 10:33 PM | #827 |
Now for the top of the seat frame... We started with some 3/8-16 standoffs that are 5/8 diameter, and turn them to 1/2 diameter to fit inside the seat frame tube...
Then holes are drilled in some 1.25 square tubing... Tacked in place and a nut used for added insurance... Seat latches plug welded in place... Side pieces formed.... The side pieces will be trimmed, fitted, and welded to the wheel well...
Robert |
04-09-2017, 11:27 PM | #828 |
Robert, you sure make some great pieces, love the attention to detail, that some may never see...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
04-16-2017, 12:34 AM | #829 |
Thanks Jim!
More work on the seat back bracket... Trimming the side pieces to match the wheel well... Adding welding flange, hammered out of 16 gauge steel.. Test drive.... https://www.youtube.com/watch?v=mpFl01yHvKw Used the Roper Whitney hand punch to make our plug weld holes.. Next we'll close off the back area to contain the amp and bass speaker.
Robert |
04-17-2017, 07:38 AM | #830 |
The close up photos really do help! Thanks for posting.
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
04-18-2017, 03:41 PM | #831 |
Impressive work on the seat frame Robert. Appreciate the documented details ... thanks for sharing.
04-18-2017, 08:59 PM | #832 |
looking great, as always.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
04-19-2017, 01:27 PM | #833 |
Wow! I'll be stealing that square tube rounding trick! Nice stuff!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
05-17-2017, 07:15 AM | #834 |
Thanks for all the comments
Had a short evening in the shop as I was busy packing the neon clock for shipment, so the remainder was spent working on some of the many final details of the rear seat. Here are the factory seat clips to hold the seat bottom in place. In order to use these, let's do a sample and see if we cut a hole in some sheet metal that they'll fit into.. This looks like it will work, we'll get some 18 gauge strips made to hold these that 45 down to the floor, adding some bead details for strength..
Robert |
05-18-2017, 11:07 PM | #835 |
Time for some brackets for the rear seat bottom retainers. Cut out some 19 gauge...
Drilled some holes for an inside radius, and trimmed the corners for the floor pan flange.. Now to fold some flanges on the sides for strength, using the Diacro press brake and a 1/2" thick lower die. By adding some rare earth magnets to the back side to serve as a back stop, we get a perfect 1/4" flange... Then some back and forth between the Erco kick shrinker and the press brake with a narrow die inside the folds.... and we have 45* bends on either end of our brackets... Test fit.... and trimming the retainer hole...
Robert |
05-18-2017, 11:21 PM | #836 |
Robert, when you make up your parts, it leaves my without any words to say, just over the top...Jim
05-21-2017, 09:44 PM | #837 |
Thanks Jim!
Had our new apprentice started today, while I cut out the hole in the second seat bracket, Mike got started on punching and drilling holes for plug welding the passenger bucket seat bracket... After I got the bracket hole cut out, E media blasted the brackets and added some SPI epoxy using a brush. We mainly wanted to get the bottom side well covered as it will be inaccessible once welded in place.. First coat... Two coats, that should hold us for under a seat... Meanwhile I got out the John Deere rod bender to see if we could make up some anchors for the shoulder belt.. Bent with relief for a 1/2-13 lock nut.. Welded with short bursts and plenty of cooling between to keep the nylon lock intact.. test fit... plug weld holes drilled and welded in place.... Mike finished up plug welding the seat bracket in place...
Robert |
05-23-2017, 10:23 PM | #838 |
Had a late start in the shop tonight as I had to go look at a school bus. Yeah, week and a half to go until the end of school.
Looks like something gave the spot mirror a nice push.. The mirror mount looks like it's no longer straight.... OK, so we found it hard to fathom something hitting the mirror that high in the air as the bus was driving into it, so the other possibility was something backed into this one.. A quick search of the buses parked close by revealed this one with some nice shiny metal showing... A quick test drive showed that the mirror didn't vibrate/move around that much so we're going to address this after school is out so this one can still be used for the next couple weeks.. Back at the shop, time to weld in the seat retainer brackets... https://www.youtube.com/watch?v=o9Gj...ature=youtu.be ....and then started the next shoulder harness anchor bracket....
Robert |
05-27-2017, 11:31 PM | #839 |
Pilot hole drilled for the passenger B-Pillar.....
