Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-10-2009, 12:50 PM   #876
Rokcrln
Rokcrln's Avatar
Re: LFD's 4dr Tahoe Build
Originally Posted by Frizzle Fry View Post
Nice! You'll probably want to at least spring-load the door side in the closed position so that the cab side swings to full open before the door side moves. Mine have a complicated cam-over mutual lock-out set-up so that only one half can move at a time.
Yep I think I will go with a magnetic (earth mags)set up on the door side so it opens the Body side first then with an extra push the door will swing open and not want to spring back. I worked this out last night sleeping soI will try it today. Now I need to work on a small push spring for the Body side so it directs the outer Door hinge to fold first. It should work good but we will see.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-10-2009, 01:39 PM   #877
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
So, it's going to be kinda like an Astro van
Took me forever to find a pic with the doors open
LOW DOUGH is offline   Reply With Quote
Old 12-10-2009, 01:46 PM   #878
VA72C10
VA72C10
VA72C10's Avatar
except open 180
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-10-2009, 01:56 PM   #879
Rokcrln
Rokcrln's Avatar
Yes but with out visible hinges when the doors are closed!
Kevin
LFD Inc.
Old 12-10-2009, 02:26 PM   #880
Critter
Future TOTM Winner
Critter's Avatar
I believe the Ford Excursions are that way as well...
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-10-2009, 02:52 PM   #881
Rokcrln
Rokcrln's Avatar
Yes they are but see those ugly Ars hinges! I spent several hours getting rid of the hatch exposed hinges for a hidden style and these are no different. I will not pull the body until all fab design work is worked out and now it almost is!
Kevin
LFD Inc.
Old 12-10-2009, 03:12 PM   #882
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Yeah, the hinges on that excursion look like an afterthought, they are tacky.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 12-10-2009, 05:12 PM   #883
pickup67man
pickup67man's Avatar
Where did you find those hinges? I have cargo doors and would like to hide those ugly hinges. Don't know if I will go 180* or just 90* but I love them already.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
Project Family Hauler
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 12-10-2009, 05:15 PM   #884
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
I believe they are a LFD, one off, hand made set.
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 12-11-2009, 03:44 AM   #885
Rokcrln
Rokcrln's Avatar
The basic 90* hinge is from Suicide doors. I have seen sets going for $150 + and these were $379+ and I was hopping they were top of the line. Well they are and then some, well worth the extra money for the quality of the kit. I then mod'd two sets to try and make a 180* but don't think it will work out like I want. I was only able to get about 130* of open before the edge of the door bound up on the hinge arm. Unless I have a notch in the door edge to clear (no way I will do that) then it looks like I will settle for 90* of hidden over a bit more with notches.
Kevin
LFD inc.
Old 12-14-2009, 12:54 PM   #886
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
can't wait to see the your rear..... the doors that is.
Old 12-14-2009, 01:44 PM   #887
67cheby
67cheby
67cheby's Avatar
WOW i have heard of a BRO-MANCE before and i am awed by LFDs work as much as the next man ... BUT "I cant wait to see your rear" THAT IS OVER THE TOP MAN!!!!
67cheby is offline   Reply With Quote
Old 12-16-2009, 12:27 AM   #888
Rokcrln
Rokcrln's Avatar
I seem to remember that saying about 2 things come from TX.........
Well a small update on parts showing up. I received my in tank pump and bracket so I can finish the fuel tank. I also just got the package from Speed & Performance with my re-flashed computer, DBW gas pedal, MAS air flow meter and my complete harness. So I should have everything I need to get it to fire up with a few runs to the local Napa but now I need to find the time. Things will be a bit slow until after Christmas because I have an ArticCat and 2 Rinos to build cages for before Christmas so they can head to the dunes and play. I have to do a shop clean up so I can get back on the 41 chevy now that I have my air system on its way as well as the SS V-clamps for the exhaust. Then I might find a few hours to start playing on the Tahoe again.
Kevin
LFD Inc.
Old 12-16-2009, 11:18 AM   #889
67cheby
67cheby
67cheby's Avatar
chuckle ,chuckle
Old 12-16-2009, 02:16 PM   #890
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
I wanted to say rear doors, but thought it would be funny to leave it as rear. I JUST want to see the back of the tahoe after the doors are done.
Old 12-17-2009, 12:27 AM   #891
Rokcrln
Rokcrln's Avatar
So after I got the cage work done on three of these ATV's I finished up my gas tank and all that is left is PSI testing and run some lines to the front. Boy is that tank heavy but being built out of 14 ga it did not warp very bad at all and sure was nice welding something thick for a change.
Kevin
LFD Inc.
He is adding two seats in the back for his kids so he wanted a bit more protection.
[IMG][/IMG]
Got to use my tube roller for the dash bar!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
View of the sump.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 12-17-2009, 01:33 AM   #892
VA72C10
VA72C10
VA72C10's Avatar
Purdy. Very nice work as usual.
Old 12-17-2009, 03:08 AM   #893
Puropedo
Tank turned out sweet! Do you mind telling us how much was the wiring harness for your 5.3 and for the computer re-flashing? Aslo, didnt your 5.3 came with an air flow meter sensor?
Puropedo is offline   Reply With Quote
Old 12-17-2009, 11:45 AM   #894
Rokcrln
Rokcrln's Avatar
I had to buy a MAF, DBW gas pedal, harness (with rear 0s's removed) and the computer re-flash and it was about $1600. You can find cheaper or even do the harness your self like several board members have done and I have done in the past. Also you can source missing parts from the wrecker but I have no extra time right now and wanted it done! Plus I have always had great luck with S&P.
Plus I found out yesterday I did not have the TAC module to control the Drive by wire gas pedal so their went another $200
Kevin
LFD Inc.
Old 12-30-2009, 09:46 PM   #895
camokid
I dont know if you have looked at the door hinges on the new chevy extended cabs but those doors open like 180 or so and they just use two springs on bigger then the other to make it have a stop of sorts half way....I was looking at my dads new extended cab and they looked like they would do the trick...
camokid is offline   Reply With Quote
Old 12-31-2009, 01:30 AM   #896
Rokcrln
Rokcrln's Avatar
I did look at those to start with but because the the body curve and the way those hinges "tuck in" they would not work on this set up. But thanks for looking out.
Kevin
LFD Inc.
Old 12-31-2009, 02:46 PM   #897
gcburdic
Restoration Virgin!
gcburdic's Avatar
Not sure why I haven't subscribe to this build already, but here I am.....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-01-2010, 06:08 PM   #898
itchy...
itchy...'s Avatar
Wow, what a way to spend a new years day. New to the board, and just found the thread. Just read all 897 posts. I'm gonna go out to the my garage now and burn it down, along with my junk.
Fantastic craftsman ship. I dont know how you juggle work, play and a family. What ever your secret is, keep it up.
Cheers, The Drunk Pollock.
itchy... is offline   Reply With Quote
Old 01-04-2010, 10:01 PM   #899
tdave00
Restoring a 68 SWB
tdave00's Avatar
Join the club. Sounds exactly like how I got hooked. Except I didn't burn down the garage! Well, I didn't have a garage at the time, or any junk either.
tdave00 is offline   Reply With Quote
Old 01-04-2010, 10:40 PM   #900
mcbassin
Still Learning
mcbassin's Avatar
Kevin,
Do you have a set of drawings for that gas tank? You think you will want to sell them on the board? Cost? You think that tank with minor mods would fit on a truck frame. I might be interested in building one like that.
mcbassin is offline   Reply With Quote
