Old 09-12-2017, 12:13 AM   #901
rustytruck50
rustytruck50's Avatar
Re: Owen's C10
It's been a while since I read about the progress on the truck...all I can say is WOW! It looks great!!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 09-12-2017, 08:27 AM   #902
Bennett68C10
Bennett68C10's Avatar
Re: Owen's C10
congrats on getting to drive and enjoy it. Quick question, what backspacing are you running on your front mobsteel wheels? I think I remember them being 20x9 but couldn't remember what backspacing you were running.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-12-2017, 03:03 PM   #903
mooseknuckles
mooseknuckles's Avatar
Re: Owen's C10
Originally Posted by builtbyKane View Post
Does the heat wrap on the intake serve a purpose? Never seen that done before except on turbo cars.
Well actually...it covers up the hole in the tube where I cut the tube for the pvc thingy off and patched it. And also it's gotta keep some of the heat from the fans and rad blowing on it only inches away...?
mooseknuckles is offline   Reply With Quote
Old 09-19-2017, 07:00 PM   #904
mooseknuckles
Re: Owen's C10
If anyone cares, I attended a couple local shows on the weekend. lol.
Old 09-19-2017, 08:07 PM   #905
RRR18
RRR18's Avatar
Re: Owen's C10
Yep seen some pics on Instagram.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 09-25-2017, 10:40 AM   #906
knomadd
knomadd's Avatar
Re: Owen's C10
Truck looks good! That little trophy is pretty cool.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-25-2017, 09:18 PM   #907
tlmoore2501
Re: Owen's C10
I have followed your build since day one.You have simply done some amazing work.Craftsmanship in your own details.Congratulations on your great accomplishment !
tlmoore2501 is offline   Reply With Quote
Old 10-30-2017, 01:47 PM   #908
mooseknuckles
Re: Owen's C10
thanks!
Old 12-05-2017, 09:41 PM   #909
72 tigger
72 tigger's Avatar
Re: Owen's C10
anything new?
72 tigger is offline   Reply With Quote
Old 12-05-2017, 10:08 PM   #910
stevenfromtexas
stevenfromtexas's Avatar
Re: Owen's C10
your clear coat makes me want to go swimming in it
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline   Reply With Quote
Old 12-06-2017, 01:42 PM   #911
faribran
Re: Owen's C10
I really like this build. For a few pages I was watching your power steering reservoir ..I see you turned it up.
faribran is offline   Reply With Quote
Old 12-06-2017, 08:54 PM   #912
mooseknuckles
Re: Owen's C10
Originally Posted by 72 tigger View Post
anything new?
nothing new yet... just waiting for the "truck fund" to replenish itself, I have a few things planned like side windows, interior, heat/ac, and finish the bed.
hahaha, thanks!
actually I was waiting on a f-body reservoir, which has a top filler, in hindsight I should've bought a new pump and went with a remote reservoir...
Old 12-08-2017, 02:35 PM   #913
rwade
rwade's Avatar
Re: Owen's C10
I may have missed it, can you give me some info on your alternator and P/S mounting to the motor? Just using a fixed adjustment, not tensioner? Who built or what brand is your engine wiring harness?
Thanks, Wade
rwade is offline   Reply With Quote
Old 12-10-2017, 05:33 PM   #914
mooseknuckles
Re: Owen's C10
Thanks, Wade
The alt/power steering mounts are from ICT Billet, got them from Summit. it has a turnbuckle for adjustment. the harness is from PSI that I reworked quite a bit to go where I wanted it to..
Old 12-11-2017, 11:08 AM   #915
rwade
rwade's Avatar
Re: Owen's C10
And you switched to 98-02 LS-1 power steeering pump? The intake came from summit as well? How do you like the intake? Does it use the truck injectors? Thanks for all the info.
Wade
Old 12-18-2017, 04:20 PM   #916
rwade
rwade's Avatar
Re: Owen's C10
I'm not that familiar with the 98-02 Camaro (LS-1) power steering pump, can a remote resivoir be used with it?
Thanks, Wade
Old 12-18-2017, 06:24 PM   #917
mooseknuckles
Re: Owen's C10
Wade
it's just a normal power steering pump but the ICT Billet kit mounts the pump on its side like f-bodys, instead of up/down like others. The pump I have does not have a threaded fitting for a return line or else I could of went with a remote reservoir...would've saved me some headaches. The intake is from summit and was a good price, and looks good, but my tuner guy says it hurts torque. it also has a terrible resonating sound coming from the top that goes away when you put your hand on it probably from the material being too thin. The truck injectors I had to make fit, which means pulling the black plastic cups off the bottom of the injectors to make them fit down in the bores. I also had to cut down the brackets for the fuel rails because of the shorter truck injectors...not a big deal, but now I need bigger injectors since the stock truck injectors are now maxed out.
Old 12-18-2017, 06:29 PM   #918
mooseknuckles
Re: Owen's C10
Old 12-19-2017, 10:18 AM   #919
rwade
rwade's Avatar
Re: Owen's C10
Thank you for the valuable information. Your truck came out amazing.
Wade
Old 01-23-2018, 06:08 PM   #920
mooseknuckles
Re: Owen's C10
We had some nice weather on the weekend so I backed the ol' chevy out of the garage for a warm up ....
Old 01-23-2018, 06:59 PM   #921
rustytruck50
Re: Owen's C10
Cold & Cool!
-Doug
'05 RCSB Sierra 2WD
Old 01-24-2018, 07:57 PM   #922
Metaldoc
Metaldoc's Avatar
Re: Owen's C10
I see you guys don't have much snow as well, I'll be up on Aylen lake over by Barrys bay ice fishin in a couple weeks. I'm not sure on taking the sled.
Metaldoc is offline   Reply With Quote
Old 02-28-2018, 08:11 PM   #923
mooseknuckles
Re: Owen's C10
A couple pics of the billet a/c vents and heater controls.. that's about all I've done so far this winter but I do have some new parts ordered, and a few things that I have to get done in the next couple of months..
Old 03-01-2018, 11:24 AM   #924
BigDaddyV
BigDaddyV's Avatar
Re: Owen's C10
The truck looks Sick bro! Love every single detail you have put in to it!
This is one of the trucks that i hope mine will compare to one day!
Thanks for the inspiration!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 03-01-2018, 08:22 PM   #925
mooseknuckles
Re: Owen's C10
thank you!
