08-31-2019, 08:43 PM | #901 |
Re: What did you do to your truck today part IV
Finally got my radio wiring fixed. I didn't have the 12v constant wire hooked to a constant source It works great and sounds so much better than the old one.
I also swapped in the new gauge cluster that has a temp gauge instead of the warning light. Got a much cleaner lens as well
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-31-2019, 09:02 PM | #902 |
Installed my engine!
10-26-2019, 10:59 PM | #903 |
Moved the mudflaps closer to the rear tires and change tailpipes from dumping just behind rear tires to rear of the bed.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
11-05-2019, 10:24 PM | #904 |
Been moving along this summer.
Got the AC in and the engine running, It actually moves under its own power for the first time in 9 years. Tonight we finally finished all the painting, both fenders and the grille support. I may actually drive this thing next spring. |
11-05-2019, 10:46 PM | #905 | |
I got my power steering lines run today...should fire up the engine this weekend for the first time in 2 years. |
11-11-2019, 06:05 PM | #906 |
finally lubed up noisey speedo cable,painted rc truck to match
11-11-2019, 06:10 PM | #907 |
I had a "ziptie moment" My exhaust hanger broke and I had to use zipties to hold it up. I felt like I was channeling David Freiburger
11-15-2019, 04:24 PM | #908 |
11-15-2019, 05:27 PM | #909 |
11-16-2019, 01:02 PM | #910 |
I built a clutch master cylinder bracket that bolts on the inside of 60 truck. I bought a 3/4 bore master cylinder from speedway motors and made it work very clean and simple. Might sale some on the parts side of the forum.
Posted via Mobile Device |
11-16-2019, 06:49 PM | #911 |
Cut off the zip ties and replace the exhaust hanger. I ended up doing both sides. The bracket broke off at the hole where it bolts to the frame. I think it was because the bracket hole was larger than the one in the frame. So a smaller bolt was use which might have caused vibration in that location.
11-19-2019, 10:58 PM | #912 |
installed radio to fill dash that was pretty hacked up,added some repop knobs
11-25-2019, 08:46 PM | #913 |
turned old lunchbox into cupholder,large magnets hold it somewhat in place..
12-27-2019, 12:56 PM | #914 |
Mocked up Frankentruck's Christmas present to make sure everything clears.
Should I keep them red or paint them black?
12-27-2019, 01:15 PM | #915 |
12-27-2019, 02:45 PM | #916 |
I think with that patina they should be Maroon Colored.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
12-27-2019, 03:54 PM | #917 |
Moderator
Put my new brake booster and hinges on before I head back to work up north.
12-28-2019, 01:21 AM | #918 |
Thanks for the input guys. I'm still not sure what I'm going to do, but I might try to paint them as close as I can to the original 505 green. I think green wheels with white caps would look real nice
12-28-2019, 11:46 PM | #919 |
Yep, think green would look good!
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
12-31-2019, 07:51 PM | #920 |
Got the tailgate on and the windshield in. Neither was an easy task.
Happy to say they are behind me. |
01-01-2020, 03:28 PM | #921 |
It's Better With Nitro
Updated the cooling system between Christmas and New Year by modifying the fan shroud and changing out the fans to Derale Performance HO 12-in. fans and inset mounting them on the shroud. The temps stay steady now at 180 in stop-go L.A. traffic.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 01-01-2020 at 03:48 PM. |
01-02-2020, 05:59 PM | #922 |
Removed the propeller shaft and am trying to size the yoke to the rear of the 700R.
http://s1299.photobucket.com/user/jb...23904108567829 |
01-03-2020, 11:44 PM | #923 |
Managed to get one side of the suspension back together tonight.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 01-03-2020 at 11:51 PM. |
02-29-2020, 09:23 PM | #924 |
I removed my old jazz fuel cell in order to make room for my new Boyd tank. And new AN 6 fuel line which will replace my old and too large AN 8 fuel line. I am not sure whether to go with braided stainless an line or stainless hard line. I have had the tank for around 15 years.
03-02-2020, 02:58 PM | #925 |
what's the difference between a Fuel Cell and a Gas Tank?
