Old 03-22-2009, 11:10 AM   #76
Strodder
Daring to be Different
Strodder's Avatar
Re: Shrunken66Stroker's build thread.
Hang in there. You still have a lot more sanding to do. Even after it's painted. But it will be worth it. Keep up the good work.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 03-22-2009, 11:59 AM   #77
shrunken66stroker
shrunken66stroker's Avatar
WARNING! This thread will slow down drastically for the next few weeks. I've got a baby boy on the way that's due on Thursday. I'll be on lock down for a while after that. I'll have to sneak out for an hour or two at a time, which we all know isn't enough to do much. I've also got a big job coming up at the end of April so progress will be slow for a while. Hopefully I'll have wheels in May and this thing will be on the ground.
shrunken66stroker is offline   Reply With Quote
Old 03-22-2009, 12:10 PM   #78
Strodder
Strodder's Avatar
Congrats on your new baby Boy. Your life will change. Hang in there.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-22-2009, 03:49 PM   #79
Strodder
Strodder's Avatar
Glad to see it didn't blow up on you. I'll have to take a trip to the salvage yard and see what they have.
I just saw this tank on e-bay. What do you think?
http://cgi.ebay.com/ebaymotors/CHEVR...mZ170297956499
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-22-2009, 04:00 PM   #80
shrunken66stroker
I have a 2yr old already so I know the deal. It's just alot less sleep and twice the dirty diapers.
The tank on ebay looks iffy. I'd rather have someone else guinea pig that one. I'll go the scrap yard route I think. Thanks
Old 03-22-2009, 11:22 PM   #81
SCOTI
SCOTI's Avatar
Awsome build & excellent documentation so far. You mentioned the Baers were pricy. If you don't mind, how bad was it? Looks like 13" GT-Plus up front & 12" Track-Plus out back?
Also..... Could you take a measurement for me? I was curious of the dimension between the top of the frame rail to the top of the ART c-notch.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-23-2009, 12:16 AM   #82
shrunken66stroker
It's a 13" GT-plus 2 piston up front and a 13" track plus single piston out back. The size is why I spent the money for them. I'm going to be running 20's on front and back and wanted them to be the rotors to be the same size. I looked for the Baer receipt but couldn't find it. If I remember correctly the set up with 2.5" drop spindles, steel braided flex lines, drilled and slotted rotors and adjustable prop valve was a little under 4K. Call Baer and order from them directly like I did and you may save a little. The pads are a direct swap with 97' Corvette pads when they ware out.
The frame above the rear axle is about 5.5" thick. After the notch there is about 1 5/8" of thickness left. There is still frame rail underneath and it seems pretty solid. The notch is made of the same thickness steel that the frame is. Each notch is bolted in with two 5/8" bolts and twelve 7/16" bolts.
Old 03-23-2009, 12:41 AM   #83
SCOTI
SCOTI's Avatar
It's a 13" GT-plus 2 piston up front and a 13" track plus single piston out back.... If I remember correctly the set up with 2.5" drop spindles, steel braided flex lines, drilled and slotted rotors and adjustable prop valve was a little under 4K."
Ouch!
1 5/8"..... Excellent. Thanks very much!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-23-2009, 01:52 AM   #84
shrunken66stroker
After I put the stroker in it, I'm going to drive the $h!t out of it on the track. I don't want this to be a work in progress for ever. It's going to take a while longer now to get it finished but when I'm done there won't be anything left to upgrade.
Old 03-23-2009, 04:03 PM   #85
83burban
Great work...couple questions though.
What body filler are you using, and what brand primer do you plan on using? I am trying to save up for my body work right now and am looking for suggestions.
83burban is offline   Reply With Quote
Old 03-23-2009, 04:10 PM   #86
shrunken66stroker
I'm using Evercoat Rage Extreme filler. It's not cheap but it's the best I've ever used. The first primer is going to be a ureathane epoxy primer because the truck is in bare metal but has filler on it. The second will be Evercoat Slick Sand. It's a high build primer surfacer that will flatten out nice after block sanding. You have to shoot it through a 1.8mm tip at least because of the high content of solids in it. It creates extra work on flat panels but sands extra straight.
Old 03-24-2009, 01:33 PM   #87
aggie91
I'm just glad to be here!
aggie91's Avatar
Congrats on the Baby Boy!! My youngest 2 are only 22 months apart so I know what is ahead for you.
I love this build. I have a 65 that I got from my grandfather when I turned 16 I have owned it longer that anyone else...I am the 3rd owner. Grandpa bought it used 7 months before I was born. My plan for it is similar to yours, stock outside, modified under the skin...
Again, great work.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-24-2009, 09:11 PM   #88
shrunken66stroker
Thanks Aggie. It might be a while before I'm posting progress again but I'll still throw things out every now and then. For instance, did chevy engineers design in a place on the inner fender for tools and hardware? What other purpose could this indentation serve?
Old 03-24-2009, 09:20 PM   #89
protrash64
Resistance is Futile
protrash64's Avatar
Talking Re: Shrunken66Stroker's build thread.
I know!!!! ..I worked with an older guy and he said they used to put beer in there to get it into the drive-in!!! The whole space, anyway....
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-24-2009, 10:40 PM   #90
Strodder
Strodder's Avatar
But who would want warm Beer?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-24-2009, 10:53 PM   #91
joe231
joe231's Avatar
maybe room for the hinge to fold down
CHEVY ONLY
Old 03-25-2009, 01:49 AM   #92
shrunken66stroker
good point. i'm going with a hard ware dish though.
Old 03-25-2009, 08:12 AM   #93
joe231
joe231's Avatar
CHEVY ONLY
Old 03-25-2009, 09:25 AM   #94
jchav62
1962 C-10
jchav62's Avatar
Good info, Greg...You really know your sh!t!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-25-2009, 01:22 PM   #95
shrunken66stroker
Thanks Joe. Wish me luck, we're going in tonight at 10 to be induced. Should have a baby boy tomorrow morning some time.
I'm doing my part to pass on the Chevy truck lovin gene. Be back around soon.
Old 03-25-2009, 02:37 PM   #96
jchav62
1962 C-10
jchav62's Avatar
Good luck! Congrats... Keep us posted.
Joseph Chavez
Old 03-25-2009, 03:06 PM   #97
4dranch
Shloooooong bed member #2
4dranch's Avatar
Congrats...
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 03-25-2009, 03:08 PM   #98
derider
derider's Avatar
Good luck hope everything goes good. Before you know it you will have a liitle truck buddy!
derider is offline   Reply With Quote
Old 03-25-2009, 03:10 PM   #99
Strodder
Strodder's Avatar
Good luck to you & your wife on your new Boy. Need pictures.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-25-2009, 03:50 PM   #100
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
is that a 5 on 41/2 bolt circle i couldn't tell by the pics
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
1966, bagged, disc, long to short, stroker
