04-18-2014, 08:06 PM | #926 |
Re: Crusty Rusty Leaky Squeaky 67 Step
Way to forge ahead Vic. I'm equally disappointed as I was hoping the POR15 was going to be such a hit that I'd grab some for my DD Silverado and follow your footsteps. Oh well, the silver looks sharp and your custom center caps are going to finish them off nicely. Do you have rubber for them yet? What sizes are you thinking of using?
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
04-18-2014, 11:46 PM | #927 | |
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
04-21-2014, 10:54 AM | #928 |
Hammered away on sheetmetal some more over the weekend. Had several low crown areas that needed to come down before applying filler. Once I got started, it was a bit like "Whack-A-Mole" as one area settled down, another popped up. Started out using the spot shrinker, but had to get out Bertha with the SS shrinking disc. Using a little t-handle puller and flat hammer leveled out the last of the high spots. So, let the real mess begin ...Bondo Bob's Body Boutique is open for bidness.
04-21-2014, 10:58 AM | #929 |
67cheby
great work on the sheet metal !
04-21-2014, 11:09 AM | #930 |
SS Shrinking disk? What in the world.. how can that thing shrink metal??? Glad to see you at this stage!
04-21-2014, 12:15 PM | #931 |
I see your putting the bondo on bare metal, i hope its ok to put it over enamel based primer too? I was afraid my work was gonna rust and i have been side tracked a bit.
On another note i did buy a shrinking disk for my 4" grinder but never used it yet, i may have to give it a try soon on some scrap to learn how it works...
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-21-2014, 12:20 PM | #932 | |
On the plus side, it removes virtually zero material, although after repeated use, a small amount of buildup will occur on the disc. I then use a DA to dress the disc. It also handles large areas much more effectively. Downside to this tool is that if you're overzealous, it can affect the heat treat on modern sheetmetal causing it to become brittle. If you see blue steel, you're overdoing it. The guy I bought mine from no longer maintains a website (or has changed the domain name.) Ea$twood, Autobody Toolmart and others carry similar discs, though.
04-21-2014, 12:33 PM | #933 |
Did yours come from Sunchaser? Can't wait to see the Mud Mastery!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
04-21-2014, 12:33 PM | #934 | |
My shrinking disc is meant for a 7" sander that runs above 6000 rpm. Some smaller sanders and most all pneumatics don't have the HP to run it. If your disc is smaller, it should work great. If you didn't get instructions on using the disc, I can post a link to the ones that came with mine.
04-21-2014, 12:40 PM | #935 | |
I'd gladly take that link when you have time, no rush.
04-21-2014, 12:41 PM | #936 | |
Kathy is out making a mud run as we speak. I'm running low and she was headed in the right direction so I added one more stop to her list. Plan to blow the bed apart and do some epoxy priming tomorrow. Supposed to be nice out.
04-21-2014, 01:09 PM | #937 | |
Links to shrinker instructions attached. Sorry for quality, due to filesize limits, 100dpi was all I could do.
04-21-2014, 04:39 PM | #938 |
Thanks Vic for the links.
Trying to get an answer in the body thread but so far no replies, I was sold a tube of Bondo brand glazing and spot putty at the paint store, trying to figure out how thick it maximum for filling the voids on my bedside around the filler welds ect? Should i get a regular can of Bondo? this stuff say's fills pin holes, scratches and hairline cracks. http://www.shop3m.com/bondo-glazing-...F414csiCdS5icQ
04-21-2014, 05:03 PM | #939 | |
04-21-2014, 05:18 PM | #940 | |
http://www.autobodytoolmart.com/dyna...e-p-17610.aspx
04-21-2014, 05:45 PM | #941 |
Absolutely. Paint store would probably be a better choice since their inventory usually turns over more often than auto parts. Fresh plastic filler will be a little runny, which is what you need. The older it gets, the thicker the consistency and the larger the voids it leaves when it sets up. Just mix up a small amount and squeegee it over the area with the hiccups. Try to avoid going back over it too much because as it sets up, overworking it will introduce the porosity you don't want. I like the Putty Cote, but if you can't find it locally and don't want to wait for it to come from Toolmart, then regular filler will work in a pinch.
04-21-2014, 06:52 PM | #942 |
Just got caught back up on your progress Vic, looks like you're coming right along on the ole' girl.
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
04-21-2014, 07:12 PM | #943 |
Thanks, guys! I had to lay off for awhile doing some extra-curricular machine work, but I have a few days this week to devote to nothing but "truck time". I'll be back doing some buddy work next week, but then the coast looks clear. Me and Mr. Board Sander will have a putty party. I did manage to get the tires remounted on the rims today so the chassis will be down on all fours tomorrow morning. WooHoo!
04-22-2014, 10:16 AM | #944 |
Can't wait to see it back on the ground! Standing by for All The Mud Tricks You Can Stand!
Rat, I lay a skim coat of mud over the metalwork/lumps and bumps (literally, standard Bondo, I have a gallon I'm trying to get through), block it down with 80 until I'm close, then knock the 80 scratch down to 150 and hit it with Slick Sand/G2 primer from Evercoat. Get it from Toolmart/your Paint Store. Goes on thick and is great for 150 blocking down waves and filling pinholes and low spots in your filler. Then you can block it out from there. Sorry to jump in, Vic, just my .02.
04-22-2014, 11:40 AM | #945 |
Still Learning
Oh Vic you are bringing back some pleasant memories from last summer/fall. Your metal work looks fabulous. I like the metal shrinking wheel. I had to use a propane torch on mine, but I will own one of those wheels.
I'm with you on mudding to bare metal.. I would add, try to Stay completely away from that red spot filler made by Bondo co. etc., it will shrink way more than the primer over time. It can cause serious issues down the road. I really like the Dolphin glaze made by U-Pol, for minor surface imperfections. I have really liked the Evercoat rage extreme for my filler too. |
04-22-2014, 07:50 PM | #946 | ||
So this morning, I scrubbed the ozone induced film off the tires and cleaned off the handprints left by the tire guys, then mounted the rolling stock back on all four corners. This afternoon with the outside temp around 70, I mixed up a load of epoxy primer and squirted a few pieces top and bottom. This should be enough to get me into bondo mode. Also, now that the hood and riser are sealed, I can finally glue them together without worrying about condensation wreaking havoc at a later date.
04-22-2014, 09:13 PM | #947 |
Very nice work Vic. I'm looking forward to seeing how the hood scoop looks when you get it put on.
Scott |
04-22-2014, 10:25 PM | #948 |
Still Learning
Really nice progress.
04-23-2014, 08:12 AM | #949 |
Hooray! Hooray! Epoxy day!
04-23-2014, 04:38 PM | #950 |
Getting close, Scott. It's glued on and waiting for the adhesive to set. I prepped the areas around the edges with an 80 grit DA and then laid down a couple of beads of pookey around the perimeter. Tooled them down with an acid brush then weighted and clamped the edges of the panel. I'd marked the centerlines of the riser panel and the hood and traced an outline of the final position before mating the wet parts. Where the adhesive oozed out, I smoothed it down with a brush to make sure there were no small voids at the edge. I'll remove the weights and clamps in the morning and survey the results.
