Old 10-24-2016, 01:24 AM   #901
swamp rat
swamp rat's Avatar
Re: Project: 1967 C10 Small Window
That's gotta hurt, hope everyone is ok.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-24-2016, 08:15 AM   #902
Bennett68C10
Bennett68C10's Avatar
Saw this on IG, sucks to see such a beautiful truck messed up like that! Can't wait to see what you plan to do with the rebuild.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-24-2016, 08:47 AM   #903
mcbassin
Still Learning
mcbassin's Avatar
Ouch! Man, that really sucks to see. I hope everyone is safe from the crash. Your truck can be fixed.
mcbassin is offline   Reply With Quote
Old 10-24-2016, 12:23 PM   #904
David67
David67's Avatar
Thanks all for the concern.
Only myself involved and I walked out. My leg smacked the gauge bezel and it seems my elbow dented the door... but there was no pain or bruising. It happened maybe 5 months ago but I haven't had the heart to post it on here.
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 10-24-2016, 01:36 PM   #905
cericd
cericd's Avatar
Man! Sorry to hear about the truck but glad to hear that you weren't injured.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 10-24-2016, 01:56 PM   #906
David67
David67's Avatar
Yeah... could've been much worse!
1967 C10
IG: david_r67
Old 10-24-2016, 02:02 PM   #907
David67
David67's Avatar
In September, I got this '69 SWB frame from 62LS1 (who I originally bought the truck from). It was in good shape other than the rear shock member which was pretty mangled.
1967 C10
IG: david_r67
Old 10-24-2016, 02:12 PM   #908
Deer_hunter_088
Deer_hunter_088's Avatar
May i ask what happened to cause the wreck?
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 10-24-2016, 02:15 PM   #909
David67
David67's Avatar
I decided to make the switch to air suspension... nothing crazy but I did need to notch the frame. The frame was obviously flipped over for convenience. I've been working with Travis at AZ Pro Performance. He is awesome to work with and has helped a ton.
1967 C10
IG: david_r67
Old 10-24-2016, 02:20 PM   #910
David67
David67's Avatar
I wanted to know what it was like to be a Mustang driver...? just kidding...
1967 C10
IG: david_r67
Old 10-24-2016, 02:27 PM   #911
David67
David67's Avatar
The notches are from Dead End Garage. Very stout and they include bag mounts and the panhard bracket.
I replaced the stock shock member with one from CPP. It required a little bit of extra cutting and drilling to make it work. I love hacking up new parts!
1967 C10
IG: david_r67
Old 10-24-2016, 02:33 PM   #912
David67
David67's Avatar
I'm using (2) 3-gallon Accuair tanks mounted to 1/4" flat bar.
1967 C10
IG: david_r67
Old 10-24-2016, 02:42 PM   #913
MMcMasters
MMcMasters's Avatar
Sorry about the damage but it looks like your well on your way to bringing it back to life.
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 10-24-2016, 10:58 PM   #914
oldman3
oldman3's Avatar
I feel your pain, hit a deer with my AD this past Saturday morning. Will be starting repairs to it soon...Jim
oldman3 is offline   Reply With Quote
Old 10-25-2016, 04:10 PM   #915
jlsanborn
jlsanborn's Avatar
Ahhh, the Mustang videos. That was me a few years back when I backed my son's V8 S10 into the ditch
Glad to see you're on the road to recovery and that you'll be able to incorporated some changes you've thought up. Look forward to following the process. Great looking work so far!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 10-25-2016, 08:55 PM   #916
mud.man.rj
mud.man.rj's Avatar
Wow, as long as your ok, that matters the most.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 11-08-2016, 03:56 PM   #917
Slick67
Sofa King Crazy!!
Slick67's Avatar
BAGZ!!!!! I knew you would come over to the darkside!!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 11-23-2016, 06:52 PM   #918
David67
David67's Avatar
It's getting there!
Not fun!
Thanks! I'm very excited about the changes.
Exactly
It was only a matter of time.
I've gotten a little bit done. I'll post some pictures this evening.
1967 C10
IG: david_r67
Old 11-24-2016, 12:00 AM   #919
David67
David67's Avatar
Not a whole lot of exciting things yet. We managed to roll the bent chassis out from underneath the cab/bed. I do not have pictures at this time.
No more low hanging exhaust! I found that Dead End Garage came out with these nice crossmember cutouts. They came with a template and use one of the preexisting holes. I ended up using a 4.25" hole saw... I was not sure if it would do the job, but I dropped the $50 for the saw and arbor and gave it a shot. Those had to be the most VIOLENT cuts I've ever made, but it worked like a charm and the saw is still in good shape. You can see in the first picture that I tacked a piece of metal to the crossmember in order to have a pilot hole. I then made a template which fit inside of the DEG template and marked the center point for drilling. I may go back and weld them in. Cleaned and painted hidden areas and torqued them down. Very happy with the results!
1967 C10
IG: david_r67
Old 11-24-2016, 12:15 AM   #920
David67
David67's Avatar
Well....this control arm is pretty janked I'd say. Also found out the original front crossmember is bent believe it or not, so I'm using the new-to-me one and it's donor LCA. I cleaned/painted hidden areas and bolted in the crossmember for good. Control arms are waiting their turn at powdercoating. yes POWDER! The rest of the frame/suspension will get the same treatment.
...anyone want a bent frame?
1967 C10
IG: david_r67
Old 11-24-2016, 12:24 AM   #921
David67
David67's Avatar
I repainted the calipers and spindles as well as some new rotors. The front end should be ready for assembly when I get the control arms back. This will likely be hidden with my new wheel choice..... "but no one is going to see it" has never been a valid reason for me to not do something!
1967 C10
IG: david_r67
Old 11-24-2016, 12:35 AM   #922
David67
David67's Avatar
After looking at my original axle housing, I realized that...guess what? It's bent. At least the mounting flange is bent, so it can probably be fixed. Regardless, I'll be using the other rear end. It seems to be in better shape with no pitting, so it'll look better after PC. It even has a posi with 3.73 gears!! Ordered some Moser Axles/seals and a Timken rebuild kit.
1967 C10
IG: david_r67
Old 11-24-2016, 12:41 AM   #923
David67
David67's Avatar
Scored this nice '68 front clip. Very happy to have original steel!! The core support isn't even rotted out under the battery.... but the fender is of course.
1967 C10
IG: david_r67
Old 11-24-2016, 12:50 AM   #924
David67
David67's Avatar
That's all for now.
Oh and one more thing......
1967 C10
IG: david_r67
Old 11-27-2016, 11:54 PM   #925
jlsanborn
jlsanborn's Avatar
Awesome progress and GREAT looking work!
1967, small block, small window, stepside
