11-07-2022, 11:02 PM | #926 |
BlahBlahBlah
Re: Working Man's Burbon
Seats seats seats seats ... Lets see some more seats seats seats =)
11-09-2022, 03:28 PM | #927 |
Post Whore
Okay! Okay, I'm sorry! I've had some fastener issues to sort out.
The second row bottom seats had some rust on their frames which ruined some of the bolts. Fortunately although the threads in the frames were salvageable, five of the bolts were too rusted to use (Photo #1) and I did have 2 bolts that I twisted in two despite my best efforts. Being blind fasteners I had no way to get any heat on the nuts, even pentrating oil was almost impossible to get on the threads. Anyway not only did I need some bolts, I also needed some of the flanged spacers that GM used to prevent the bolts from being threaded in to far and distorting the backs. Most spacers were deformed from the bolts being over torqued (Probably with a mis-adjusted air ratchet.) Some of them were less than half as long as they should have been. My searches for another squarebody Burban at the u-pull-it yards didn't pay off. But I found some spacers that are used in cheap particleboard furniture that were almost perfect. I only had to drill the hole out. (See photo #2 the arrow shows a factory spacer with minor deforming, next to one of the furniture spacers.) Next was to make the new bolt heads match the original bolt heads (It's an OCD thing you may not have to worry about. ) I chucked the replacement bolts up on the lathe and made a smooth, slight dome on the top of the bolt head. (Photo #3) Once all of that was done I just needed a day when it wasn't raining. Which was yesterday! I still need to remove the seat bottoms on both of the lower seats so I can loosen the bolts that hold them to the mounts. Hopefully then I can line them up better. Worst case I will have to take a grinder and slot the mounting holes. But I was happy with how they fit before so I'm guessing it is a tolerance stacking problem. The only disappointing thing was the 503 green paint I got to paint the seat back latches isn't 503 but Detroit Diesel engine green. UHGG! You can kinda see it in the back of the last photo. Expensive paint that sprayed out really nice. Anyone putting a 471 in their truck need some paint? And for CG's information the front seat is all the way back in the last photo. Now I have the whole seat belt dilemma to get figured out.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-09-2022, 03:42 PM | #928 |
Wow...that's a slick looking install! I totally get the "matching bolt head" thing...you did a great job with that as well!
Woody |
11-09-2022, 05:20 PM | #929 |
BlahBlahBlah
Today I'm 100 percent convinced I want to do the rear seat like yours now. I love it, and your upholstery looks awesome.
Course now I have to source a seat haha. I hate going to wrecking yards anymore, no Im not turning in my man card, just one of those things I did all the dang time when I was younger ... Over it haha.
11-11-2022, 10:50 AM | #930 |
Post Whore
Thanks everyone. It makes the 2 year wait worth it. I was just my luck to drop them off right before Covid took over.
01-31-2023, 11:06 PM | #931 | |
02-01-2023, 04:26 AM | #932 |
I like your seats. I had a set of Squarebody backseats ready for my '67 K/10 Suburban, but the rear floorpan was not deep enough for the seat back. Then that truck got totalled.
02-03-2023, 02:12 PM | #933 | |
Post Whore
On the upside thank you for the kind words about the seats.
02-03-2023, 04:04 PM | #934 | |
It was ''totalled'' on paper by Farmers after an engine bay fire. Body is fine. With gas getting so high, I wasn't inclined to rebuild a BBC. My Sub now has a Salvage Title which would require a complete overhaul. With running trucks -- '68 C/10 Stepside and '71 GMC Jimmy -- I don't need a 3rd truck, especially with gas, insurance and maintenance. Set up was: 454/TH350/NP205/12 Bolt 3.73 w/Auburn Posi. The rear end was cannibalized into the Jimmy 12 years ago. The Stepside has the '67's horn button, hood letters ''E'', Voltage Regulator, and the hood latch, plus some odd signal lens screws. I have a 292 L6 core, an SM465/T221 core, a thrashed 1971 12 Bolt 3.73 Eaton Posi diff, and a partial Dana 44 front axle. Truck was originally rigged as 283/SM420/T221-?/12-Bolt open 3.73 -- I think. PO progressively up-gunned the motors... 283, 350, 454. And went automatic.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-07-2023 at 05:16 PM. |
02-04-2023, 12:04 AM | #935 |
Holy frijoles Batman! Your seats look incredible! Beautiful install as well!
