03-12-2013, 10:52 AM | #76 |
Re: you want to change your 5X5 bolt pattern on 73-87 disc to 5X4.75
subscribed. hopefully you guys come back with updates.
I did the C5 swap on my 3rd gen Camaro and would love to do the same on my C10.
'87 R10 - 5.3, 4.8 Flat Top Pistons, 220r Cam, Long Tubes, P&P 862 Heads, 4L80e '84 C10 - 5.3, LS6 Cam, 4L80E, 3.73, Ported Heads 329hp/334tq !! STOLEN !! 2-15-13 North AL Click Here:How To DIY Port & Polish LSx Heads Videso by "AGearHead4Life" |
03-12-2013, 11:55 PM | #77 |
I Did the Camaro 1LE rotor swap on my truck. I Had a set of wheels in the 5x4.75.
Before and After:
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
03-13-2013, 05:35 PM | #78 |
A guy with a truck
Confirmed. Nice work! The C5 swap works,too. I have them on my 70 (in sig)
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-18-2013, 10:47 PM | #79 |
gringoloco, thanks for posting those pics what are the 2 bolt patterns on your rotors?
I have a curve ball for you guys, I have a 64 C/10 and I want to run a 5 x 4.5 bolt pattern wheel!! Yes this is the anti-christ of ideas, it happens to be a Ford wheel, but almost nobody will identify it as such. I plan on running a Ford 9" in the rear so I think I have a handle on the rear. ANY HELP HERE?? |
04-02-2013, 08:11 AM | #80 |
k... this thread gets a little confusing... I have some drop spindles on my truck installed by the PO. not sure what the brand is. The front is disc brakes though... Can I put the g10 rotors directly on the spindles I have now? I am pretty sure that the G10 spindles use an A3 outer bearing and an A5 inner bearing. I am trying to confirm that now, and its driving me nuts. Also, what does height mean on a rotor?
"Live, Love, Build cool s***" Jesse Chapman, 2013 My Truck.. http://67-72chevytrucks.com/vboard/s...d.php?t=567219 |
04-02-2013, 08:26 AM | #81 | |
The difference is in the thickness of the rotor. The 1.25" rotors are considered HD & use one combo of bearings. The 1" rotors are considered lt duty & use a diff combo of bearings. The trucks utilized each type of rotor by using different spindles & brake assemblies (vans were the same deal). Aftermarket drop spindles are available for each brake type (HD & lt duty). You have to have the lt duty spindle to swap off the shelf car pattern rotors. To determine if you have the right spindle, measure the thickness of the rotor.
04-02-2013, 08:32 AM | #82 |
thanks SCOTI, that helped a bunch. I love my drop spindles, and I don't want to have to change spindles and springs to get the same height... while searching for rims I have found it a bit difficult to find 5x5 rims I like for cheap.. and I wanted to run the 2010 camaro steelies. I guess I will just find another cheap rim.
04-02-2013, 08:46 AM | #83 |
hmm. with 81+ c10 lt duty brake drop spindles, what calipers work? the c10 or the camaro or both?
04-02-2013, 09:08 AM | #84 |
More than likely both but I would spec them for a lt duty C10 since that's a no-brainer.
01-26-2014, 11:30 AM | #85 |
Hi all I know this is an old thread, but I have a question. I have a 76 c10 with the 1.25" rotor. I bought a set of used drop spindles that appear to be for the LD 81-87 truck. Both my inner and out bearings do not fit the spindle. The grease seal appears to correct. My caliper, that I just rebuilt, slides into the "pocket" of the spindle and appears that i would bolt up. My question, is this a simple change of rotors and bearings? Or am I going to need the later calipers as well, possibly brake lines too?
I am not opposed to going to the thinner rotor, I just want the least hassle. Money is an object but safety is a bigger factor. If I have to get the HD spindle I will, but if I can make this work for less I would like to go the direction I am headed. Thanks, Matt
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
01-26-2014, 11:47 AM | #86 |
I think I should add that the outer bearing will not readily slid onto the spindle. The spindle itself has GM T cast into it as well as N357-87.
01-26-2014, 12:34 PM | #87 |
67-72 parts collector,…
Spindle, bearings, caliper and rotor ALL have to match.
So if you have 1.25" rotors now,... EVERYTHING will have to be switched to work with the Light Duty spindles.
