Old 07-21-2006, 09:27 AM   #76
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Glock's official "Project 68" build thread
I'm hoping I can start to squirt primer after we get back from Sturgis. That would make me very happy!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-21-2006, 02:31 PM   #77
glock35ipsc
Well, I got the new ignition pieces today from Brothers. And of course the first thing I did was to cut them up!!!!
Well, sorta. I bought the spacer and bezel for a 67 because I wanted a small, flush mounted bezel, nothing setting in a recessed hole (pic 1). Next, I chucked up the spacer in the lathe and took off the larger part of the spacer with the three notches that sets against the dash metal. I cut it back to a length that I determined before I started (pic 2). The purpose of this is to allow me to cut a 1-3/16" hole in a yet undecided location (might be on the dash, might be under the dash, might not be anywhere near the dash ) and mount the switch flush in a flat piece of metal (pics 3 & 4). I haven't yet ruled out the possibility of making a new dash bezel out of an old glove box door. If I did that, I would mount it in the lower right corner of the "new" dash bezel.
I still need to cut a couple of small notches on the outer part of the spacer, and weld a couple of small pieces of 1/8" or 3/16" round bar to the backside of the metal so that it does not spin when I turn the key.
Bob
Old 07-21-2006, 03:08 PM   #78
Joe67
67 is sold
Never a wasted post in this thread
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-24-2006, 04:44 PM   #79
glock35ipsc
Well, not a whole lot of progress this weekend. I did get the hood, grill, lower grill splash guard, and the rear wheel well splash guards to the sandblasters on Saturday. Yesterday I mocked up the tilt column so I could install the Lokar shift cable setup. That was a *&#! Took some time, but I finally got it all installed and adjusted. Glad I did it now, cause I scratched the firewall and steering column up pretty bad! But it is done now, and it is adjusted, so when the truck is done it will go right together.
UPS came today and delivered some body tools I ordered from Eastwood, as well as the paint samples from Auto-Air Paints. I originally was going to paint it a dark blue, but fell in love with the truck I posted a few posts ago...light blue with a white top.
I'll get some pics of the shifter cable tonight and post them later.
I hope the pics come out OK, here is the sample bottle of color that I think I will be painting it....... at least until I change my mind again
Bob
Old 07-24-2006, 04:51 PM   #80
ChevyDude
Gonna be SWEET!!!
ChevyDude is offline   Reply With Quote
Old 07-24-2006, 07:53 PM   #81
glock35ipsc
OK, here are the pics of the Lokar shift cable installed/mocked up. When I tear it all back down, I will trim the gold horseshoe adapter that is bolted to the OEM shifter arm since I only need the one hole. I will also cut off the original hole on the left side there, and TIG the Lokar bracket to the OEM shifter arm
Bob
Old 07-25-2006, 12:19 AM   #82
powell72
powell72's Avatar
Good call on the light blue and white, the other color would be sweet too though but the two tone is classy.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 07-26-2006, 09:18 AM   #83
glock35ipsc
OK, got the third brake light from Ron Francis yesterday, and got it installed last night. Took awhile to make certain I had found the exact center! I forgot to take a picture of the layout marks, but got one right after I cut the hole. It took a little over an hour to tack weld in to be sure I didn't put too much heat into it.
Once welded in place, I had to open up the hole inside the cab where the dome lamp goes to be able to get the LED stick in there. The dome lamp still snaps in place nice and tight, and the bigger slot I cut is not visable at all. Got some mud on it last night, cut the first layer down, then put another layer on before calling it a night.
I like this mod, it's gonna look cool when painted!!!!!
Bob
Old 07-26-2006, 09:19 AM   #84
glock35ipsc
A few more pics........
Bob
Old 07-26-2006, 10:38 AM   #85
Joe67
67 is sold
Old 07-26-2006, 12:25 PM   #86
Lemield
Lemield's Avatar
That light looks VERY COOL!!! Great job!!!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 07-26-2006, 02:02 PM   #87
ChevyDude
Nice work....I gotta get a welder and learn how this melting metal stuff works!!!
Old 10-17-2006, 05:31 PM   #88
glock35ipsc
I guess I should post a little update of what I have got done lately....
Nuttin!!!!!!!