To clarify more on my seat combo, I have 2004 Silverado seats in the front with the ‘86 rear. With this setup I’m a lil more forward with the rear seat folded flat. Having a 30” inseam it’s totally doable. Anyone taller may feel a bit cramped. YMMV
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
02-05-2023, 09:24 PM | #936 |
Post Whore
Thanks Joe. They are comfortable too!
And as always I appreciate the kind words. Not much else to report on, I put new front tires on 2 weeks ago and I've been driving around town searching for new fabric to replace the current fabric on the door panels, which should be the next project once the weather gets drier. The WMB is currently dirtier than it's ever been since I started driving it. It's either raining or freezing out. And just to complicate thngs I had Covid last month and my mother's apartment was flooded when the pipes in the ceiling froze and we had to move her into my sister's house and since have been working to dry her belongings out locate a new place for her to live. The odometer now shows 40k miles since I got the truck. Oh and I installed a clock in the WMB. My dad had a similar one in his K20 back in the day. And thank you to everyone who comes here and looks around. I'm finding it hard wrap my mind around the fact there has been 160,000 visits here.
02-06-2023, 09:17 AM | #937 |
Post Whore
The new clock!
02-06-2023, 12:00 PM | #938 |
The Older Generation
02-07-2023, 05:10 PM | #939 |
Classic clean look. Reflection of a simpler, more elegant era.
02-07-2023, 10:46 PM | #940 |
DUH! but it's not digital.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
02-07-2023, 11:48 PM | #941 |
And it doesn't have military time readout on it... LockDoc .
02-08-2023, 05:37 AM | #942 |
Whaddya mean it doesn't?
It clearly indicates 14:29. If it were 02:29 it would be dark, and you'd only see the lumimous hands.
02-08-2023, 09:27 PM | #943 |
Good point. or... is it a luminous face?
02-08-2023, 09:38 PM | #944 |
Any way, The seats look great.
02-10-2023, 04:08 PM | #945 |
Post Whore
And the installation went as planned with no additional can of worms to sort through.
02-10-2023, 04:20 PM | #946 |
Post Whore
[QUOTE='68OrangeSunshine;9176318]
Whaddya mean it doesn't? It clearly indicates 14:29. If it were 02:29 it would be dark, and you'd only see the lumimous hands.[/QUOTE Having spent most of my adult life working in the marine industry my brain is hard wired to the 24 clock. So for me what 68OrangeSunshine says is what I see . Correct with the exception of the luminous dial. I have to turn the dome light on sometimes.
02-10-2023, 04:23 PM | #947 |
Post Whore
Thank you, sir. Kind words like that make it worth the all the work.
02-11-2023, 04:09 AM | #948 | |
[quote=HO455;9177262]
The image of luminous hands was poetic license.
02-11-2023, 11:50 AM | #949 |
BlahBlahBlah
I think the watch is a neat period addition. I think if I ever actually get a truck on the road again Im gonna get one, but its going to be a Timex ... Keeps a licking and keeps on ticking.
And like the metric system, military time seems just out of my pea brain.
02-11-2023, 06:23 PM | #950 |
I don't think a watch would stay in that position very long the way I drive and use the sun visors.
In Arizona we have an active and agressive Sun. I often use the sunvisors against the glare of direct sun at or around Sunrise or Sunset. Even in winter. I pull it straight down if heading E/W into the sunlight or flip it 90* paralleling the window, N/S. Southbound, going Downtown in the morning -- breaking dawn in my eyes -- and Northbound, against the setting Sun in the late afternoon. A watch on a twist-o-flex type band might get flung off, and possibly fly out the window.