The center point is spring loaded, but they seem to locate better using a pilot hole vs. just a punch... The plug weld holes drilled for the anchor and paint cleaned off in prep for welding.. Apprentice E worked on smoothing off the plug welds from last week.. Welding in the anchor ..... For the lower anchor point, which will hold both the retractor and the lap belt, we used some 14 ga that will be plug welded to the back side of the inner quarter panel just behind the B Pillar.. A 1/2" lock nut is welded to the back side, and a spacer added to the front side to keep the lap belt off the side wall. Or the motion picture version.... Thanks to duallyjam for stepping in for hand model duties in the video... https://www.youtube.com/watch?v=4na-...ature=youtu.be
Robert |
05-28-2017, 09:31 AM | #840 |
Robert, just more nice work...Jim
05-28-2017, 05:39 PM | #841 |
First let me say thanks for the invite to hang out in your shop for the day and it's probably a good thing I don't live closer as I would never leave.
The craftsman ship on the 55 is just as described in this thread but seeing it in person puts it on a whole nother level.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
05-28-2017, 06:59 PM | #842 | |
05-28-2017, 11:28 PM | #843 |
You guys are too much! James, stop by anytime..
Robert |
05-30-2017, 10:29 PM | #844 |
Tonight we have both seat belt retractor anchor plates welded and waiting for apprentice E to media blast and epoxy prime..
Next, we have the side filler panels to either side of the fold down rear seat that don't fit with those pesky wheel tubs in the way... So we plan to make new ones, with a relief to fit snugly to the wheel tubs at the bottom end.. We used the Baileigh MH19 hammer and the shrinking dies to shape a piece of 14 gauge cold rolled to fit the wheel tub. Glad I didn't have to do all that shrinking by hand. A flat piece from the top section will be welded to this piece, and then foam will be glued to the assembly and upholstered to match the seat..
Robert |
06-05-2017, 11:34 AM | #845 |
To catch up on the wagon, the seat belt retractor anchor bracket will be located inside the quarter panel, here we are laying out for the plug weld holes that hold it in place...
Holes piloted, then use the burnishing brush to remove the paint from the weld area... Then the holes are enlarged for plug weld size, I use a letter A and plenty of heat. Back to our rear seat back modification, some 14 gauge steel is shrunk in the Baileigh MH19 to fit the driver's wheel well.. After some cleanup on the Tommasini cast wheeling machine... Meanwhile, Mike has media blasted the anchor brackets and is here spraying them with SPI epoxy primer... The 14 gauge is then held to the wheel wells and marked a line parallel to the seat frame. We'll use this line to start the transition to flat, using a linear stretch die in the MH19. Linear stretch die also used to add this detail to blend into the bottom part... Tacked together and fitted.... Tig welded.... This should JUST hide the wheel well, but doesn't look like the foam will be all that thick at the bottom... Weld dressed and another fit, I was going to trim the sides but we'll be adding some stiffener beads to the flat area, so we'll wait until after that process to trim the sides.
Robert |
06-05-2017, 03:41 PM | #846 |
Excellent detail as always...Jim
06-12-2017, 12:13 AM | #847 |
Thanks Jim!
Saturday Mike worked on the 55, with the seat belt retractor anchor plates now epoxied and cured for a week, they're ready to weld inside the quarters. He clamped them in place, scribed all the holes, removed them and cleaned paint off the hole locations.... clamped in, ready to plug weld..... then he dressed the plug welds on the anchor plates as well as a few remaining ones on the drivers bucket seat pan. next on the list is to fabricate some arm rests for the rear seat area that will also serve to enclose the seat belt retractors.
Robert |
06-17-2017, 10:23 PM | #848 |
With the Biederman fenders out of the building, its time to work on the 55's rear seat bolsters. Time to assemble the parts for the passenger side..
TIG welded together... ....and cleaned up.... Back to the drivers side, all the edges will be tipped forward to eliminate the possibility of sharp edges cutting through the upholstery.. This is the edge adjacent to the center fold down seat, so we wanted it nice and straight.. To better check that we were straight across the uneven surfaces, we used the laser again... https://www.youtube.com/watch?v=s3TwP6NaCKU Seats mocked up again..... .....and laser used to get a straight edge on the outside.. for more edge tipping.... Hopefully we can finish this up in the morning and start cutting out the foam pad..
Robert |
06-17-2017, 11:29 PM | #849 |
Robert, very nice detail on the edges...Jim
06-19-2017, 08:11 AM | #850 |
Thanks Jim!
Here's the panel with all the edges tipped forward, clamped in place.. Some poster board templates were traced from the steel part, then trimmed out and transferred to the foam. Used the electric bread knife from the kitchen (if anyone asks you haven't seen it...) to trim out the foam, makes short work of it... roughed out... Test fit for marking the profile... trimmed /sculpted to size with the bread knife and 3" roloc. Use a worn disc on the sander, the fresh ones tend to grab.. This fills out the seat pretty nicely and hides that wheel tub that protrudes into the back side of the seat.
Robert |
