#76 |
Re: project: Sofa King Big 71'
Adda boy, GIT 'R DUN!
#77 |
hey, hey just letting you guys know i'm still on it.......
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations) Perry, Ok. We're just two guys, trying our best. 72 cheyenne super https://67-72chevytrucks.com/vboard/...d.php?t=811512 55 chevy truck http://67-72chevytrucks.com/vboard/s...d.php?t=840174 |
#78 |
looks good, What color will they be and how wide?
![]() 72 gmc 2500 2wd drive convert ![]() My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
#79 |
i still gotta cut out a few circles in the rim to be able to wash out the mud a little easier. they will probably end up just all black, or a silver color, i am going to see how good the powder coating guy is first and see about getting the centers in silver and the rest in black...who knows.
rims are about 15" wide....
#80 |
Cool Build!
anything new?
#81 |
yes still slowly working on it, snails pase..i have all the rims done and they are fixing to be sent to powder coat....all black. have all bracket templates ready so that i can cut out...should not be to bad to get these all done, just gotta make more time
![]() all in all i have everything here, i just want to be able to start putting all the pieces on and not stop ![]() on a side note: i have been doing 8under baseball and that has been taking a lot of my time, should wrap up baseball around the end of july. we took 1st in a wooden bat tournament and that won us our $400 paid entre to another tournament in Longview, Tx. (6.5 hrs away), for a Little League World Series Wooden Bat tourney, so i'm pretty pumped about that! so now more of my time will be towards working on our fundraiseing projects to get this great group kids there!!! later.....
#82 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice progress! Congrats on the baseball success! Keep up the great work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#83 |
hey, hey, look what i finally got done
![]() ![]() ![]() ![]() this is about all i have really been needing to get it to set up on its own. the rims put a little fire in my butt so i am back to work!!! later......
#84 |
i had a little extra time built up from work, so i took friday off. a buddy of mine offered to come over and help out (he hurt his back a few weeks ago) so i told him sure, but to take it easy!!! so we got to work on these and NOT FUN AT ALL
![]() ![]() ![]() ![]() ![]() my overall answer; get two piece rims or find a Co-op that can do tractor tires.....cause i found out my Co-op stopped and sold all there machines months ago ![]()
#85 |
Holy Crap! 2" sidewalls!!?? I had to do 8 42" iroks on beadlocks one day for a friends shop and I thought that was hard! PROPS to you man! Truck looks awesome, cant wait to see it rollin
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
#86 |
those are a pain...but i can tell you one thing worse, low profile skid steer tires really suck, even with a tire machine!
#87 |
Where did you find the divorced 205 at or what trucks did they come in?
#88 |
i am taking your average 205 and having a shop machine me a front piece (kind of an experiment) so that i can do a fixed yoked on the 205 and a slip yoke off the back of the th400. this way i can pull the Tcase back and put a small drive line between the tranny and tcase and then go from the tcase to the axels.
i am in the works of trying to sell some toys because i may say F the hole deal 205above and just get a PRO FAB full time 4x4 tcase and go from there.... process has been next to none...haveing no luck with tires and have been just burnt out on the whole project, also the $$$$ has been the other issue...life happens....but any who i'm not selling and not giving up so it will be there sometime..... its a toy not a priority....
#89 |
do you know if the Rockwell T-221 is as strong as the 205?
#90 |
from what i understand yes. they are a solid piece of equipment BUT they are a bit bigger and heavier. i have seen guys run these and they work well in the mud and playing around. if you can get your hands on one i would. it would get you going till you may want to upgrade.
what are your overall plans??? my theory is you can have all the motor in the world but its the gear ratio threwout the entire setup that makes it the best. thats why i lean towards the pro fab or SCS case. you can switch out the gears for different events or pits......but with that comes cost ![]() oh and welcome to the board ![]() alot of great info is on here. i might not be making much progress but i still read up to learn a little bit more everyday!
#91 |
thanks and my plans are to build a new frame for my truck have a 14 bolt with locker in the back and a dana 60 up front with either a cummins or an ls engine and use if for towing and playing around.
#92 |
From my experience the Rockwell T-221's aren't as strong and are a lot harder to get parts for. Divorced 205's with RH drop came in International trucks and Scouts, as well as some older dodges in the late 60's and earlier 70's.
Nvrsatisfied, I know all too well how bad those tires suck to mount. My Dad and I mounted my Michelin's on the M/T aluminum wheels and it was a long road. I have one more to do because for some strange reason when I purchased the tires I thought I would need a spare. ![]() Have you used a cheetah to try to inflate your tire? Here is a tip. Mine wouldn't inflate either. We removed the outer side wall, stretched it out as much as we could and placed 4"x4"s or 6"x6"s in between the tire and rim. We let it sit for about an hour, removed the wood, reinstalled the bead and blasted it with the cheetah. We managed to get them all to air up that way.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 12-06-2010 at 06:38 PM. |
#93 |
thanks Dieselwrencher
#94 |
well i apologize for the misleading info..... what transfer am i thinking of that are the big ass military looking ones that are divorced?????
do a diesel engine!!! nothing looks more tits than a diesel dumping the black coal out ![]() ![]()
#95 |
if i can get my other projects out of the way the cummins is the way i want to go
#96 |
That's sweet! Got fuel"
![]() I don't know a model number for the huge military rockwell tcases, but the 221 is the same thing in pre 1971 chevy trucks. Mainly 64-70 manual trans applications I believe.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 12-06-2010 at 09:01 PM. |
#97 |
your pretty close to me. im in ponca city
#98 |
Junior Member
updates?
1979 K10 reg cab short bed 33x12.50s - GONE 1988 4x4 reg cab long bed 337k miles - GONE 1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE 1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE 1994 Z28 M6 1995 Z71 GT4 G80 ext cab short bed 215k GONE 1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE 2003 Avalanche Z71 GT4 G80 165k miles |
