09-10-2012, 10:43 PM | #901 | |
Re: How to: Ruin a perfectly good C10
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
09-11-2012, 12:09 AM | #902 |
The aftermarket inner tub swap opens up a whole 'nother can-o-mods.
09-11-2012, 08:32 AM | #903 | ||||
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-11-2012, 10:12 AM | #904 |
When you figure this out, please.... please, tell me the secret. With the swap to the tubs, you have to relocate the w.washer reservior, the OE radiator overflow tank, emissions charcoal tank, & battery (any or all depending on what items you have). Can-o-worms indeed....
09-11-2012, 12:18 PM | #905 | |
A guy with a truck
09-11-2012, 02:12 PM | #906 |
Ahhh.... Forgot them! I technically didn't have to start from scratch there as mine is an 89 thus has the cowl mounted pivot installed from the factory. I just have to add struts. My 64 & 67 will be a different story.
09-12-2012, 12:52 PM | #907 | |
Hope you get back to it soon! Cant wait to see how this goes together.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
09-12-2012, 11:29 PM | #908 | |
A guy with a truck
Oh, and I despise frame rivets. That is all. Posted via Mobile Device
09-13-2012, 06:56 AM | #909 |
So the trailing arm flip gave the truck a slight rake then? I bet it looks good just how it sits now.
John Mild Custom 68' Work Truck Build Facebook LoL 1977 Trans Am (Project) 1965 Chevelle (Project) |
09-13-2012, 08:09 AM | #910 |
I'm right there with you buddy, I hate those frame rivets too. Can't wait to see some pics.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
09-13-2012, 09:48 AM | #911 |
67cheby
its....tomorrow, today !
09-13-2012, 03:06 PM | #912 | ||
A guy with a truck
I guess I deserve that, after all the pic harassment I've given in your thread, so I went out and snapped a couple during my lunch break, to go with the in progress shots from yesterday Pretty simple mod--though it took me a few hours, mostly due to those !%dag@^*$^blasted##&%&*flabber#@!*#*@jackin*&^&%#^*% rivets. I used the brackets as a template for the offset holes and drilled them all out to accept 7/16" grade 8 hardware. Pretty happy with the end results, as the rake is now at an acceptable height- just gotta get the Camaro sway bar mounted up, and the rear suspension will be done! Just for comparison, the rear is now ~3/4" higher than before and with no measureable fore/aft change. Looking at this pic, I really need to get those a-arms in and get the front wheel centered in the wheelwell...
09-13-2012, 03:53 PM | #913 |
C10 addict
Did you have to add shims between the axle and the trailing arms to correct the pinion angle or is the change in angle minor enough to not be an issue?
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
09-13-2012, 04:04 PM | #914 |
Still Learning
Nice work Chris! Keep the updates coming. With pictures.
09-13-2012, 04:54 PM | #915 | |
A guy with a truck
Bottom line: no, I did not add shims, either before or after the mount flip and have no issues--even at up to 80mph on the (crappy LA) interstate this morn Thanks! More to come- can't have an update without pics
09-13-2012, 05:13 PM | #916 |
I know it's a small difference, but I like the stance more now you have done the flip to the brackets. I didnt like the look of your a$$ dragin on the ground, it looked lazy, not very sport.
09-13-2012, 06:17 PM | #917 |
Looks Good ! Nice subtle rake, adding the rear sway bar you'll have almost nobody roll. very cool.
09-13-2012, 08:10 PM | #918 | ||
A guy with a truck
Here's a side-by-side of before/after the mount flip. Amazing, to me, how much difference less than an inch can make (that's what she said! ). Also notice how the arms are no longer hanging down beneath the bed. All said, good mod
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 09-13-2012 at 08:16 PM. |
09-13-2012, 08:35 PM | #919 |
You nailed the stance perfectly!
09-13-2012, 09:26 PM | #920 |
The stance looks really good, matches the front perfectly. Great job on a well thought out mod I would have never thought of.
09-13-2012, 11:04 PM | #921 |
Truck and auto performance nut
Looks good..interesting about the pinion angle. My truck got worse with the TA mount flip...my trucks pinion angle is like (yes shims are on the way) 8*? After working to set a better angle from the eng/trans my d-shaft was too short...then he put on the wrong u-joint....my d-shaft is getting it re-redone
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
09-14-2012, 12:54 PM | #922 | ||
A guy with a truck
Thanks! I think it will work
09-14-2012, 12:57 PM | #923 |
I'm just glad to be here!
Stance is perfect. When do you plan to install the Forward Lower arms?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
09-14-2012, 05:42 PM | #924 | |
A guy with a truck
09-15-2012, 05:49 AM | #925 |
Maybe a dumb question, but I read an earlier post that had to do with centering the front wheel in the fender opening. Is this done with the A arms your installing? and is just the lower needed to accomplish this? I'm still learning.
