Old 02-21-2009, 02:36 AM   #76
Twisted Minis
Twisted Minis's Avatar
Re: Not so budget 3-link build
Originally Posted by p8ntballer1911 View Post
Is a wishbone the same as a 4link, as in it need to be level at ride hight?
You would install it the same as a 4-link. Lower bars level or close to it at ride height, upper bar point down slightly towards the cab.
Originally Posted by abadsvt View Post
Thanks for the insite! Wow 200psi and not even a little buldge! Thats great news. If you have any pics showing where you used the frame or cross braces as air tank I would love to see them. I am not going to do this for my current build but would like to keep that in mind for future builds. I am always doing my homework. Thanks again.
Josh
Here's some from when I was building it.
I capped the front of the rails where they transition into the stock frame.
Here you can see I cut two 1" holes on each side of the frame where another cross member will go.
Now the cross member in place, and the initial pressure test of 120 PSI. I let it sit for 3 days to see if it would leak down over time. It's all TIG welded, and I didn't find any leaks. Over 3 days it lost 2 PSI. I figure it was either in a fitting, the schraeder valve, the gauge, or a pinhole too small to detect. I later tested it to 200 PSI and let it sit for about 20 hours with no change in pressure.
Here's that cross member. I spaced the ports out so that the valves van be mounted to the frame.
And a last shot of it installed.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 02-21-2009, 11:48 AM   #77
scotts62
One day...
scotts62's Avatar
Heck yeah man looks good nice work!
Scott
93 crew cab build
Project 62
Old 02-21-2009, 01:13 PM   #78
abadsvt
abadsvt's Avatar
Awesome! Thanks for the pics! One of these days i am definately going to have to do that. Very clean!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 02-22-2009, 10:16 AM   #79
grinch4om
dang its hot
grinch4om's Avatar
unbeleivable workmanship, way overkill on strength but that is coming from a drag racer so I look at things different. Thanks for teaching
grinch4om is offline   Reply With Quote
Old 02-23-2009, 08:05 PM   #80
Twisted Minis
A shot of the finished shock towers, and one of the wheel turned with the new narrowed control arms.
Truck is done now. Just waiting for it to be picked up so I can turn the Toyota around and Z it.
Old 02-23-2009, 08:09 PM   #81
Twisted Minis
Got in some Tech Flex so I finished up the wiring. First shot is the valve wiring. Second is the power wiring. Third a close up of the Tech Flex I mentioned. Fourth is the switch box wired up and the bulk under the carpet.
Old 02-24-2009, 02:14 AM   #82
project 67 sub
project 67 sub's Avatar
no vids of it in action......
project 67 sub is offline   Reply With Quote
Old 02-24-2009, 09:15 PM   #83
Twisted Minis
Of what in action?
Old 02-24-2009, 09:41 PM   #84
p8ntballer1911
Bodydropped71
p8ntballer1911's Avatar
I was originally planning on making my back-half an air tank. But I went the other route because i was worried about getting it all sealed up.
Btw did you get those tabs out?
p8ntballer1911 is offline   Reply With Quote
Old 02-24-2009, 09:51 PM   #85
Twisted Minis
Ya I sent the new tabs out today. I ran out of shipping labels and got some yesterday.
Old 02-24-2009, 10:51 PM   #86
project 67 sub
that truck you are redoing the air suspension on, im a sucker for vids on bagged trucks
Of what in action?
Old 02-24-2009, 11:19 PM   #87
Twisted Minis
Are you talking about the one that I just finished? Because that one does not run, and it's on T'd lines with schraeder valves. It wouldn't make for an exciting video.
And the other one is still on jack stands with no wheels on it.
Old 02-28-2009, 05:37 PM   #88
project 67 sub
oh ok
Old 03-02-2009, 02:56 AM   #89
Rorkrado
Rorkrado's Avatar
Awesome fab work! I dont suppose you'd hint me to where i might find some short limiting straps like that. All the ones ive found are for rediculous ammounts of travel. It would be much appreciated!
'66 c10 draggin' bumper
'41 business coupe in progress
Rorkrado is offline   Reply With Quote
Old 03-02-2009, 11:25 PM   #90
Twisted Minis
Check out Poly Performance. They make the ones I use, and you can order them in black or red, and in 1" increments starting at 6" I think. They measure eye to eye and use a 1/2" bolt. They will also do you a custom length set you just have to wait a few extra days.
Should have more pictures tomorrow. I'm in the middle of Z'ing the frame right now.
Old 03-02-2009, 11:30 PM   #91
edflores
http://www.polyperformance.com/shop/...trap-p-47.html
edflores is offline   Reply With Quote
Old 03-03-2009, 05:09 AM   #92
Rorkrado
Rorkrado's Avatar
Thanks guys, thats exactly what i was lookin for. Cant wait to see pictures after the Z
Old 03-03-2009, 05:39 AM   #93
dammitmitchell
the pollock
dammitmitchell's Avatar
ok read this fully before assuming im saying somethin wrong..
you dont do "good work"
you attention to detail and all the the subtle hints are awesome.. just incredible..
an then you dont just do "one thing" in one spot to show off..
you repeat the design to complete the entire visual package..
the welds are also.. just damn good dude.. wish i could weld like that..
you do an incredible job.. "good" is an insult..
too bad i havent seen an 4x4 stuff from you... i might have to sell one of my children off for that work...
thanks dude.. incredible stuff you got going on there
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 03-03-2009, 12:20 PM   #94
Twisted Minis
Wow, thanks man!
I actually grew up doing nothing but 4x4 stuff. My uncle had a shop until I was 16. I used to have pictures of some of the things I have done for 4WD, but my computer crashed about 6 months back, and I have nothing left. And I have done no 4WD work since then. I have something potentially coming up in about two months, but I don't want to talk about it an jinx it. They usually don't come through once I start talking like it's a sure thing.
Old 03-03-2009, 10:36 PM   #95
Twisted Minis
Doing the frame Z now. First two shots show cutting out, and smoothing the VIN stamp that protrudes from the frame. It gets in the way of plating the frame. Third shot shows the frame cut and moved up.
First shot here shows the Z fully boxed. Second is the VIN welded back onto the frame, and last is an overall shot.
Old 03-05-2009, 09:22 PM   #96
Twisted Minis
Started some upper shock mounts.
Old 03-06-2009, 01:15 AM   #97
Rorkrado
Rorkrado's Avatar
very nice shock mounts.
Is the toyota getting triangulated LCAs like the ones posted on page 2? If so, is there a way to determine haw far apart you'd put the two bushings? or just whatever fits best?
Old 03-06-2009, 01:24 AM   #98
Twisted Minis
I'm doing it a bit different on this one, and actually keeping the strut rods. But normally I would push the bushing out as far as possible without interfering with anything. The wider the arm is the more stable it is. I just want to try something different with this one, and make the strut rods work with the Z, since I am doing a tech article for MT on this.
Old 03-06-2009, 01:34 AM   #99
Rorkrado
Rorkrado's Avatar
Cool! I cant wait to see what you come up with. Again, very nice work.
Ian
Old 03-06-2009, 01:40 AM   #100
Twisted Minis
I'm basically just modifying what is already there. I just want to show that this could be done over a weekend with some friends if your truck is already bagged. Even though I sell control arms that eliminate the strut rod on these trucks. Lol.
