Old 09-08-2012, 08:25 PM   #876
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Squirted some color on a few small parts today--really liking this VHT epoxy satin black. It has the perfect sheen and lays out really nicely. The control arms and rear disc brackets will head to the powder coater next week...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-09-2012, 09:03 AM   #877
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Nice parts ! and painted pieces are lookin good too. Vht is a good product, I use it and duplicolor as well. keep up the good work !
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 09-09-2012, 09:32 AM   #878
mcbassin
Still Learning
mcbassin's Avatar
More nice parts. The paint looks good.
mcbassin is offline   Reply With Quote
Old 09-09-2012, 10:05 AM   #879
widewhite70
widewhite70's Avatar
Looking good! I like to see the Porterbuilt parts! My next build will have some for sure
-Calvin
http://67-72chevytrucks.com/vboard/s...d.php?t=512270 my build, tube chassis and LS2
How I keep the truck shining, Detail thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=697902
widewhite70 is offline   Reply With Quote
Old 09-09-2012, 02:46 PM   #880
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! I've had good luck with their wrinkle finish, too.
Thanks- chipping away at it...
Thanks! I don't think yours is lacking in the handling dept. They are nice looking pieces- hopefully work as good as they look
-Chris
Old 09-09-2012, 09:14 PM   #881
gringoloco
A guy with a truck
gringoloco's Avatar
Pulled the 'bags and installed the ECE 6" drop rear coils. Man, this thing is L-O-W...
The coils slipped right in like they belonged there and in conjunction with my 1.5" blocks give me 7.5" of rear drop, which is about 1.5 lower than where I had the airbags set before for the 'just right' rake. Not sure what the plan of attack is at this point, as I kinda like the lowered look, but would have to re-work shock mounts, bumpstops, and maybe exhaust to get it right--not to mention the work involved in getting the front down another inch to match
The ride is different--definitely feel more of the road than with 'bags, but not necessarily in a bad way, except when I hit a larger bump and it bangs the bumpstops. If it stays at this height, I'll fix that so it won't be a factor...
-Chris
Old 09-09-2012, 09:29 PM   #882
gringoloco
A guy with a truck
gringoloco's Avatar
Here's before and after measurements of the rear wheel arch, as well a side view showing just how re-donk-u-lous it looks with the a$$ dragging the ground. I am NOT a fan of the 'cali-lean'. Also note how off-center the front wheels are--the PB arms should remedy most of this. I think I will wait until after I complete the trailing arm 'flip' before I plan any other drastic changes out back, as I'm pretty sure that mod will raise the rear an inch or so...
-Chris
Old 09-09-2012, 09:52 PM   #883
Lolyin58
Lolyin58's Avatar
Truck looks really good. Should be fun to drive!
Lolyin58 is offline   Reply With Quote
Old 09-09-2012, 10:23 PM   #884
Bennett68C10
Bennett68C10's Avatar
I love the way the rear looks, I would leave it like that and get the front down a little lower. What spring are you running in the front, maybe try a 3" lowering spring if your able too
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-10-2012, 12:27 AM   #885
Xeen
Xeen's Avatar
You could just remove the 1.5" rear lowering blocks and see how you like it.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-10-2012, 05:47 AM   #886
Pick
Pick's Avatar
Or just machine the blocks to the height you need to fine tune the rear drop and achieve the "right" rake you're looking for.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread"
A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack
Pick is offline   Reply With Quote
Old 09-10-2012, 05:57 AM   #887
XxCHEVYMANxX
I agree, bring the front down and your there.
John
Facebook LoL
Old 09-10-2012, 06:02 AM   #888
darkhorse970
darkhorse970's Avatar
I like it! With a little fine tuning I have no doubt that you will get it where you want it.
BTW, I'm adding the sway bar to my '63 this week so I will give you some "feedback" on the handling improvements.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 09-10-2012, 08:19 AM   #889
SCOTI
SCOTI's Avatar
He would still have to re-work the shock mounts as the blocks help w/shock travel. It will be interesting to see where the height winds up after the relocating of the front T/A pivot.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-10-2012, 01:57 PM   #890
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks- I sure hope so after all of this
Front is currently a 1" drop Belltech trimmed to about 2" drop. If I do anything, I'd probably section the crossmember to bring it down and keep my ground clearance. This was supposed to be a simple project, though
Thought about that, but will probably wait 'til after the t-arm 'flip'
Likely will end up doing this following the flip
Part of me agrees, but the other part doesn't wanna deal with all of the custom fab required to get there...
Cool, let me know what you think--I was amazed at the difference
I agree- trying to minimize the amount of fab while still being super low is an exercise in futility. There's give/take while finding the balance. TA mount flip coming soon--I'll do it as a direct 1:1 comparison with no other changes, just for scientific purposes
-Chris
Old 09-10-2012, 02:24 PM   #891
Zoomin
Man of Mini-Talents
Zoomin's Avatar
What's odd is that it looks like it's sitting level if you look at the top of the bed. Are your rims different diameters (too lazy to search)?
Zoomin is offline   Reply With Quote
Old 09-10-2012, 03:38 PM   #892
gringoloco
A guy with a truck
gringoloco's Avatar
20" wheels all around, but with a slight tire rake; 28" front/29" rear...
-Chris
Old 09-10-2012, 07:15 PM   #893
gringoloco
A guy with a truck
gringoloco's Avatar
Powder! Dropped off at lunch, picked up after work- how's that for service?!
-Chris
Old 09-10-2012, 08:08 PM   #894
darkhorse970
That's outstanding service! Looks like very high quality coating too.
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 09-10-2012, 08:47 PM   #895
chapster
chapster's Avatar
Hey Gringoloco,
Nice build,
Quick question,
I thought I had this figured out the last time I talked to Nate in regards to the 1" forward arms. After reading your thread is it only the requirement of lower control arms to benefit the 1" forward? What is the difference on the uppers they sent you vs the uppers for a standard dropmember.
Thanks,
Chapster
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 09-10-2012, 09:37 PM   #896
gringoloco
A guy with a truck
gringoloco's Avatar
They generally do great work- I will have to chase some threads and probably clean up the ball joint pockets, which they're normally really good about, but I'm not complaining- I have taken a hammer to their powder before, and it just conforms to the dents- no flaking/chipping at all...
Originally Posted by chapster View Post
Hey Gringoloco,
Nice build,
Quick question,
Thanks,
Chapster
I will be running lowers only, which will give more caster and less 'centering'. The upper arms were sent to me by accident, and are being returned
My understanding is that there are forward uppers as well as standard uppers depending on what you're looking for. I was looking for cheap
-Chris
Old 09-10-2012, 10:06 PM   #897
Bennett68C10
Powdercoat looks awesome, should have done that to mine but I cheaped out and painted them.
Keith
66 Suburban
IG: bennett68c10
Old 09-10-2012, 10:21 PM   #898
gringoloco
A guy with a truck
gringoloco's Avatar
I thought about putting most of the parts in powder, but to save a few bucks, I only did the larger ones that required the durability.
Here's a dirty-hack p-shop of what I would be happy with for ride height up front to match the current rear. I think I'd be pretty close to the stock inners at this height, but I love the look...
-Chris
Old 09-10-2012, 10:25 PM   #899
chapster
chapster's Avatar
Posted via Mobile Device[/QUOTE]
Thanks for the clarification. That is what I understood from Nate but thought maybe I was missing something.
Cheers
Old 09-10-2012, 10:36 PM   #900
aggie91
I'm just glad to be here!
aggie91's Avatar
Who did the powder coating? If you don't mind what did they. Charge for the control arms and brackets?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
