#851 |
![]() Join Date: Mar 2007
Re: Loadmaster '47 COE
The camper is coming along nicely...
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#852 |
![]() Join Date: Mar 2011
Sweet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#853 |
Love it ,cant wait to see more .
#854 |
Wow, what a whole different look, an improvement, sure looks good.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#855 |
![]() Join Date: May 2007
the mpg answer is in your last picture behind your truck, see the semi with the air deflector on the roof? get some styrofoam and carve some wedges for all that frontal area on the camper, then wrap fiberglass on them and make them screw on/off! or just run it like it is, it sure does look cool!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#856 |
soo cool. sux about the gas though.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#857 |
Looks very nice and 61k is amazing. What kind of water proofing are you using?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#858 |
For the roof I'll be doing paint/cloth/paint (PMF, poor mans fiberglass) and corrugated galvanized for the siding. Now I'm using wood filler on the outside which I will follow with primer. I've haven't worked out the windows yet.
Still a bit of learning process as I've never done anything like this before. Rob
My '47 C.O.E build |
#859 |
FYI, here in the Southwest we use a Rubberized roof coating for our roofs on houses, and I think the same PME which is Rayon cloth.
Some of the new coatings even have very small glass spheers which act as insulation. I used some Lizzard Skin on my shop steel door which faces West and then a coat of paint, and it is holding up great. The temp on the outside in summer was 164* and it cooled it down to 105* on the inside
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#860 |
So after 3 tubs of wood filler and a few hours with a sander, most of the outside wood is done. I even got started on primer sealer. I also made a change in the outer cover plans. I have decided to skin at least the roof in aluminum.
Rob ![]() ![]()
#861 |
looks great. you gonna overhand the roof or make a drip rail?
#862 |
Don't think so, I'm looking at using a aluminum skin for both the top and sides. I think I will just leave the top about 3/8" overhang and fold this lip down the side. I've been looking at a few builds on a tear drop site and that seems to be a descent solution for the edge. I will be holding the aluminum on with a ton of rivets. Now, I may do some type of an rain gutter over the door and windows. A lot of this stuff I just figure out as I go.
Rob
#863 |
Great looking camper. Good idea to cover the plywood I have had trouble keeping the wood on my trailer from pealing due to the sun, and I am way north from you.
#864 |
OK, so after much back and forth I have made a final decision on the outer skin, Aluminum for all surfaces. Dropped over $800 today for a new roof skin for a semi trailer. 102" wide and 54' long. It worked out cheaper getting a full trailer top then the 46 feet I really need. With that I also got 1000 3/16" self sealing rivets. Just for the heck of it I hit a small spot with metal polish and a buffer wheel. That was way to easy.
Rob ![]() ![]()
#865 |
Oh good job on the roll. There should be a coating on that aluminum that prevents oxidation. I assume your going to polish the outside? That should be amazing.
#866 |
6>8 Plugless........
![]() Join Date: Sep 2007
Very nice work on the camper! The frame work came out awesome, and the wood work looks sweet too! As far as picking it up and loading/unloading it, maybe you can build 2 gantry cranes to do the work. I have a really heavy in bed camper and those jacks just are too sketchy for me IMO. They are ok on perfectly flat concrete. But I never have had that option. It's always un level, and windy when I want to load or unload it. I built some wood gantry cranes out of 2x6s and made them like a laminated morton building pole. I used 2 atv winches, 1 on each gantry. It worked slick and was safe and relatively cheap.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#867 |
I actually made some changes with the jacks. I put some concrete anchors for the base and then added 2 support bars which are mounted to the top and also anchored to the pad on each jack, making a triangle to the ground. The only other thing I may do is to add a pin to the jack shoe and a hole to the bottom tubing on the camper, this would allow for zero movement. I have put it on and off 2 times now with this new arrangement and things seem to be very solid. Thanks for the idea just the same.
Rob
#868 |
Very cool so far. I followed the build over on ls1tech when you got started, I absolutely love the flatbed!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#869 |
This is going to be really cool. the truck is already wicked cool but with the camper on it its like double the cool...
#870 |
Thanks all, the camper is still progressing but a bit slow. I'm waiting on some warm weather to continue with the skinning of the outside. That being said, I have been working. One side is ready for skin with all the holes cut on the wall. I have also started the wiring and the insulation. Now for the tough part: I have 30 days to have this thing water tight and ready for camping, not finished mind you but ready for a long road trip. Oh, and other news, I had the engine and transmission programs retuned for a more solid shift feel, some performance adjustments, I also got the tow/haul mode working.
Rob ![]() ![]()
#871 |
Slowly but surely!
1958 Apache 454ci 4 speed |
#872 |
Getting the trans tuned like that will make a world of difference.
#873 |
Actually, it has made a noticeable difference. 0 to 60 time went from 8.54 seconds to 8.23 seconds and it is not shifting out of torque converter lock up every time I hit a hill. Fuel mileage seems to be about the same at about 16 highway and city. The mileage had dropped when I converted to the steel bed. City and highway mileage have always been very close (the driving a barn on the highway effect ).
Rob
#874 |
More progress on the turtle. I now have both sides attached. Lots of trimming and riveting to say the least.
Rob ![]() ![]() ![]()
#875 |
Looks good, ah air shears, nice...Jim