LOL, I thought I would have more time after getting back from Sturgis, but I guess I was lied to by someone!? Been working on a lot of house projects, installed a new fireplace, cuting and splitting firewood, painting, the usual "getting ready for winter" stuff. I also built this wood splitter, me and axes just don't get along!:
However, Powell72 and I have been working on an idea for rear disc brakes. I need to test-fit the template, and if everything looks good, I will have about 12 sets of brackets made up. A-527 Grade 50 steel, all laser cut, and set-up for 94-96 Impala rear disc calipers. These are simple calipers, and have no E-brake. Later I plan to have other brackets made that will accept Caprice calipers or Camaro calipers, both with integral E-brakes, as well as later Malibu/Monte Carlo/Chevelle calipers, and Caddy Seville calpiers with E-brakes.
I have some other things lined up to try to build as well; like new trailing arms, frenched antenna kits, automatic transmission crossmembers, filler pieces for stake pockets and side marker lights, as well as different stages of the rear disc brake kits. I guess when/if that happens, I will probably need to become a board vendor?
It's snowing right now, so maybe the outside chores will get delayed and I can hide in the shop for awhile!
Bob
Old 12-27-2006, 10:38 PM   #89
glock35ipsc
Wow, I actually got time to work on the ol girl today! Of course, I had spent the entire day yesterday cleaning the shop just so I could find the truck!!
I started installing the fuel filler today. I got the filler door assembly from Hagen Street Rods. Anyhow, here are some pics of the install. It's obvious that I haven't turned on the TIG welder for some time. Need to get back into tigging form again.
Enjoy!
Bob
Old 12-27-2006, 11:59 PM   #90
dirtball
dirtball's Avatar
Nice. How did it feel cutting into that new bedside? Good news, I finally talked Howard out of that short fleet bed Now I can hang with the cool kids with shortbeds.
dirtball is offline   Reply With Quote
Old 12-28-2006, 12:10 AM   #91
glock35ipsc
LOL, kewl!!!! We wooda let ya hang with us anyhow!
Ya know, I didn't even think about it when I went to chopping into it. I guess after 10 years at Vanworks and cutting the huge window openings in the van sides, I guess I am kind of hardened to it.
Bob
Old 12-28-2006, 12:29 AM   #92
72armyswbtruck
72armyswbtruck's Avatar
Man you have done some nice work there
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 02-17-2007, 08:11 PM   #93
regal8r
progress? lol
regal8r is offline   Reply With Quote
Old 02-18-2007, 08:33 PM   #94
glock35ipsc
Progress = very little There has been too much snow to work on the truck, we've been snowmobiling practially every weekend! That, and I have been working on my new CNC plasma cutting table when I have spare time.
Bob
Old 02-18-2007, 10:48 PM   #95
Chevy_Man
Tightwad
Chevy_Man's Avatar
Great progress, what do you plan to use for ac....stock or aftermarket?
Eric
56 Chevy custom cab step side under construction
55 Chevy 210
68 SWB Stepside back burner under construction
72 Chevy LWB
84 CJ 7
05 Chevy 1500 Crew Cab
30X40 DOGHOUSE(shop) with many add ons
Chevy_Man is offline   Reply With Quote
Old 02-19-2007, 12:48 AM   #96
glock35ipsc
I will be a Vintage Air system.
Bob
Old 02-19-2007, 09:33 AM   #97
Chevy_Man
Tightwad
Chevy_Man's Avatar
Hey bob if ya would post some good pics of the ac system when you do that step i am undecided what i am going to do. my bab is a noon ac cab also...
Eric
55 Chevy 210
72 Chevy LWB
84 CJ 7
Old 02-19-2007, 10:04 AM   #98
msgross
msgross's Avatar
nice log splitter, guess that you don't handle to many large logs since it's 3 feet off the ground! i remember the days on the farm and rolling 200 lbs + tree trunks onto the ole splitter! I love my Natural Gas now!
Nice work on your truck too!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-19-2007, 10:14 AM   #99
glock35ipsc
LOL, no, about the largest I bring home is only about 16" or so in diameter. I cut them into 16"-18" long pieces then split them. I had looked at other splitters, but could only see my back hurting from leaning over all day, so I made this one to a good waist high or so working height.
Bob
Old 03-08-2007, 03:51 PM   #100
glock35ipsc
Whew, is this thing EVER gonna get done?? LOL, there is now light at the end of the tunnel!
The one big thing that has been holding me back is the hail dings in the roof. I HATE body work!!!! Well, a while back I sold one of my welders to a guy who has done body work for 20+ years. I made him a good deal on the welder, so he is going to fix my roof! As soon as I have it off the frame and back on the dolly, he will come over and get the roof smooth.
I have been putting it off for sooooo long now because of that stupid roof. Once the roof is fixed, there is just minor work left on the cab corners and rockers, and that will be easy. Then it's primer time baby!! And that can only mean one thing.....paint is next!!
Bob
