#876 |
Tot Roddin'
Re: Finally starting my Longhorn 4x4 conversion
Looking good Ryan!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#877 |
6>8 Plugless........
![]() Join Date: Sep 2007
Thanks man. Still have a ways to go to get to your level buddy.
![]() Yes it is. It should look nice once all painted up. I only scratched my fire wall 3 times so far during this mock up. ![]() Thanks Nate. Your tot rod turned out awesome!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#878 |
Tot Roddin'
Thanks buddy.
#879 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
"Thanks man. Still have a ways to go to get to your level buddy.
My level? Dude now your talking lets slammmmmmm that 4x4 and get down to my level.....LMAO** Seriously dude you ave great game and this is a great build....can't wait to see it completed...
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
#880 |
![]() Join Date: Oct 2010
Soo, I am at the EXACT same point you are, I literally tried a 7.3 intercooler yesterday evening, too narrow, then my grandpa gave me the same Dodge one you have today and it's tall as all get out!
What are you gonna do about the hood latch? I just bolted my latch up to see if it'd all clear and it ain't lookin too hot. |
#881 | |
![]() By the way, where's your build thread?
#882 | |
#883 | |
#884 |
Well if you are going to do that, why stop at 2wd? Make it a lowered AWD with a bed mounted engine, Maybe a stepside to reach it better or a flopper hinged fleetside bed. How much of a torque input rating do you need for a t-case?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#885 | |
#886 | |
I never started a build thread because I knew I wouldn't be consistent enough or have the time to keep up on it. I've taken pictures here and there throughout the deal but just never made a thread. I have a thread that has a few updates, nothin spectacular though. Doing this 2wd with and Auto is proving to be a good challenge though! I don't have all the clearance like you 4wd guys! |
#887 | |
Start a thread son! ![]()
#888 | |
#889 | |
#890 | |
I'll start a build thread if you set me up with a big turbo so I can do compounds with my sissy little Aurora 2000! ![]() ![]() |
#891 | |
#892 |
Hope they rebox the S300G's better than their higher series turbos.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK" ASSEMBLY THREAD |
#893 | |
I wanted to keep the truck as original appearing as possible since my grandma was the original owner from 68-96 when she passed away! The Aurora I bought with a set of DDP "Stage 3" injectors and a fuel plate for $380, I couldn't pass that up! Aren't those injectors like 5x.013, right? |
#894 | |
I wouldn't recommend anything bigger than a 145* 5*0.012" SAC injector for your A2000, if I was the one selling you Ryan's injectors.
#895 |
Fuel plate is a 6 profile I believe.
This turbo is pretty much just a non gated S300 though, right? |
#896 |
Nope, if memory serves me correct, I got hung up on for asking if the the A2000 was similar to the S300G, and if the A3000 was similar to the S300. S300G is a smaller cartridge than the S300. They don't seem to like that people know they don't produce their own turbos.
#897 |
I'm going to take a stab here, but I think A2000's are S200 series and the A3000's are S300's. 200's do look very similar to 300's though.
#898 |
Well ride on, thanks for the help/input guys!
Appreciate it all from the both of ya! Anyway you might know of a exhaust manifold like the 24v ones that put the turbo to the front of the motor that has the right ports or am I gonna have to build one? |
#899 |
I have one that will place the turbo on dang near top of the #2-3 valve covers. I can post a pic of one if you want.
#900 |
No big progress this weekend. Between working on a semi and sluffing off with the owner, and Mother's Day, I didn't get much done on this thing. But I did manage to get the hydra boost on. It isn't done as I have to build a linkage to connect the brake pedal too, and drill 2 holes in the mounting plate to finish bolting it to the fire wall. I did find my clutch pedals and get them in finally. I also removed the large spring from the clutch pedal because I won't be using it. By the way, I had to go hydraboost because now that I raised the engine up and brought it back more, a vacuum type set up will not fit.
![]() ![]() Getting ready to build the last charge air cooler (CAC) pipe. ![]() 2 steps forward, 3 steps back. I'm going to have to modify my engine mounting bracket to clear the PS line. Yeehaw! ![]()
