Old 07-19-2015, 12:32 PM   #76
chevy2tom
chevy2tom's Avatar
Re: C20 lowered pictures
Yes sir, stock front springs & shocks with drop spindles & it rides great.
chevy2tom is offline   Reply With Quote
Old 07-19-2015, 01:22 PM   #77
Billyburban
The reason I ask is I have a 1970 suburban c10 I just installed the 4inch HD by cpp in the rear an mine looks lower than yours in the rear now the front sits like an 1ich or inch an 1/2 taller. The guy at cpp told me to drop the front 3inchs an it should b close. I believe the c20 set taller than the c10 ? What size rims an tires are you running? The reason I as all this is cause I'm going to be towing my travel trailer it's about 3,000 lbs an I don't want to b to low
Billyburban is offline   Reply With Quote
Old 07-19-2015, 02:07 PM   #78
chevy2tom
chevy2tom's Avatar
I'm running 16" wheels all around & yes the c20s sit higher than the c10s
Old 07-19-2015, 02:13 PM   #79
chevy2tom
chevy2tom's Avatar
Either run air shocks or air "helper" bags that go inside the coil springs when towing
Old 07-19-2015, 05:40 PM   #80
Lerch1145
Lerch1145's Avatar
Anyone have a GMC or Chevy with heavy duty suspension lowered, 8 lug? I have a 72 GMC 2500 with leaf springs rear. Would love to find a simple kit without having to replace every part? Hate to sell her as she is in great shape
1972 GMC 2500
2007 Chevrolet Silverado 1500
Lerch1145 is offline   Reply With Quote
Old 07-19-2015, 09:24 PM   #81
chevy2tom
chevy2tom's Avatar
Axle flip kit, looks like this
Old 07-19-2015, 09:31 PM   #82
Billyburban
Thanks for all the info 👌🏻
Old 07-20-2015, 11:34 PM   #83
dukkie
My Spoon Is Too Big
dukkie's Avatar
Is this bolt on kit using stock suspension? No grinding or welding?
1972 C20, 03-14-10 Build Thread
2000 Silverado 4.8L, 11-04-13 (Currently Parting)
1999 Silverado 5.3L, 07-07-14. (Engine Donor)
2015 Ram 05-20-15 (Daily Driver)
dukkie is offline   Reply With Quote
Old 10-01-2015, 04:00 PM   #84
northerngmc
northerngmc's Avatar
Well I started this thread almost 5 years ago to try and figure out how low to go and then how to achieve that goal.
Here is the before pic.
After replacing the coil springs and shocks. 2" front and 4" rear. I used 1/2 ton coil springs because I could not find a reasonable way to get 3/4 ton springs shipped into northern Canada.
It rides great and drives wonderfully.
And a front corner shot.
I also ditched the hub caps and painted the wheels a flat green. The trim rings where always there but with the white shinny wheels and hubcaps they did not show up well.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 10-01-2015, 04:13 PM   #85
SWB
Active Member
SWB's Avatar
Looks Great ! !.. Love that Color
*K10 SWB. Orange/White
*69 Ford F100 21K Actual Miles, 2nd owner in family since new
*67 Chevy II RestoMod, Wilwood all around,
Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc..
SWB is offline   Reply With Quote
Old 10-01-2015, 06:24 PM   #86
chevy2tom
chevy2tom's Avatar
What he said! ^^^^
Old 01-21-2016, 05:42 PM   #87
ltrrtl
ltrrtl's Avatar
Northern GMC; I Like the stance! I have a 71 Chevy C20. I installed 2" drop coil in front last spring. I have 4" drop coil for the rear to install this spring. I will soon load a pic of the original stance, current and when I ha E installed the rear
ltrrtl is offline   Reply With Quote
Old 01-21-2016, 05:56 PM   #88
northerngmc
Thanks. I can't wait for spring to come so I can put some cruising miles on the truck. Maybe 90 days......
Old 04-04-2016, 04:02 PM   #89
ak808
Here is mine, 2.5 drop spindles, and 4" drop coils. It has 265/75 16 up front and 235/85 16 in the rear just to get it rolling. Need to change out the rear studs to 9/16 and then decide on some wheels and tires...
ak808 is offline   Reply With Quote
Old 04-23-2016, 08:52 AM   #90
chuckamatic
My lowered, uh.... c10+p30= C20?
3"dropped spindles, spring over rear P30 frame (mostly)
chuckamatic is offline   Reply With Quote
Old 04-25-2016, 12:29 AM   #91
drive-em
drive-em's Avatar
Great truck chuckomatic!
drive-em is offline   Reply With Quote
Old 04-25-2016, 12:53 AM   #92
67chevy_hotrod
67chevy_hotrod's Avatar
Wow! I would love to hear the story on that c10+p30 chuckomatic!
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 04-25-2016, 07:58 AM   #93
chuckamatic
So I bought this truck about 4 years ago from So. Md. 250/3speed, even radio delete. Had never been touched. Lowered it a little, drove it a lot. Elderly neighbors stopped driving their Pace Arrow motorhome a few years ago and I finally got it out of them. Cut the RV up (that was fun). Tied in the P30 chassis to the C10 under the cab, kicked it up a little (P30 is straight, no bends at rear), notched over the axle, flip kit on massive rear springs. Frame rail protrudes about an inch into bed, just over axle. No bump in bed, as I wanted full bed depth. P30 A arms, steering (rearranged), springs and dropped spindles bolted in front.
Low mileage 454, TH400, 4.10 14bolt rear, power steering, hydroboost, oil cooler, trans cooler, etc. Put a Gennie shifter in so it looks like it still has a real transmission. I still have room to lower it some more, but those 32inch tall rear tires help calm down that rear gear. Original plan was to switch to regular front wheels/hubs, but I'm diggin those Budd wheels.
Old 10-07-2016, 12:38 PM   #94
ak808
I don't know how to edit my previous post... so here is my 70 C20, with 2.5 and 4 drop, 255/65 16 on newer chevy steelies.
Old 10-08-2016, 12:16 AM   #95
northerngmc
Nice truck neighbour!
Blaine
Old 10-08-2016, 07:36 AM   #96
Boog
laying low
Boog's Avatar
That's a cool look you have going there Chuck. I like it as is but at the same time I am visualizing that stance with rear duals instead matching the fronts.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-09-2016, 01:07 AM   #97
ak808
Thank you! Wishing I lived somewhere I could drive it more than 6 months a year
Old 10-09-2016, 02:00 PM   #98
Jose's 69
Here's my 69 c20. Lowered 3.5 front 5.5 in the back with 225/75r16 tires. Sits almost level.
Jose's 69 is offline   Reply With Quote
Old 10-10-2016, 12:14 AM   #99
northerngmc
I hear you, while it hasn't snowed yet, I parked my truck for the winter last week.
Blaine
Old 10-11-2016, 05:48 PM   #100
hdman6465
hdman6465's Avatar
Here is a 3/4 ton that I sold a few yrs. back. spindles ,bags,notch,blocks,etc.
72 C10 suburban, lowered,nice original
55.1 Panel, bagged,old school
56 Panel,ls power,frame up build
72 C30 enclosed car hauler, 454,FI,4L80E
hdman6465 is offline   Reply With Quote
