Old 12-07-2011, 10:02 PM   #76
rollinrooster
rollinrooster's Avatar
Re: '49 chevy with s-10
Got some more done on the chassis. It will finally roll again.
rollinrooster is offline   Reply With Quote
Old 12-07-2011, 11:41 PM   #77
oldman3
oldman3's Avatar
What size wheel/tires you running front and rear.....Jim
oldman3 is offline   Reply With Quote
Old 12-07-2011, 11:54 PM   #78
youngrodder
youngrodder's Avatar
Looking good. Keep it up.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-08-2011, 12:07 AM   #79
AD51
AD51's Avatar
Originally Posted by rollinrooster View Post
I just went with new 4.3 mounts. Should be OK from what ive seen and read everywhere.
Did you mount in the original 4.3 location? Im doing the same thing with mine but it looks like I need to move the engine back a few inches.
AD51 is offline   Reply With Quote
Old 12-08-2011, 07:51 AM   #80
rollinrooster
Yep, mine is so close to where i thought it should be that i just left it in the stock location. I considered moving it back a little but after looking it over decided it would work where it was.
Old 12-12-2011, 04:38 PM   #81
texas56
texas56's Avatar
Hey man what size tires are on your truck front and rear?
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 12-13-2011, 09:02 PM   #82
rollinrooster
The wheels are 20x8.5 with 245/45/20 on front and 20x10 with 295/45/20 on the rear.
Old 12-13-2011, 09:07 PM   #83
Kabwe
Certified Car Nut
Kabwe's Avatar
Looks great.
Kabwe is offline   Reply With Quote
Old 12-14-2011, 09:49 PM   #84
Nsanehotrodz
Nsanehotrodz's Avatar
Looks good!
www.nsanehotrodz.com
customerservice@nsanehotrodz.com
865-761-0460
Tennessee's #1 HotRod Shop!
Nsanehotrodz is offline   Reply With Quote
Old 01-30-2012, 07:56 AM   #85
rollinrooster
Got some time to work on the brakes this weekend. This is my first time making brake lines. At first i was scared to death but after a good friend of mine(that just happens to own a hotrod shop) came over and let me borrow some brake tools and gave me some pointers i think i can make this thing stop.
Old 01-30-2012, 09:54 AM   #86
youngrodder
The chassis is looking good. Making your own brakes lines is not too difficult, esocially when you have the right tools.
Looking good.
Marc
Old 01-30-2012, 11:10 AM   #87
daverod
SSN 706
daverod's Avatar
Looks great. Your doing a nice job. That's somthing I've been putting off too. Maybe after watching you I'll try it. No front shocks yet? I'm hoping I'll be able to do my brake lines from just buying the lenghts from the parts store?
daverod is offline   Reply With Quote
Old 01-30-2012, 11:27 AM   #88
rollinrooster
I was going to buy lengths from the parts store, then my buddy talked me into just getting 25' coils and using his straightner.
Front shocks are on my list of thing to do also. One of my friends gave me some front shock brakets that will work once i get a chance to buy shocks and install them. Buy the way your truck is going to be killer.
Old 01-31-2012, 09:53 PM   #89
rollinrooster
Looking good.
Marc
Thanks Marc,
Your truck is an inspiration to me.
Old 01-31-2012, 10:58 PM   #90
youngrodder
Rooster-
Thanks for the kind words. I hope to put more miles on it this summer.
Keep up your progress....we'll be watching. What is the width of your rear rims? I was going to go with 295's in the back but they were on national back order so I went with 275. I'm glad that I did because the 295'3 would not have fit.
Marc
Old 01-31-2012, 11:15 PM   #91
jspek9
jspek9's Avatar
She is comming along nicely...I love your rear upper bag mounts but no step or mini c in the back??? is your rear travel going to be cool??? cant wait to see the body on it again keep up the good work and the updates comming!!!
jspek9 is offline   Reply With Quote
Old 02-01-2012, 09:07 AM   #92
rollinrooster
Rooster-
Marc
Sorry to hear about the 295's but my rear rims are 20x10 with 4.75 backspace.My rearend maybe shorter than yours because with the tires all the way up to the top of the fenders they will clear but it is real close!! But with the truck at ride hieght i have about 1/2 inch on each side to the fender lip.
Old 02-01-2012, 01:12 PM   #93
youngrodder
My rims are 20 x 10 with a BS of 4". I should have explained that it was the outside edge of the tire that would have hit the edge of the fender. It my be the 3/4" that made a difference.
Here is a pic.
I also have a 4 link so I'm not concerned as I don't have any side to side movement.
Marc
Old 02-01-2012, 03:55 PM   #94
rollinrooster
Thanks... as for the rear travel i have about 2 1/2" from top of the axle to the bottom of the frame when let all the way down. My tires are 32" tall and will hit the top of the rear fenders before the axle even gets close to the frame.
Old 02-01-2012, 03:57 PM   #95
rollinrooster
Here is a pic.
Marc
Marc,
What gas tank did you go with?
Old 02-01-2012, 04:14 PM   #96
xpickup
xpickup's Avatar
rollinrooster, your frame is looking great. Keep up the great work.
Shannon
xpickup is offline   Reply With Quote
Old 02-01-2012, 10:56 PM   #97
youngrodder
Marc,
Rooster-
I don't recall. My frame uses a modified G-body frame and I looked through catalogs to find something from a G-body that had the correct filler location. I had to cut the filler neck down. Mine fills from behind the license plate. I also sent the tank out Rockvalley and had a fuel pump retrofitted inside it. This is because I'm running an LT1.
Marc
Old 02-03-2012, 03:11 PM   #98
eventytoo
looking good!
Please more info on the brakes and spindles in the front.
Do you plan on running front shocks?
eventytoo is offline   Reply With Quote
Old 02-03-2012, 05:07 PM   #99
rollinrooster
Originally Posted by eventytoo View Post
looking good!
Thanks... the front end is a kit i got from McGaughys. As for the front shocks i have some brackets that a friend gave me just need to buy shocks and put them on.
Old 02-05-2012, 05:08 AM   #100
iehotrod
iehotrod's Avatar
subscribed
1952 Chevy Pick Up
1962 Chevy C10 Short Bed
1963 Chevy C10 Long Bed
1986 Chevy Silverado Short Bed
2004 Chevy Suburban-wifies ride
iehotrod is offline   Reply With Quote