01-26-2014, 02:30 PM | #88 |
Thanks for the response, I will find the correct spindle and keep it simple.
01-27-2014, 11:13 AM | #89 |
Square
i just had a machine shop re-drill my rotors and shave down the outer part of the hub a little bit, cost me 20 bucks to switch to 5x4.75 in the rear i swapped the axle for a 80's camaro. super easy.
Squarebody Syndicate Last edited by broey; 01-30-2014 at 11:30 PM. |
01-30-2014, 11:15 AM | #90 |
Wow, That easy huh... cool.
01-30-2014, 11:24 AM | #91 | |
04-05-2014, 10:53 AM | #92 |
Is it possible to adapter hubs like these to work?
http://www.flynbye.com/catalog/i225.html Or maybe the Kore3 version? |
04-05-2014, 10:58 AM | #93 | |
http://www.kore3.com/proddetail.php?prod=10038-F3 Then we could use the slip on rotors? |
04-05-2014, 07:33 PM | #94 | ||
10-28-2015, 08:43 PM | #95 |
[QUOTE=502tripower;3031272]Now we all know that the 73-87 front crossmember and suspension components can be swapped into the 60-72 trucks. The 73-80 Chevrolet C10 pickups used a 1.28 rotor. Then in 81-86 GM switched to a 1" rotor. I did a bit more digging and found that the calipers are different for the 1" rotor but use a common bolt pattern with 73-80 so, it looks as if the 91 Camaro rotor will work on the 73-86 spindles if the 81-86 calipers are used as well. Also the flexible brake line will need to be changed if you have the 73-80 caliper as one of the calipers uses American standard thread and the other uses a metric thread. The parts house could not tell me which one used what thread but that they were different. I will figure that out when I purchase the parts. I have not done this yet but it does look like it will work. fones1966 a member here PMed me telling me about this possibility and I want to thank him for that. I just thought I would post this information in case there were others that could use it. Olympic Brake here in Washington is who provided this information. One note I want to point out is the specs that I have all show the same bearings on all three rotors. I was told by fones1966 that the 73-80 1.28 rotor used a A-5 inner bearing so that bearing would have to be replaced when switching to the Camaro rotor but, what I found was the 73-80 heavy duty 1.28 rotor used the A-5 inner bearing and the 81-87 light duty rotor used the A-6 as shown in the specs I have provided. I hope this information is helpful. Here are the specs on both the truck and Camaro rotors:
73-80 Truck rotor specs are: Height 4.88 Diameter 11.85 Min. Thickness 1.220 Hub 3.06 Outer bearing A-3 Inner bearing A-5 Seal Part # 8871 Bolt Circle 5X5 81-86 Truck rotor specs are: Height 4.63 Diameter 11.86 Min. Thickness .96 Hub 3.20 Outer bearing A-3 Inner bearing A-6 Seal Part # 8871 Bolt Circle 5X5 91 Camaro 1LE Performance Package rotor specs are: Height 4.65 Diameter 11.85 Min. Thickness .97 Hub 2.78 Outer bearing A-3 Inner bearing A-6 Seal Part # 8871 ok....I know this post is old and I'm gonna ask for info outside of this forum but any possibility of swap knowledge or ideas could help....I want to convert my 1996 tahoe 2wd to 4.75 bolt pattern up front and run a 96 corvette IRS in rear....looked at camaro rotors no good and several more....any imput here would be welcome...Thanks, cliff Last edited by vettemad; 10-28-2015 at 08:44 PM. Reason: im a dummy |
08-14-2016, 03:38 PM | #96 |
Active Member
i know this is an old thread but, does anyone have the part number for the drop spindle or stock spindle for the 81-86 c10? when i look them it it just shows 73-87. i looking to do the 81-86 spindle with the camaro 1LE rotors. thanks
08-14-2016, 04:51 PM | #97 |
Belltech 3200 drop spindle.
These work with all 73-87 balljoints and tie rods, but you have to use the 1" width rotor. https://www.summitracing.com/parts/b...0/applications
08-14-2016, 05:09 PM | #98 | |
Active Member
08-27-2017, 05:56 PM | #99 | |
Can you provide a part number for them. I have a 66 chevelle and my current rotors make the front wheels sit to close to the fender lip, these low profile rotors look like they could solve my problem. will they work with the stock calipers? thanks |
08-28-2017, 12:21 AM | #100 | |
A guy with a truck
