#926 |
A guy with a truck
Re: How to: Ruin a perfectly good C10
Yes, the Porterbuilt control arms I'm installing will move the lower ball joint forward 1", helping to center the front wheels in the wheel arch as well as adding some much needed caster. They offer uppers as well, but they will work as lowers only. The front wheels should move forward 1/2" or more...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#927 |
Truck and auto performance nut
I need to get around to this....bought tubular uppers but need to add the lowers. Part of me has been holding off tho...for a complete IFS from Scott's, Jim Meyer Racing, P.B., or others. Want coil over with rack and pinion front setup...IFS best way to get there I think.
Course its like my appetite....eyes always bigger then my.....................wallet! ![]()
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#928 | |
A guy with a truck
#929 |
Master Procrastinator
I love the current look wouldn't change a thing, drive and enjoy it
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
#930 | |
A guy with a truck
![]() Posted via Mobile Device
#931 |
this truck looks terrific!!!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#932 |
A guy with a truck
Hey thanks a lot man! Likewise--love your truck, just don't have that kind of budget
#933 |
![]() Join Date: Dec 2006
Hurry up and get these control arms installed, we want some more pics
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#934 | |
A guy with a truck
#935 | |
Now I got the "project parts blues" twitch again. ![]()
#936 | |
A guy with a truck
#937 |
Cool truck. Another good build thread I can use for reference.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
#938 |
A guy with a truck
Thanks, man. Looks like you've got it under control- nice build
#939 |
A guy with a truck
I'm back in town and have a short break in the action before work picks back up again, so I've been working on getting the Bilsteins mounted up. Since I'm mounting them in other than the stock suspension setup, they're requiring a little bit of custom work.
First, I decided I needed to raise the upper mounting points, both front and rear, to keep the shock from bottoming out and to position them closer to their center-stroke 'sweet spot' at ride height. Out back, I decided I would modify my existing mounts by re-drilling the ECE relocator. This gives me just over an inch of extra travel and only adds around 2* of lean, based on my limited geometric/trigonometric calculations--luckily my wife's an engineer ![]() After mounting them up, I took it for a drive, and WOW! I've heard good things about Bilsteins, but never experienced them first-hand. The truck feels completely different now; much softer, but more controlled feeling ride. I honestly was not expecting this much of a difference just from swapping shocks, much less the rears only. It is quieter, smoother, and and more composed. Money WELL spent. I'm anxious to see what the fronts do for the overall feel of the truck.
#940 |
A guy with a truck
As for the fronts, I will be using the CPP/POL style upper relocators, which require loop style mounting instead of the frame-mounted stud. The problem with using the Bilsteins with these is that the shocks come with the upper stud permanently attached. No biggie there, as I just cut the end off and pressed them out, but had to special order bushings to fit the width of the mount.
The lower end had to be modified as well, due to the PB arms using a 5/8" stud instead of the stock arms 1/2" bolt. I originally thought I would just press the metal sleeve out of the bushing, but they were permanently bonded, so I picked up a set of Energy Suspension hourglass bushings and pressed them in their place. Worked perfectly--now I'm just waiting for the upper bushings to come in...
#941 |
![]() ![]() Join Date: Jan 2011
Bilstiens kick major a55.. one of the best out there IMO
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#942 |
A guy with a truck
No doubt! I'm a believer, now. This answers your question on if they'll work with a 6" drop, too
#943 |
![]() Join Date: Oct 2010
Nice fab work, and install. the shocks, just goes to show sometimes it pays to spring for the good stuff ! looks like it's time to throw out my abacus and brush up on my trigonometrics. lol
John Mild Custom 68' Work Truck Build Facebook LoL 1977 Trans Am (Project) 1965 Chevelle (Project) |
#944 |
Still Learning
Keep up the good work. Still taking notes
![]() Posted via Mobile Device |
#945 | ||
A guy with a truck
![]() Quote:
![]() I'm still chipping away at it, but don't want to incapacitate the truck for too long, so the upgrades are getting broken down into manageable chunks. I'm thinking probably front C5 brakes next, since I can swap them out without affecting too much else (master cylinder, prop valve, lines, etc). The rear sway bar needs to wait 'til after I finalize rear ride height, which has to wait and see where the front ends up after the LCA install. I'll also prolly do the front shocks at that time to make sure my upper mounts line up well with the PB units. Rear discs will come somewhere in there after the fronts, which will be a pretty big job since I have to remove axles and swap out the master cylinder and prop valve in the process... Posted via Mobile Device
#946 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Don't remove the rear axles unless you need to replace seals and bearings.
I have seen alot of people just cut the backing plates in half and remove them,... without taking the axles out. (what are you going to do with the old backing plates anyway?)
#947 |
Good job keep at it.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
#948 |
That's great thinking out of the box I learn from guys like you every day
#949 |
GM Addicted
WOW!! I just went threw your whole 38 pages. Nice truck man. Been wondering what you were building when i bought those parts off of you. Nice truck for sure.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#950 | |||
A guy with a truck
Thanks! Plugging away... Quote:
![]() Quote:
