#76 | |
Re: Lets see your seat swaps....
That is exactly what I am trying to do in my 86! I wanted a leater bench seat style with some comfort and a faold down console. I am actually looking to use the back seats from a King Ranch ediction Ford (I know, sort of sacriligious, but they look real nice). How much leg room do you have compared to the original seat and how much modification did you need to do to make them work in the cab? Plus, any more pictures you could provide would be greatly appreciated. Thanks! |
#77 | |
Windy Corner of a Dirty Street
Sorry I missed your question 8 months ago ![]() I actually used a Hi-Lift Jack mounting bracket to help create the inboard mount. I cut the bracket in half then welded it to the Suburban seat frame. ![]() ![]() Hi-lift jack bracket that I cut in half. Worked perfectly ![]() Here are the seats after re-upholstery ![]() 2010 GMC center fabric ![]()
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
#78 |
![]() 2007 Subaru Impreza buckets and a Blazer console in my '71 stepside. Not a 73-87, but I've done the same thing with an 85. I did a how to, that works for most odd-ball buckets from wrecking yards. Last edited by SeniorVerde; 11-04-2014 at 05:53 PM. |
#79 |
#80 |
Carboncrew, I like those, how wide are they? I tired to fit an early 90' series bench in my 86' but it was not wide enough and didn't line up with the steering wheel.
Thanks! |
#81 |
#82 | |
These are the new seat sitting on an old bench frame. The seats are actually pushed tight together in this pic so once mounted and proper gap between the seats adjusted they were a little wider than what this shows. ![]() ![]() |
#83 |
I check with the guy in Arizona you bought those seats from, he charges $220 to ship. GAH!
#84 |
[QUOTE=carboncrew;6904553]These are 2nd row seats from a honda odyssey ('take outs' from handicap conversion vans). Cheap, new and matched the 91 chevy light gray perfect led me to this decision.
These are the brackets I had to make: ![]() Once again very clean truck , Im not into aftermarket seating,,,, though you nailed it, and that truck all aroud, with your burb upgraded burlwood interior, mirrors. and of course black, that pick-up would fit in at my house.
70 SS 454 Monte 69 355 C-10 Shortbed 90 454 Crew dually 4x 76 454 Dually 2x 75 454 K5 77 468 Kona Last edited by tobytuttle; 11-05-2014 at 01:13 PM. |
#85 | |
I could maybe carry a set halfway (oklahoma) when I visit my sis this spring, if that helps. |
#86 |
I appreciate the offer, I'll probably stick with my buckets for a while though. I have to use them for my center console that holds the tablet and camera system.
#87 |
I did pretty much the same thing 86jimmy4x4 did with his seats, except i threw in a center jump seat from a 2003 pickup that I got from Ebay. Everything bolted in. No cutting and welding involved. I slid the center jump seat front brackets underneath the bucket seat brackets, and drilled the inside mounting holes through the floor, and got creative with some clamp style bracket for the back of the center jump seat. All in all it took me about 4 hours to do everything by my self. Went from factory torn up bench and red carpet to black carpet from LMC, Procar bucket seats and adapter brackets, purchased from summitracing. I think it turned out all right. The seats aren't sitting too high, and the steering wheel can be used inline with the steering column. I don't have to tilt it up more than center with the column.
#88 |
I just got bucket seats and rails from a 75 k5 blazer will the bolt right in a 1973 c10 or do I need different brackets
#89 |
Trying to get them in my 1973 Cheyenne super short bed.
#90 |
I'm looking for some manual bucket seats. Straight swap replacements for a 89 GMC suburban....anyone have any ideas????
