12-29-2019, 10:02 PM | #926 |
Re: What did you do to your Blazer/Jimmy today?
Got my OG paint polished the rest of the way out yesterday and got the old original 307 fired off after setting in a barn for 20 plus years!
01-02-2020, 04:42 PM | #927 | |
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
01-02-2020, 05:55 PM | #928 |
Proprietor of Dale's Corner
Looks nice, more pics please.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-02-2020, 07:48 PM | #929 |
Looks great. Just need some tires that fill the wheel wells.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
01-03-2020, 10:16 AM | #930 |
Got the interior and patch panel paint finished. now its reassembly time with all new interior. I also ordered a "original looking" bluetooth radio from custom autosounds and the new push on door seals from GMC pauls.
'72 K20 Ochre/white 350/350/205 4" Lift 35's '72 GMC K10 red orange/white 400/350/205 '69 C20 Longhorn 454 TH400 '72 Blazer CST 4x4 '70 Blazer 4X4 |
01-03-2020, 11:37 AM | #931 |
Looks great!!!
Full top blazer or bust.... |
01-03-2020, 08:48 PM | #932 |
Is that a factory color?
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash 1972 SWB C-10 Highlander Blue/White 1972 Canadian 2wd Jimmy light olive 1970 SWB 4x4 4 speed 307 |
01-04-2020, 12:35 PM | #933 |
Thanks guys, have a set of 33’s with cucv Steelies waiting Togo under it. Got it fired off and drove it for the first time New Year’s Day! Have a short video on my Instagram Boonedogs32.
01-04-2020, 09:35 PM | #934 |
Preparing the rear passenger area for carpet.
Dynamat down, what about the wheel wells and the inside of the bed walls? Also, you can go to my build thread to look at additional pictures. Thanks, Pat |
01-05-2020, 11:45 PM | #935 |
Now the bed sides lined also. Then added 1.5" solid foam insulation over that.
Hopefully, this will make it sound a bit better in the cab. Pat |
01-06-2020, 05:21 AM | #936 |
Collector of Projects
On my resto-mod K5, I built the front half of a rear body harness. I used GLX wire and Deutsch connectors. I also added a couple wires to have my LED rear side marker lights act as rear turn signal lights as well. All covered in F6 split braided loom that was run along the body rather than inside the frame. I still need to build the rest of the harness on the truck to connect to the actual lights and tie into a trailer wiring lead.... |
01-06-2020, 12:03 PM | #937 |
01-06-2020, 04:24 PM | #938 |
01-09-2020, 12:46 AM | #939 |
Still have to get my other two wheels powder coated and mounted but couldn’t wait so....
01-09-2020, 05:57 AM | #940 |
Installed the custom rear body harness.
Terminated at a junction box so I can tie into the rear trailer harness (blue wire.) I also have LED lights on all corners and will have my rear side markers flash with the turn signals. I also ran the harness along the body from the firewall, along the rocker box, then up through the driver side wheel well. I still need to add some clips to secure the harness along the rocker box. It's wrapped in TechFLex F6 split loom. The only thing running inside the frame will be fuel and brake hard lines... |
01-10-2020, 07:02 AM | #941 |
I had my door panels sitting on a shelf for years...
I decided to take them down, wash them and hang them on the doors with a couple bolts. They were covered in Line-X and I had the trim powder coated in red. Still need some arm rests... trying to decide on Black or try Red.... I still need to install my NuRelic power window regulators as well... Then figure out what to do with the hole where the window crank used to be... Maybe a cup holder... |
01-10-2020, 06:06 PM | #942 |
I got the rear seat out of the donor 2001 Tahoe mocked up and made sure the passenger side would fold down correctly. Turned out pretty nice and will be a lot easier for the kids to get in and out.
1967 Chevy c20 1969 Chevy K20 1972 Chevy K5, LS Swap 1972 Chevy C10 1985 Jeep Cherokee SBC, sm465, np205 with 1 tons 2012 Jeep JK Last edited by Dchamber; 01-10-2020 at 06:14 PM. |
01-10-2020, 08:50 PM | #943 |
That's cool.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
01-19-2020, 09:16 PM | #944 |
New NOS caps for the blazer!
01-19-2020, 09:36 PM | #945 |
Designed and installed a bracket for my Dakota Digital gauge module and OBDII interface. Cut out of stainless steel on a waterjet. Bolts to the bake pedal/steering column mount.
01-19-2020, 11:15 PM | #946 |
01-20-2020, 12:07 AM | #947 |
01-30-2020, 12:58 PM | #948 |
Took it out of the garage.
01-30-2020, 02:29 PM | #949 |
Glad I could help.
01-31-2020, 02:13 AM | #950 |
