08-01-2019, 09:55 AM | #876 |
Re: What did you do to your Blazer/Jimmy today?
Post 98 of my build has more details. Short story is that it's a damper from a 2014-19 truck mounted inside the tailgate. |
08-01-2019, 10:34 AM | #877 | |
BigBlockBobby
Bob |
08-04-2019, 06:35 PM | #878 |
Swapped one Grant GT wheel out for another...been waiting to install the walnut one for awhile now.
I also fixed the turn signal cam while I was in there that has been broken since I bought the truck. Slowly working on the interior as I get time and parts. I already picked up a set of parchment buckets that will be replacing the seats that are in this rig now. |
08-05-2019, 11:20 AM | #879 |
Took the K5 5 to Menard's Chevy Show Denver
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
08-05-2019, 06:30 PM | #880 |
Looks like one clean k5
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
08-05-2019, 10:02 PM | #881 |
Proprietor of Dale's Corner
Looked very nice. Looked like a nice show.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-10-2019, 10:38 PM | #882 |
go cyclones
Cleaned out all the mouse turds.
Posted via Mobile Device |
08-11-2019, 12:49 AM | #883 |
Installed my newly purchased 15x8 rims and tires!
08-13-2019, 03:51 AM | #884 |
I started replacing the corroded brake lines with copper alloy lines but run into areas I couldn't reach. So I ended paying the local repair shop to finish the job. Cost me $225.00 labor.
I have a question: I went to a reputable shop for the line replacements and they told me they are not licensed to work on vehicles 1972 and older ! I never heard of such a thing. Anyone hear anything like that. This is in Michigan. |
08-13-2019, 11:42 PM | #885 |
Cut some patch panels on the doors.... fought with some frozen u bolts prepping for the new front axle this coming weekend while simultaneously using mass amounts of profanity. After a couple beers decided they will get the good old fire wrench
08-14-2019, 09:11 AM | #886 |
Sometimes the fire wrench is the only way. Especially on trucks that are almost 50 years old now.
08-16-2019, 12:15 PM | #887 |
(Actually a couple days ago..) Installed new seats, so my kids have shoulder belts. These are from a 2010 Escalade.
I did the mounting a little different than others. I don't care about the removable rails for the rears, so I removed all of the brackets, which leaves you with seats with nice flat bottoms and flat metal tabs to mount to. I welded a simple metal frame, which reused the legs off the original seats (bolts into the stock mounts in the floor). I have amplifiers under the seat that I wanted clearance for. The Drivers side also only used the seat, stripped of all the factory frame, and then mounted pretty easily to my pre-existing sliders. The passenger seat kept the flip/fold base from the Cadillac, it's nice and flips up like it was meant for the Jimmy. |
08-16-2019, 07:49 PM | #888 | |
08-22-2019, 04:42 AM | #889 |
Collector of Projects
I installed some American Billet tail light bezels. If you're not using factory trim, these are awesome...
https://allamericanbilletstore.com/1...-btl-6772-c10/ |
08-26-2019, 06:03 PM | #890 | |
08-26-2019, 06:13 PM | #891 |
Installing an American Autowire builder harness... I decided to install some flange mount Deutsche connectors on the firewall for the front and rear light harness ...
* picture is sideways for some reason Last edited by mcmlxix; 08-26-2019 at 06:44 PM. |
09-12-2019, 05:35 PM | #892 |
Hooked the sending unit up and seen my gas gauge works. Kind of want to go get some gas just to watch the needle go up.
09-23-2019, 02:09 PM | #893 |
Active Member
Made progress on my floor removal and rebuild project
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3. Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. Members Met: Aldtime, DeadheadNM |
10-05-2019, 09:49 PM | #894 |
Washed and waxed for fall!
-Bruce 1971 K5 Blazer 4WD |
11-10-2019, 05:23 PM | #895 |
Installed double wall top for the winter.
Not sure if others have done this, but it's usually an all day job getting bolt holes to line up and to get everything to thread properly. This year I cut down some bolts and essentially pre-installed studs into the top. Dropped the top and everything was lined up in one shot. Major time saver. And I didn't have to worry near as much about cross-threading a bolt into an ancient captured nut. |
11-10-2019, 05:41 PM | #896 |
I thought about doing that but was thinking it would be just as hard to line up and drop at the same time without scratching the paint on the bed pretty badly. Plus I already have like four or five bolts broken off inside the top that I can’t get out already. So I only have to line up four bolts per side right now. But my top is on for winter as well.
11-10-2019, 07:47 PM | #897 |
Top partially on for the winter
11-11-2019, 03:03 PM | #898 | |
Is there is a more efficient way to reinstall the tops on these Blazers/Jimmies? Thanks!
Photo Gallery of 1972 K/5 Blazer CST |
11-15-2019, 02:41 AM | #899 |
I installed my winter tires and wheels. Those 32-11.50x15 look good but that last snow storm was a little squirrely.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
11-15-2019, 11:13 AM | #900 |
@GreenMonster -
I picked up a dozen 2" SS carriage bolts that fit the captured nuts. Ran them through all the nuts in the top and chased any that needed it. Then cut the heads off of the nuts and ground a taper on one end of each. This is the real benefit, being able to easily access each nut while the top is in the air and being able to thread them properly. (In retrospect, I'm not sure that grinding the taper on each was necessary. The thought process being it would allow the bolts to find the holes more easily with a little play to get them started.) I installed a bolt into each nut in the top with loctite. I used blue, but would probably use red if I did it again. All of them held, except for one. I think my threads weren't perfect from the grinding process on that one and the nut ended up turning the bolt. Still worked, but better to make sure your threads are tip top, and red loctite would help. Come spring, we'll see if any of the bolts come out when removing the nuts. Even if they do, it'll be easy enough to reinstall them. On my lift set up, the top sits on 2x4's which I lower on to the bed rails. Then get inside and lift the top with my back while I, or a helper, removes the 2x4's. Then gently lower the top into the holes. FWIW, this is the lift set up I wish I had the tools to make, a much slicker system and would work with a roll bar. From BobbyK: http://67-72chevytrucks.com/vboard/s...d.php?t=398105 I then worked from the back to the front adding a washer, lock washer and a nut to each bolt. I would say it easily cut the time frame down below half of the previous method, and if I remember correctly, I'm not sure there was even one cuss word involved. The old way involved several. Let me know if that explains it sufficiently, or if you were looking for anything else specific. |
