05-13-2018, 02:32 AM | #951 |
Re: What did you do with your truck today, Part 3
many of you have read my battle with the carburetor on my truck. it ran good then it ran like crap for no reason. I adjusted something and it worked again only to run like crap again over night. I went to adjust the choke ( this was around christmas) and the electric choke body wouldn't rotate. I had to remove the screws all the way and pull the choke body off to get it to rotate. weeks later went to tweak the choke adjustment and again it wouldn't rotate. discovered tonight the choke body retaining ring was on backwards. I didn't install it and hadn't noticed it was backwards. once I flipped it the choke body rotated freely. I'm hoping that issue is resolved. did a slight choke adjustment and it fired great! before it fired well but the exhaust was very rich. smelled a lot better now. I plan to do an adjustment on the fast idle tomorrow.
05-13-2018, 09:04 AM | #952 |
The Parrell people did it!
05-13-2018, 12:35 PM | #953 |
I bought it second hand. the guy said he bought it just to run his motor after he built it and then swapped to fuel injection. I think he screwed up all the adjustments and assembly then sold it thinking it was bad. what a jerk. there have been a number of small things wrong that I adjusted out. it will probably need 2 sizes of main jets added and I need to set the fast idle and its golden.
05-13-2018, 12:44 PM | #954 |
WANTED! since I'm not cool enough to play on the wanted/for sale boards I need something guys. I need a section of firewall to use as a patch panel. I need the far passenger side section that has the access hole. anyone have a firewall they don't mind cutting up and selling?
05-13-2018, 11:44 PM | #955 |
started installing the alternator bracket but didn't get finished.
05-14-2018, 01:04 AM | #956 |
First off, I can't believe I didn't get something done this weekend, I started out thinking I would have that whole window done over the weekend, yeah right good luck with that. Between cutting my fingers pretty bad yesterday (not related to the truck) and Mothers Day today, going to two different cemeteries and putting flowers on a number of graves and going out to "Linner" and all that, not much happened. The photo of the truck up on the wall was my wife's choice of the restaurant to go out to, I had to think to torcher me looking up at "my truck" in the garage. LOL No, she is an angel she wouldn't do that to me.
But I did get out there and found that I was WAY off on the whole damn rear window thing! I am SOOOOOOO glad I caught on to what in the heck this whole thing was about because I could have made a real mess out of it. I can't even explain because it's so complicated but basically the window area that I am welding in isn't uniform across it, the shape changes because the glass is basically flat while the cab back is curved. I know I must have know this but I just caught it this evening after working on it the last two days. Soooo, it gets a lot more complicated but it's falling into place, glad I caught that! The "flow" from the body line at the bottom of the pillars to the area beyond that where there is no line is one of my issues. But I think I have got it! Anyway, we will get out there tomorrow and see where it goes. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
05-14-2018, 11:12 PM | #957 |
Fine tuning the left side of the rear window. The other side will be a breeze I am hoping once I get this side done.
Brian
05-15-2018, 02:40 AM | #958 |
05-15-2018, 09:43 AM | #959 | |
That sign brings back some great memories, I put it up in the garage back when I was a Cub Scout Den leader and I would have den meetings out there with the boys and their dads building Pinewood Derby cars and stuff like that. Brian
05-15-2018, 10:04 PM | #960 |
I was makin' dust in the garage and my brother in law Ronny stopped by with a couple of custom bed rail end caps, designed to replicate my tail lights. He added the rings around it for a nice little detail, I think they look pretty cool...
05-15-2018, 10:12 PM | #961 |
dude those are amazing!
05-15-2018, 10:15 PM | #962 |
I found yesterday that the new bracket isn't going to work. I have tons of height but no width. I think ive decided to try and build my own compressor bracket. I'm going to pick up some thin poster board tomorrow and start trying to mock something up. I'm sure it will take me a couple of weeks to get this to work but I will get it.
05-15-2018, 10:17 PM | #963 | |
05-15-2018, 10:32 PM | #964 | |
those are doper than a meth lab
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-16-2018, 02:35 PM | #965 | |
Brian
05-16-2018, 06:53 PM | #966 |
Thanks for the kind remarks guys, I will pass them along to Ronny.
Picked up my rear fenders from the body shop after work, they look great. I will drop off the doors on Friday, when they are done the truck will be ready for paint... |
05-16-2018, 07:07 PM | #967 |
Not a big step but a step just the same, I cleaned out a spot and moved the suspension donor around so that the wrecker can get a direct shot at it after I remove the pieces I want. There will be and empty spot in the yard in a day or so.
05-16-2018, 07:21 PM | #968 | |
Brian
05-16-2018, 07:32 PM | #969 |
I try to get something done every day, no matter how small the task. That's how progress is made...
05-17-2018, 01:18 AM | #970 | |
Yeah, this making a living crap gets in the way of all the good stuff! It doesn't look like I have got much done tonight but I actually have spent quite a bit of time out there the last number of days. This window is much more work than I thought it would be, no wonders no one has done what I am doing to this thing. Anyway, final trimming and tacked into place, WHOOO HOOO! Hopefully the other side will be easy using this as a pattern, I can only hope. :sweat: Brian
05-17-2018, 03:17 AM | #971 |
I may be taking advantage of Brian's "5 minutes a day" plan by using it as an excuse to work only 5 minutes a day, lol! Today I secured the battery cables to the firewall and installed my fan spacer. Okay, it probably took 10 minutes total...
05-17-2018, 09:47 AM | #972 |
The thing is, it's amazing how much you can get done over a few days of just going out there for such a short time. You got one step closer that you wouldn't have if you didn't spend that little time, right on!
Brian
05-17-2018, 08:13 PM | #973 |
Sanding louvers, what was I thinking?
05-17-2018, 09:16 PM | #974 |
Everytime I think about louvers I think about when I was 19 years old 40 years ago I was working a full blown restoration shop, we specialized in "Model 40's" which is the 1933 and 34 Ford. I paint many of them, in lacquer, cutting and buffing every single square inch including jambs to Concours d'Elegance perfection without so much as on spec of texture. With Lacquer we are talking lacquer primer sanded to perfect, applying four coats, sanding it, four more, sanding it, four more then sanding it to absolute perfection and then polishing it to a mirror.
Did I have any finger prints at the time...nope. Brian
05-17-2018, 09:30 PM | #975 |
Tired of doing mechanical work, I installed my rear fenders and hubcaps just to give myself some visual sense of accomplishment.
